Now I've got the Z650 going again, I'm back to a problem I had before the rebuild. The brakes occasionally come on of their own accord! It's happened front and rear at different times. All the calipers have new seals and pistons, as does the front master cyl (back m cyl repair kit seems to be unavailable). What happens is that pressure seems to build in the system, causing the brakes to be applied; the only way to release it is by slacking a bleed nipple off after which it's ok for a while. It can even happen while the bike's been standing, you go to push it and you can't until you've released the pressure. Any ideas, I must admit to being a tad foxed... TIA, Ian
