DIY tire changing sites?
Discussion in 'Classic Motorbikes' started by TI, Oct 27, 2004.
  1. TI
    TI Guest
    Hi everyone,
    Gotten to the point where tire-changing seems a good thing to know and
    practice. I have a little more free time, am riding more and therefore using
    up rubber more often than ever. Therefore...
    I think I need to spoon my own tires in my own garage.
    Any superior sites for DIY equipment and tips/tricks on tube tires is
    appreciated.
    Thanks in advance.
    -David
    TI, Oct 27, 2004
  2. TI
    D o n ' t F u c k i n g B o t h e r
    sweller, Oct 27, 2004
  3. TI
    Paul - xxx Guest
    sweller vaguely muttered something like ...
    wot e sed ...
    Just tried to remove an old Michelin (maybe 15 years old) from my Beamish
    and replace it with a new IRC Trials tyre .. I gave up and went to a local
    tyre depot when I resorted to the angle grinder to try to cut the beads ...
    They wouldn't charge me, so I later dropped off a 6 pack of Becks for their
    trouble .. they took 3/4 of an hour ... ;)
    Paul - xxx, Oct 27, 2004
  4. Tubed tyres - not much of a problem. It's tubless tyres that are a reet
    bugger to get on and off rims with only hand tools available.
    It would help us a lot if you said what the bike was - I mean, a 125cc
    dit bike, fine, but some hulking great custom thingie that has tubed
    tyres because it has old-fashioned spoked rims[1]: well, that's a
    different kettle of fish.
    [1] Yes, I know many spoked wheels nowadays use tubeless tyres, but
    there are exceptions. The old Triumph 900 Thunderbird, for example.
    The Older Gentleman, Oct 27, 2004
  5. TI
    Dave Painter Guest
    Couple of mates with too many years fitting kwicker than any one
    moved into their own franchise. Now run a van fitted with generator,
    compressor, air line and bead breaker.
    Didn't get much change from several grand! Then they had to buy a van
    They come to the wheel and change the tyre for you. The only thing they
    don't do is remove wheels from
    bikes, too many complications in their insewer ants.
    I changed the tyre on a virago 535 once. Never again.
    Changed the tyre on a 125 dirt bike hybrid rat. Never again.
    For a fiver I have a choice of garages/mobile units to change a tyre for me.
    Just not economic.
    Dave Painter, Oct 27, 2004
  6. TI
    Mark Olson Guest
    Get as many tyres as you can changed ASAP by the blokes in the van,
    then, because it sure sounds like they're giving you a great deal!
    I bought my own t_i_re changing machinei[1] (all of $69) and made a
    balancer ($15) because the local shop wants $30 to change a tire if I
    don't buy it from them. That's the loose wheel price, ride in would
    be more.
    Mail order tires are so much cheaper than paying the shop's markup that
    it made good sense for me, I'll be money ahead after 3 changes.
    If I could get tires changed for $10 I'd never have gone for it, it's
    too much fussing about, but at $30 a pop it makes sense for me.
    [1] Had to drill into the concrete floor of the garage to set anchors
    for it, though.
    Mark Olson, Oct 27, 2004
  7. TI
    Steve Parry Guest
    I've found if after removing the wheel the bike is raised slightly so
    that one leg of the main stand is off the ground then the tyre is put
    under the stand and the bike lowered back down the bead pops easily.
    Having said that for the hassle I'd rather leave it to a tyre depot
    <snip>
    Steve Parry
    http://www.gwynfryn.co.uk
    http://www.arrivedeprived.org.uk/
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Oct 27, 2004
  8. TI
    David Guest
    '73 Norton C'do 750
    David, Oct 28, 2004
  9. TI
    David Guest
  10. TI
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, David
    Ah, is it well screwed together?
    'Cos if it is, you'll be needing Z rated tyres.
    Nigel Eaton, Oct 28, 2004
  11. *Snort*
    The Older Gentleman, Oct 28, 2004
  12. Skinny tyres, skinny rims, tubes. No problems.
    (*Actually* that's what I thought when I was changing a rear tyre on a
    400 Four I bought last year - I had the devil of a job, and it was only
    when I paused for breath, mid-way through breaking the bead, that I
    noticed it had been fitted with a tubeless tyre (obviously with a tube
    in it).
  13. TI
    You need:
    - a bead breaker for tubeless tyres
    - a pair of tyre levers
    - a tub of tyre 'soap' for making the bead on the new tyre slippy
    - a wheel balancer
    You can get all except the tyre soap from here :
    http://www.abbastands.co.uk/products.htm
    Champ, Oct 28, 2004
  14. TI
    in it).[/QUOTE]
    You thick twat. Surely it wasn't the first time you'd noticed this
    trend, was it?
    Ace, Oct 28, 2004
  15. You thick twat. Surely it wasn't the first time you'd noticed this
    trend, was it?[/QUOTE]
    Er, yes, actually.....
  16. TI
    Er, yes, actually.....[/QUOTE]
    So the tyres you've been running on your various SOBs over the last
    few years have been what, exactly?
    Ace, Oct 28, 2004
  17. So the tyres you've been running on your various SOBs over the last
    few years have been what, exactly?[/QUOTE]
    Small things - tyres for the Benly and suchlike are still tube type. And
    for the bigger bikes, I've bought some at Kempton Park, where they still
    sell new tube-type tyres from time to time.
  18. *Governments* change more frequerntly than you change your shirt.....
  19. TI
    Oldbloke Guest
    Hmm, I had to change the tube in the TS50's front wheel.
    3 punctures later it seemed okay
    Dan L (Oldbloke)
    M'boy's current bike 1990 Suzuki TS50X (Heavily fortified)
    M'boys NEW bike 2003 Honda NSR125R
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Oldbloke, Oct 29, 2004
  20. TI
    This is why I don't do tyre changing. I can, but it's such a pita. That
    and expensive alloy rims; tubeless tyres and tyre levers just do not mix.
    sweller, Oct 29, 2004
