Doing It the Champ Way
Discussion in 'UK Motorcycles' started by sweller, Oct 11, 2003.
  1. sweller
    Finally got round to fitting some new tyres to the Guzzi, but this posed
    the perennial question about scrubbing in. I've always gingerly tip toed
    about for a hundred miles or so to "scrub off the release agent".
    The Champ doctrine states that this is bollocks and it's only necessary
    to get the tyres hot. But Champ appears to be the only proponent (on
    UKRM) of this method.
    New BT45's [1], 10 miles later (actually to get the engine hot), full on
    side stand scraping action [2]. No problem, nice matt to the edges
    non-slidey tyres. Case proven.
    [1] Top recommendation, cheers Lozzo. Lets see how long they last, I can
    destroy a Macadam rear in 4500 miles.
    [2] The first thing to touch down. Unusual as the Guzzi has loads of
    ground clearance and my style isn't the full on lean.
  2. sweller
    tallbloke Guest
    WHich type of side stand? A lot of people fitted cali stands and frame
    rails to T3's and spadas/Lemans'
    tallbloke, Oct 11, 2003
  3. sweller
    Small gearbox pivot type.
  4. My second Spada had a Cali sidestand. The original one was shite. You
    had to change the lower frame rail as well, to get the Cali stand to
    fit, IIRC.
    The Older Gentleman, Oct 11, 2003
  5. sweller
    I've got that on the back of the BMW - a very good non-sports-bike
    tyre, IMO.
    darsy, Oct 11, 2003
  6. sweller
    darsy had a fit and wibbled.....
    I had them on my 350LC, they grip bloody well for a middleweight H/V
    rated sports/touring tyre.
    Lozzo
    ZZR1100D, GPZ500S, CBCBCB750RSRSRS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 11, 2003
  7. sweller wrote
    I really don't know but perhaps this has something to do with Champs
    actually knowing what he is talking about for a change on this one.
    And I have to say that, although I only have personal knowledge of
    scrubbing in perhaps a dozen new sets of tyres in the last 35 years, the
    logic of it appeals to me so he is not alone
    steve auvache, Oct 11, 2003
  8. sweller
    deadmail Guest
    I'd agree with that, on my third set. One set (on the base model K) did
    about 5k and broke up a bit, I think it's because the gearing is lower
    than on the RT.
    On the RT the set I've got on have done about 6.5k now, hoping for close
    to 10k before I replace them...
    deadmail, Oct 11, 2003
  9. sweller
    Mr Precision Guest
    I am also a proponent. Want to know what's actually happening?
    I give them a couple of heat cycles but it probably isn't necessary.
    Mr Precision, Oct 11, 2003
  10. sweller
    here's an article from the Bridgestone F1 site - Kiesa talks about heat
    cycles towards the end.
    http://www.bridgestone-eu.com/articles.asp?ID=2323
    wessie, Oct 11, 2003
  11. sweller
    Daz Guest
    Certainly something I'd agree with. I head for a roundabout a few
    miles up the road from the tyre dealer, do a few laps and they're
    scrubbed. In a race I've hammered a set of brand new Rennsports after
    one sighting lap and 3/4 hour on the tyre warmers.
    <snip>
    Daz
    GSXR1000K2 - Fun
    Fazer600 - Purpose
    CBR600 - Racer
    MRO#26 | FOT#115 | FOF#48 | two#41
    http://www.highsideuk.com
    ukrm at btopenworld dot com
    Daz, Oct 11, 2003
  12. sweller
    I put a set on the K11 as Lozzo rated them so and it was an improvement on
    Pirelli Match. That said my extreme provocation of the ABS at all possible
    opportunities saw the front wear in equal time with the back. WTF, they were
    cheap.
    Now have a set on the RS, again excellent.
    Hog, Oct 11, 2003
  13. sweller
    Hog had a fit and wibbled.....
    What is this, is everyone trying to make out I'm some kind of fucking
    tyre fitment expert? I'll not suggest any more fitments from now, cos
    pride always comes before a fall.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 11, 2003
  14. sweller
    <Unrolls prayer mat>
    Don't worry you just said you had used them loads and they were good.
    Now Bear and 010's, that's a different matter (ouch)
    Hog, Oct 11, 2003
  15. sweller
    Avon Azaro 3 ST45/46, the new 020.
    Had them on the ZZR for 2,000 miles now, and so far lost 1mm in tread
    depth from 9mm. They grip like 010s all the way to the edges and look
    set to last better than 020s. Wet weather grip is far better than an 020
    and on a par with 010s IMO. They are very stable mid-corner, allow quick
    and effortless turn-in and allow changes of direction without
    complaining when flicking through S-bends.
    My only criticism is they can squirm a little under extremely heavy
    braking and as you pull away slowly from a standstill.
    Overall, I love them, and I paid about 40 quid a pair fitted less than
    020s. That's one good reason to buy them IMO.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 11, 2003
  16. sweller
    deadmail Guest
    I don't use the front brake much, K has plenty of engine braking which I
    tend to use with a touch of rear when filtering. Front only when I need
    to slow quickly (which isn't that often) or at least that's what I
    *think*; I don't have a clue what I'm doing when I'm riding, the bike
    just looks after itself.
    Anyhow... even like this the front is almost fucked when the rear is
    well fucked. K seems to be hard on front tyres.
    deadmail, Oct 12, 2003
  17. Try the magic roundabout at Swindon.
    It goes both ways.
    Roger.
    Old Fart at Play, Oct 12, 2003
  18. likewise the one at the bottom of the valley in High Wycombe.
    Doesnotcompute, Oct 12, 2003
  19. sweller
    Mr Precision Guest
    This is doing my nut in. Darsy, could you please put this on the web site?
    When you get a new tyre, it isn't finished. It's not 100% rubber, I don't
    know how finished it is, 50%, 80%, 99.999% it probably depends on the
    exact tyre compound, even the particular tyre itself, but it's not 100%.
    There's still some amount of the original material left unreacted,
    unvulcanised.
    Tyres aren't made out of the rubber you know and love, they're made out of
    stuff which becomes rubber when vulcanised, it used to be latex but there
    are better synthetic replacements now. These replacements aren't rubber
    either, they are waxy, plasticy materials which can be moulded easily. This
    waxy, plasticy material is treated with a vulcanising agent (which used to
    be sulphur, might still be) and then heated to encourage the chemical
    reaction which turns the original material into rubber.
    The molecules of the waxy material are long chains which can slip over each
    other easily, good as a lubricant, crap as a tyre. The sulphur gets in
    between the molecules and when heat is applied it bonds them together
    turning the lubricant into a springy rubber.
    The reason you have to "scrub" the tyres is that it's time consuming and
    expensive to continue applying the heat to the tyre till the vulcanising
    reaction has gone to completion, I think they do it for 10-20 minutes,
    enough to make it relatively safe and useful. The heat you add when
    scrubbing continues the vulcanising reaction driving it to where it's
    supposed to be. You are *not* removing mould release agents, if you were,
    you could just wash the tyres.
    The chemical reaction continues slowly throughout the life of the tyre but
    the initial heat from the first use of the tyre does most of the work.
    Mr Precision, Oct 12, 2003
  20. sweller
    Wik Guest
    Some do, others don't.
    | Wik -UKRMHRC#10- 2000 ZX12R-A1 -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Oct 12, 2003
