The road leading to the little 'superette' where I occasionally buy a sandwich, has an utterly _shite_ surface. So you can imagine the fun today, when, every time I went over a bump, the bike 'lurched', as if the throttle had been brutally (no other word for it) shut. It _only_ (or almost only) happens when the bike goes over an uneven surface, and if I then clutch and try to rev the engine, I can whack the right hand full open, and the engine refuses to go over 2000 rpm. Occasionally, I can 'cure' it by, if I find a sufficiently straight piece of road, I cut the engine and restart it. I'd plump for fuel filter, as I did run out of petrol that time, and it more or less started around then. It might also be wishful thinking, as when they replaced the fuel filter in the South of France, I was physically present in the workshop, and so I know how to remove the tank etc. Also, a fuel filter is (IIRC) 20¤, whereas a pump is a hell of a lot dearer. Any ideas what it could be ? Could it be the fuel pump ? Could it be electrical ? Do I buy a filter and whip off the tank this weekend ?
