Don't, just don't, OK?
Discussion in 'UK Motorcycles' started by WorkTOG, Dec 5, 2003.
  1. WorkTOG
    Ben Guest
    Doesn't Blaney's put out more than that? I will be hoping to get
    around 130 from mine.
    Ben, Dec 6, 2003
  2. WorkTOG
    Figures vary a bit, as is the way with these things. I'd estimate
    that a current B12 will put out ~100bhp out of the crate, the older
    models were quoted at 105bhp.
    Changing endcan for a non-restrictive race item will give you 10bhp
    straight off - a full Akrapovic is reputed to give more like 15,
    despite their claims of only 10 for the full system. The weight
    saving is considerable.
    Re-jetting/needling will yield another 10 to 12bhp on top of the gains
    made by subbing the exhaust. Changing to a K&N is recommended, as are
    mods to the airbox - or individual K&Ns and dispensing with the airbox
    entirely.
    Once you've gone this far, an ignition advancer is required to allow
    the spark to occur 5 degrees earlier, to take full advantage of the
    improved fuelling/gasflow achieved above.
    All in, this will give you a bike with 130 - 135 bhp at the rear
    wheel. Older models, AIUI, will still be ~5bhp up on the newer ones.
    Ha!
    You can get more with head works - gasflowing, valve/seat grinding,
    manifold matching etc - and there is always the GSXR cam swap if you
    *need* more. But you will lose tractability. Actually, you'll lose
    traction a lot earlier if you don't do summat with the suspension ...
    Pip, Dec 6, 2003
  3. WorkTOG
    Ben Blaney Guest
    129 at the back wheel.
    Ben Blaney, Dec 6, 2003
  4. WorkTOG
    Ben Guest
    100PS is standard.
    I'll be going for a Renegade can straight off. According to their
    Dynograph readouts this will give it 120, but they're probably a bit
    biased.
    K&N certainly and will get it Dynojetted when the exhaust is put on.
    They're not too expensive either IIRC.
    Heh, but I want to bigger tank and 'shiny' factor of a new one :)
    I doubt I'll be going that far with it. A belly pan will go on and
    suspension only when it wears out.
    Ben, Dec 6, 2003
  5. WorkTOG
    Ben Guest
    Do you have a fully system or just can?
    And is it properly jetted and setup? I guess it is.
    And can I have a go?
    Ben, Dec 6, 2003
  6. WorkTOG
    Ginge Guest
    Let me know when and where you're taking it.. I need to do the same for
    the ZRX so it'd be interesting to see how they perform back to back.
    I'm thinking about getting one of those legal (but free flowing) Quill
    T3 cans before doing so though as I'm beginging to think the scorpion
    can is just a little too loud.
    Ginge, Dec 6, 2003
  7. WorkTOG
    Ben Guest
    Well, current plan is to buy the bike towards the end of February, so
    we'd be looking at March.
    I was going to take the bike to Renegade, have them fit the exhaust
    and do the dyno and setup at the same time. I can't imagine they'd
    want to fit another make of can than their own though.
    http://www.renegade-products.com/renegade/index.html
    Ben, Dec 6, 2003
  8. WorkTOG
    Ginge Guest
    Ahh, I was thinking you'd be going to somwhere like PDQ to get the
    dynojet kit installed and set up, but would put a can and filter on
    yourself in advance..
    I'll probably just book in with TTS in the new year then as they're not
    too far away.
    Ginge, Dec 6, 2003
  9. WorkTOG
    Ben Guest
    If I decide to go for a different exhaust than the Renegade I probably
    will, but it seems silly to mailorder one from them, fit it, and then
    ride somewhere to have it setup and dyno'd when Renegade offer a ride
    in, setup, ride-out service.
    Will have to wait till I've run it in before it goes on the dyno,
    hence the March date.
    Ben, Dec 6, 2003
  10. WorkTOG
    Ginge Guest
    One thing you'll notice about a 1200 is it takes a lot longer to loosen
    up than a 600 does. I reckon from around 12K mine had only just started
    to feel properly run in.
    So, when you get it dynoed don't expect a brialliant result from new.
    Ginge, Dec 6, 2003
  11. WorkTOG
    Ben Blaney Guest
    Just an ART can. But Bear says they're shit. Mine's fine.
    It is.
    Of course, old son.
  12. WorkTOG
    Ben Guest
    It'll be the first bike I've run in this so anything is going to feel
    a bit odd. It'll also have the most torque of any bike I've had so
    will need a bit of getting used to.
    Wonder if you can GYKD on one? Prolly need to lose the center stand
    first.
    Ben, Dec 6, 2003
  13. WorkTOG
    Ben Guest
    Cool. I'll give you a shout sometime in the new year then.
    Ben, Dec 6, 2003
  14. WorkTOG
    Ben Blaney Guest
    Anytime. Take it for a week if you like - see what it's like to live
    with.
  15. WorkTOG
    Ben Guest
    Magic, I'll let you know.
    Ben, Dec 6, 2003
  16. WorkTOG
    [B12]
    1. No problem there
    2. It _is_ a Bindit, so it will be knee, elbow, shoulder ...
    Not necessary. The pegs go down first, followed by the (standard) can
    on the rhs.
    Pip, Dec 6, 2003
  17. WorkTOG
    Ben Guest
    I'm very intent on this being the second bike I _don't_ bin.
    Oh goodie. Pegs down first is what I'm used to. Wonder how quick
    it'll eat 010s?
    Ben, Dec 6, 2003
  18. WorkTOG
    Ginge Guest
    I'm sure it's possible, it's certainly possible on a ZRX [1]
    http://www.3rhm.com/images/Snetterton020618-1.jpg
    [1] Not that I've quite managed it yet. Mybe next year....
    Ginge, Dec 6, 2003
  19. WorkTOG
    Ben Guest
    Perfick.
    I'm pretty sure I'll be able to, especially given as the seat is 40mm
    lower than the GSXR.
    Ben, Dec 6, 2003
  20. Oh dear, I'm wrong again. I thought the RF mill was a sleeved-down
    Gixer 11 engine.
    The idea has merit...
    Darren Robinson, Dec 7, 2003
