Disc bolts.
Discussion in 'UK Motorcycles' started by SaladDodger, May 12, 2008.
  1. SaladDodger
    SaladDodger Guest
    Do they have to be "special"? Or five quid each?
    I currently swap discs from wheel to wheel as I get tyres replaced,
    but this seems a bit like faffing about for my liking. ISTR something
    about not re-using these precious items, too.
    I was thinking of sticking the original discs back on the "old" wheels
    - do I really need NINETY quids worth of bolts to do this?
  2. SaladDodger
    SaladDodger Guest
    Just found a place that has them @ £14 for ten. Much more acceptable.
  3. SaladDodger
    A standard high tensile bolt/allen of the right size should do.
    Hog, May 12, 2008
  4. They do need to be the right grade of steel, for fairly obvious reasons.
    The Older Gentleman, May 12, 2008
  5. SaladDodger
    antonye Guest
    Then use button heads instead of standard sockets, ffs.
    It's not like it makes any difference if they're the right
    size and tensile strength.
    antonye, May 12, 2008
  6. SaladDodger
    antonye Guest
    Just the right tensile strength.
    Definitely not. Find out what size they are and then search
    t'internet to find somewhere that sells said bolts "loose" at
    a reasonable price rather than as a replacement pack for a
    specific bike.
    Torquing them up stretches them slightly, so you don't want
    to do it too often. You'll be fine re-using some old ones
    but I wouldn't want to keep swapping disks about and reusing
    the same ones each time.
    Definitely not.
  7. SaladDodger
    Beav Guest
    Maybe Champ is refering to the width of the shoulder in relation to the
    thread size? All the disc bolts I've seen have a huge shoulder when compared
    to usual bolts ith the same thread.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 12, 2008
