[QUOTE] Aero drag. I'm *always* suspicious of claims that any vehicle gets better fuel economy at 80 mph than it does at 70. Unless there is an obvious gearing mismatch, it makes no sense because air drag is significantly higher at 80 than 70.[/QUOTE] by reduction you could argue that it makes no sense that a vehicle gets better fuel economy at 70 than it does at 60. As you indicate, it's all to do with gearing. [QUOTE] The reason gasoline engine vehicles do better in a higher gear at a given speed is lower pumping loss due to having the throttle opened wider.[/QUOTE] yes, I said that already.
