I have just spent the last 3 months rebuilding one complete NX650 out of a box of two so I had no guide as to how thigs were assembled. Now its done and on the road and all is well apart from it will not rev above about 2000 under load and about4000 with no load without very erratic running. it starts perfect and runs perfect at idle and up to about 2000RPM. Above that it runs a little like a 2 stroke when its 4 stroking.and there is a little black smoke which led me to strip and check the carb but after checking all jets,float height,and choke return, the piston diaphram, and blowing the complete thing out its still the same. I have changed with a spare the coil and the CDI unit and it has a new plug but still its was still the same. Have tried it with the air filter removed as well. The only thing I havent changed that I can think of is the pulse generator and this looks like a lot of work so I am asking here first although it checks on on the restiance according to the manual One thing I am not sure of is the two pipes that go the the carb,Are they both vent pipes, One on the bottom and one on the side. Oh and I have replaced the rubber carb mounting tube as there was a small crack. Any ideas?? Thanks in advance Ken in England
