Dodgy tire?
Discussion in 'UK Motorcycles' started by Cab, Feb 3, 2004.
  1. Cab
    Cab Guest
    On Wed, 04 Feb 2004 12:48:42 +0000, Sean Doherty <>
    bored us all completely to death with wittery prose along the lines
    of:
    I need to send you the latest version of my code, for you to have a
    butchers at too. I'll try to do that tonight for you to comment on :)
    Cab, Feb 4, 2004
  2. Cab
    Sean Doherty Guest
    Aye, will do.
    Peer, review is the way forward.
    Sean Doherty, Feb 4, 2004
  3. Cab
    Sean Doherty Guest
    Works every time.
  4. I've been told that this isnt the case and that the depth of tread (or
    rubber on the carcass) makes a difference to how easily the tyre warms
    up. Worn down tyre means there is less rubber on the carcass to move
    about so it wont warm up as easily. Dunno if this is the case.
    Its been over 3 years since I've had a nice new pair of road tyres on
    a road bike[1] so I dont really know.
    Steve
    [1] Always used shagged out old race tyres that although still have
    loads of tread have had the rubber go off through all the heat cycles
    - but still alright for commuting on.
    Steve Bullimore, Feb 4, 2004
  5. Cab
    YTC1 Guest
    You started it
    ______
    /_____/\ Bruce Porter
    /____ \\ \ Professional Services
    /_____\ \\ / Technical Design Consultant
    /_____/ \/ / / PRE for Solaris x86 on laptops
    /_____/ / \//\ Mobile: +44 (0)771 575 8954
    \_____\//\ / / Email:
    \_____/ / /\ /
    \_____/ \\ \
    \_____\ \\
    \_____\/
    YTC1, Feb 4, 2004
  6. Cab
    This is of course quite correct. The tread 'squirms' and this
    movement generates heat.
    <teaching grandma to suck eggs>
    One of the reasons why slicks are so sticky is that they can use much
    stickier rubber without overheating. This effect can also be seen if
    you do a track day on a road orientated tyre like a BT010 - it'll
    overheat, and shed rubber
    heh. You really are a pikey road racer, aren't you.
    Champ, Feb 4, 2004
  7. Cab
    Cab Guest
    ****, I've just noticed. I must be tyred.
    Cab, Feb 4, 2004
  8. Cab
    And possibly a little deflated.
    CT, Feb 4, 2004
  9. Cab
    Cab Guest
    On Wed, 4 Feb 2004 16:13:50 -0000, "CT"
    <> bored us all completely to death with
    wittery prose along the lines of:
    A bit worn around the edges too.
    Cab, Feb 4, 2004
