Do 2-stroke engines have oil filter?
Discussion in 'Motorbike Technical Discussion' started by peter, Dec 13, 2007.
  1. peter
    peter Guest
    It is my impression that 2-stroke engines don't have oil filter.
    So where do the metal filings (wear off from engine parts) go? Do they get
    ejected out the exhaust?
    peter, Dec 13, 2007
  2. Conventional two strokes don't recirculate oil so they have
    no filter. There shouldn't be a significant amount of filings
    produced by either a two or four stroke engine proper.
    Motorcycle gearboxes can certainly produce some fine
    metal powder. On a bike where the engine and tranny
    share a common oil supply, you may see some small amount
    of filings from the gears. Two strokes typically lubricate their
    gear train separately.
    If you ever see large amounts of filings, some expensive
    damage is likely in progress. DAMHIK.
    Rob Kleinschmidt, Dec 13, 2007
  3. If some steel part, like the needle bearing in the top of a rod, was
    shedding metal, the engine would occasionally stop running when the
    spark plug gap was bridged.
    You might be mystified as to the source of the bridging and wonder if
    you were maintaining your air filter properly. Then, one day, your
    machine might quit in the middle of a race and you might wonder where
    the rod bearing went when you tore the engine down.
    Don't ask how I know this...
    Buteo lineatus, Dec 13, 2007
  4. Bits of piston, ring, reed valve, power valve, yesterday's copy of the
    Times - anything and evertthing gets chucked out of a stroker's exhaust.
    The Older Gentleman, Dec 13, 2007
  5. peter
    Dave Emerson Guest
    Plug bridging - usually called "whiskers" - on 2-strokes is most commonally
    deposited carbon not metal, caused by poor quality oil or having the
    fuel:eek:il ratio too high either in the premix or pump settings. This can
    also occur if the transmission seals fail and gearbox oil is sucked into the
    crackcase.
    You *assumed* the bridged plug and mechanical failure were linked. Main
    bearing failure can cause the trans seals to leak but the connection to the
    plug bridging is secondary.
    Dave Emerson, Dec 14, 2007
