Dishwasher cooking...
Discussion in 'UK Motorcycles' started by Platypus, Oct 8, 2003.
  1. Platypus
    Yes, I meant that they wouldn't have parallel cold circuits in the
    same place. Hence the dishwasher, tending to be in the kitchen, would
    nearly always be off an un-softened supply.
    Ace, Oct 14, 2003
  2. Fair enough.
    William Grainger, Oct 14, 2003
  3. A boiler/water heated, central heating system would normally require a
    header tank. Plus a hot water system would have a header tank unless it
    was a direct heated water system or boiler heated with a pressurised hot
    water tank ( They have an expansion ball on top of them.)
    There was a requirement once (early 1900s) that only one tap was
    permitted to be connected directly to the mains and the cold water tank
    in the roof space should contain sufficient water for a family for a
    week.
    All my cold water mains pressure taps go through a softener including
    the feed to the dish washer with one tap for drinking water that does
    not go through the softener but through a filter system. I think this is
    the norm now in the UK.
    Mick Whittingham, Oct 14, 2003
  4. Platypus
    Simian Guest
    Ace :
    Yeah, I wasn't disagreeing with that, I was just being pedantic.
    Simian, Oct 14, 2003
  5. Platypus
    Eddie Guest
    *shock*
    Eddie, Oct 14, 2003
  6. You? being pedantic?
    I *don't* believe it.
    Paul Corfield, Oct 14, 2003
  7. Platypus
    Simian Guest
    Paul Corfield :
    I am far from the most pedantic poster here. In fact, I'm rarely
    being pedantic, per se, more often just attempting to broaden a
    persons vista wrt to the subject at hand, and perhaps provide
    another angle which will help round out their conceptual cognizance.
    HTH.
  8. so that's a bite then.
    It did - enormously :)
    Paul Corfield, Oct 15, 2003
  9. Platypus
    Simian Guest
    Paul Corfield :
    *sigh*
    No, you see, I was being peda... Oh never mind.
    Simian, Oct 15, 2003
  10. Platypus
    *ding* Loik what moin has.
    I don't think it is, unless you're talking just the last year or so.
    Most houses still have no built-in softener or filter, although most
    recent ones certainly have the kitchen cold supply (normally including
    utility room and any other appliance feeds) direct from the mains.
    Ace, Oct 16, 2003
  11. I'm agreeing with you but I didn't put it clearly.
    For the last few years in the UK, if you fit a water softener it usually
    comes with a direct feed un-softened for drinking and this will come
    with its own filter system.
    Mick Whittingham, Oct 16, 2003
  12. Platypus
    OIC, the norm for softener/filter systems.
    Ace, Oct 17, 2003
