Disable gas tank cap lock
Discussion in 'Motorbike Technical Discussion' started by Morten Becker-Eriksen, Apr 19, 2005.
  1. Any one here who can advise on how to disable the tank cap lock on a
    VTR1000F. I asume it's more or less the same on most Hondas the last 10
    years. I had to change ignition lock last year. I've found my self in the
    position that I forget the key for the gas tank a couple of times and want
    to avoid that. Rather than puting on a race tank cap I'd prefer the original
    look and the look of a fuctional lock.
    /MBE
  2. Morten Becker-Eriksen
    LJ Guest
    I like this idea best. It's simplicity. I have a similar situation with my
    beemer bags. I bought used bags and rekeyed it to fit my bike. I didn't
    use new pins where longer ones were needed, I just filed down the ones that
    were too long. I traded to an 04 1150R and took my bags with. My new key
    works on the bags as will a lot of other beemer keys I suspect
    LJ, Apr 20, 2005
  3. Or have the new ignition lock rekeyed to match the gas cap. It might be
    easier to remove and reinstall.
    Eliyahu
    Eliyahu Rooff, Apr 21, 2005
  4. That was what I wanted to do. But before I start ripping away seals to find
    out how to disassemble the thing I thought I should ask how to correctly
    disassemble the cap.
    /MBE
    Morten Becker-Eriksen, Apr 21, 2005
  5. I don't think you'd have to remove the pins. One trick that works
    is to pull the cylinder, put the new key in the lock, then file
    or grind down any pins that stick out.
    This leaves you with some of the pins still doing their job (sorta)
    and a lock that's easier to pick but won't work for every key.
    Rob Kleinschmidt, Apr 22, 2005
