Disabled Bikers?
Discussion in 'UK Motorcycles' started by Bales1983 (Lee Bales), Nov 21, 2004.
  1. Hi all,
    I have cerebral palsy and sometimes find it hard using my legs, I was
    wondering if there are any disabled bikers here? Ive always wanted to
    ride a bike but never tried,
    I have full feeling in my legs its just I have trouble lifting my leg
    over things so bigger bikes are probably out of the question, but maybe
    a cruiser will be ok, Im thinking of getting a Shadow 125 type thing as
    they are lower hence easier to mount.
    Im thinking of a Lifan-Hongda Diable Prince or an x-stream Crusader
    . I totally realise that they are not top notch examples but im not
    that well off. I hear the Lifan is modelled on the Solid CG125 Honda
    engine?
    As a bike are these any good for a beginner? Any suggestions for budget
    but value types of 125?
    One more question is, If i leave my bike on the stand will i be able to
    put my foot on a footrest then lift myself on making it easier or will
    it break the rest/stand.
    Thanks for any help or advice guys
    Lee
  2. Bales1983 (Lee Bales)
    Stonge Guest
    Can you put your feet down when stationary to support you and the bike - and
    can you do it quickly enough in an emergency?
    Stonge, Nov 21, 2004
  3. Bales1983 (Lee Bales)
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, "Bales1983 (Lee
    You need NABD.
    http://www.nabd.org.uk/
    They're your chaps for experience in this area.
    Nigel Eaton, Nov 21, 2004
  4. Bales1983 (Lee Bales)
    Donegal Paul Guest
    "Stonge" replied to "Bales1983 (Lee Bales)"
    Beat me to it. Bales, have you considered a trike at all?
    Im wondering if you have difficulty using your legs, you are talking about
    continualish use of the left foot for gear changing and right for braking
    etc?
    Donegal Paul - On the mend
    Lambretta Li186 - crashed and bashed
    Vespa T5 Millenium - intact
    www.thepilgrimssc.co.uk
    www.a4c.co.uk - What are YOU doing?
    Donegal Paul, Nov 21, 2004
  5. Yep can do, Its not so much moving them about, i can walk ok and ride a
    bicycle, its just the muscles in my thighs are tight so cannot lift them
    very high, Id be fine on a bike if it wasnt for that.
    Lee
  6. I've cross-posted this to a UK newsgroup specifically for bikers with
    disabilities so you may get more help from them.
    Are your legs strong enough to keep the bike upright if it starts to
    tip over? Bikes can be quite heavy!
    Cruisers do tend to have low seats, but sometimes have a higher seat
    back fitted that could be difficult for you.
    Could you manage a step-through type? Not usually considered cool, but
    they have two wheels and a motor, and that's what counts.
    Whether the stand is strong enough for you to stand on the footrest
    while mounting the bike rather depends on the make of bike, and your
    own weight. I'm sure you could find somewhere to strengthen the stand
    for you if necessary.
    Good luck
    Christopher Des Clayes, Nov 21, 2004
  7. Bales1983 (Lee Bales)
    Preston Kemp Guest
    Wouldn't a scooter be a better bet? You'd only have to lift your leg
    enough to clear the footboard (or whatever it's called), & parts supply
    & reliability would be somewhat better than the cheap Hongdus &
    suchlike.
    Preston Kemp, Nov 21, 2004
  8. Bales1983 (Lee Bales)
    Donegal Paul Guest
    "Christopher Des Clayes" said to "Bales1983 (Lee Bales)"
    SNIP
    Oi, my lambretta's cool IMO
  9. Im fine with the continuous use thing as i say its not the use that
    matters its just lifting my leg over the bike thats important, im pretty
    sure all else would be ok. I drive a car which is using the feet all the
    time with no trouble. I wouldnt expect to ever want to move above a 125.
    But no doubt if i get that far the urge for bigger and better will arise!
  10. Bales1983 (Lee Bales)
    petrolcan Guest
    the cont known as Bales1983 (Lee Bales) says...
    Get a fucking wheelchair.
    petrolcan, Nov 21, 2004
  11. Thats one avenue im also looking into, i know scooters are easier, ive
    ridden them, it just doesnt seem to do it for me, if anyone knows what i
    mean.
    Lee
  12. And why would i wanna do that?
    Lee
    Bales1983 (Lee Bales), Nov 22, 2004
  13. Bales1983 (Lee Bales)
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, petrolcan
    Aaaaaaand, in from left field...
    You cont.
    Have you got that fucking monstrosity MOTd yet? If not, bung it on a
    battery charger every now and again would you?
    Ta.
    Nigel Eaton, Nov 22, 2004
  14. Bales1983 (Lee Bales) wrote
    The odd one or two but they can't run fast and get fed up with being the
    butt of the cripple jokes. Their official residence is known as ukpdb,
    to which I have thoughtfully cross posted this thread. Aren't I a nice
    person.
    I've tried. It is all it is cracked up to be and more.
    steve auvache, Nov 22, 2004
  15. Bales1983 (Lee Bales)
    Donegal Paul Guest
    Probably, though personally, (and Im fairly sure im an odd one out on UKRM)
    I don't have an actual hankering over bigger and bigger bikes really.
    I have my Lambretta scooter (currently requiring some repair) and a Vespa
    scooter. The latter will happily do 60-65 as a 125 (standard) If i get the
    cash I may put a kit in this to make it capable of about 80 but maybe not.
    My passion is really the lambretta, which ive uprated to a 186cc and will do
    70-75 which on a 44 year old scooter is either really good or possibly
    suicidal :)
    So, ask yourself why in the first place you actually want to do this?
    I may one day get a "proper" bike, but i may never bother
    Donegal Paul, Nov 22, 2004
  16. Bales1983 (Lee Bales)
    Donegal Paul Guest
    Depends on what you like scooter wise, I dont think i would ever want a
    silverwing or one of them maxi scoots but a classic scooter such as a
    lambretta, i luv em.
    Mind you probably no good to you as theres a foot pedal for the rear brake.
  17. Donegal Paul wrote
    I didn't know it was a series II.
  18. Bales1983 (Lee Bales)
    Donegal Paul Guest
    "steve auvache" said to DP
    Oh yes, the one true Lambretta :)
    Though there's a series III on fleabay that im soooo tempted by and it ends
    tomorrow
  19. Donegal Paul wrote
    Look you scooter riding poof, if the geezer fancies the kudos and public
    denouncement that come with being a biker rather than getting chatted up
    by all the boys like some tart on an Italian styling frenzy then fucking
    get off his fucking case. Biking needs bikers who don't mind pain and
    discomfort. It needs bikers who are prepared to suffer.
  20. Bales1983 (Lee Bales)
    Bales1983 (Lee Bales) emerged from their own little world to say
    Get a 500cc Yamaha TMax. Quite nippy.
    wessie, Nov 22, 2004
