Dominator missfire
Discussion in 'UK Motorcycles' started by ken Booth, Jun 22, 2006.
  1. ken Booth
    ken Booth Guest
    I have just spent the last 3 months rebuilding one
    complete NX650 out of a box of two so I had no guide as to how things were
    assembled.
    Now its done and on the road and all is well apart from it will not
    rev above about 2000 under load and about 4000 with no load without very
    erratic running. it starts perfect and runs perfect at idle and up to about
    2000RPM.
    Above that it runs a little like a 2 stroke when its 4 stroking. and there
    is a little black smoke which led me to strip and check the carb but
    after checking all jets,float height,and choke return, the piston
    diaphragm, and blowing the complete thing out its still the same. I have
    changed with a spare the coil and the CDI unit and it has a
    new plug but still its was still the same. Have tried it with the air
    filter removed as well. The only thing I haven't changed that I can think of
    is the
    pulse generator and this looks like a lot of work so I am asking here
    first although it checks on the resistance according to the manual
    One thing I am not sure of is the two pipes that go the
    carb,Are they both vent pipes, One on the bottom and one on the side. Oh
    and I have replaced the rubber carb mounting tube as there was a small
    crack.
    Any ideas??
    Thanks in advance
    Ken in England
  2. ken Booth wrote
    Which is a classic any number of things, 90% likely to be fuel/air
    related.
    If you do suspect the HT side of things and given the symptoms you have
    every right, then one of the easiest checks to do is to run the bike at
    night and have a look underneath for a pretty plasma display. If there
    is one then you have issues. Better still if you can take it for a ride
    in the rain first.
    steve auvache, Jun 22, 2006
  3. ken Booth
    Sounds like an ignition timing issue to me - possibly related to
    advance/retard, but I'm not familiar with the bike so wouldn't hazard
    any more of a guess than that.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 22, 2006
  4. ken Booth
    TOG Guest
    Black smoke means it's running really rich, so I doubt it's the
    ignition system. Have you got the needle properly seated?
    TOG, Jun 22, 2006
  5. ken Booth
    Is it *definitely* related to RPM rather than throttle position? I.e.
    will it pull fine in a high gear with full throttle up to 2000rpm? If
    so, I'd suspect the advance/retard. If it is more throttle position
    related, it'll be jetting.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jun 22, 2006
  6. ken Booth
    Pete Fisher Guest
    Excellent point.
    Just a stupid question but does it make any difference whether the
    headlight is on or not ?
    By pulse generator I am not sure if you mean the ignition 'sender' unit
    that triggers the CDI or perhaps some kind of charging coil in the
    alternator that supplies juice to the CDI unit.
    If the latter, then have known similar symptoms on a Morini, but far
    more pronounced when the lights were also drawing current from the
    system. Definitely revs and not throttle position in this case.I suspect
    this somehow affecting the flux in the lighting coils and thereby
    reducing the output from the ignition coil (LT windings not HT). The
    *load* factor could also be due perhaps to spark breakdown.
    Probably totally different on your bike though. Howvere, on any CDI
    system bike I would try and find what kind of voltage to expect from the
    relevant windings as well as resistance.
    Anyway, you need to find as much diagnostic info as you can before
    spending too much on replacing stuff that may not be the problem (unless
    you can do a substitution test at no cost),
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Jun 22, 2006
  7. ken Booth
    ken Booth Guest
    Thanks for the replies
    Yes by the sender I do mean the pick up inside the engine that times the
    spark.. And yes the needle is seated I have completely rebuilt the carb
    quoting the book and its all spot on. I was thinking the misfire may be
    related to the fact that if its missing several firing strokes as it
    misfires there will be a build up of unburnt fuel in the exhaust and the
    black smoke is only a small amount. It misfire is when under any load above
    2000RPM I have to say I would have suspected a plug but I have head two new
    NGK new plugs in.
    Thanks Ken.
  8. ken Booth
    Pete Fisher Guest
    Your welcome, but if I were you I would post your reply *below* the
    quoted text next time or you might mildly annoy other UKRMers.
    <BAD FORM I know that's not quite the usual tone>
    Sorry but I am unfamiliar with the bike so will shut up before I confuse
    you.
    Best to ask Honda experts and even better Dominatror gurus.
    However apart from RTFM I would add that if it is a totally CDI system
    with a dedicated set of windings in the alternator for the ignition (the
    acid test being that with true CDI no battery is needed to produce a
    spark) then you need to check the output from those windings.
    | Visit my Home Page : http://www.flarefox.com/Lesbordes |
    | "Do not adjust your mind - there is a fault in the reality" |
  9. ken Booth
    Meaning the choir boys won't be properly seated again for a while.
    Krusty.
    Krusty, Jun 23, 2006
