Digital speedo's
Discussion in 'Australian Motorcycles' started by SJM, Jan 17, 2004.
  1. SJM
    SJM Guest
    Just wanted to get peoples opinion on digital speedos, I've never been a
    great fan, but then I've never had any mode of transportation utilise one.
    Are they a prick to keep your eye on your speed or is it not really a big
    deal???
    JM
    SJM, Jan 17, 2004
  2. In aus.motorcycles on Sat, 17 Jan 2004 18:24:27 +1000
    Do you have trouble with an analogue one?
    Are you someone who can't control the speed of the bike with ease, but
    find it always hunting and speeding up?
    If so, you won't like it.
    If, on the other hand, you can keep the bike pretty steady and just need
    it to check now and then, it's fine.
    Zebee
    Zebee Johnstone, Jan 17, 2004
  3. SJM
    NickZX6R Guest
    I had the same feelings about digital speedos but now that I've
    had a digital bicycle speedo on the bike I find that I use that
    almost exclusively rather than the analogue one.
    They're fine if you're not changing speed rapidly and if you are
    it probably isn't the speedo you should be focussing on.
    Besides, I've found that after getting used to a bike you can
    pretty much tell what speed you're at without a speedo.
    NickZX6R, Jan 17, 2004
  4. SJM
    I'm the same; in fact I squint in the dark to try and see the digits on the
    imperfectly-lit Sigma and forget that there's a fully illuminated analogue
    speedo right alongside!
    Clem
    Knobdoodle, Jan 17, 2004
  5. SJM
    tgare Guest
    Mine is a digital speedo,i dont mind them,ofcourse its easy to speed but
    keeping it at a constant speed isnt too hard.I prefer them and are much
    easier to read especially at speed.
    Tim GSXR6 03
    tgare, Jan 17, 2004
  6. SJM
    Marty H Guest
    when I put a Sigma BC800 on the last bike, my first ride I thought to my
    self why did I bother, after the second ride I didnt look back.
    they are IMHO a little strange at first, but just as easy to read once you
    get use to them
    mh
    Marty H, Jan 17, 2004
  7. Then digital speedo's arnt for me....
    DoinitSideways, Jan 17, 2004
  8. SJM
    NickZX6R Guest
    Dunno about hand in your licence, but reading it on the internet
    is no substitute for experience. I used to think digital speedos
    would make the buying decision, but not now.
    I suspect the LED tacho wouldn't be as bad as they seem. I've
    never tried a bike with one but they've been used on race
    cars for years. It'd be intersting to try one out for myself.
  9. SJM
    Big Fella Guest
    I don't have any problem with the one on the VFR. I think it's just what
    you're use too. When I get a loan bike with an analogue speedo, it takes me
    a few minutes to adjust, but no big deal.
    Cheers,
    Paul
    Big Fella, Jan 17, 2004
  10. SJM
    I used to have a two-digit tacho on my Datto and it was totally useless
    when you were accellerating cause it'd change so fast it'd just read 88!
    Clem
    Knobdoodle, Jan 18, 2004
  11. I use a digital speedo on the pushy, while both the GS and the K have
    analogue. Unless the digital readout is pretty large, I think you'll
    find it harder to easily tell what speed you're doing - although when
    you do see it, it will be more precise (eg 27.5 kph).
    With the pushbike, I have to actually READ the numbers in order to know
    what speed I'm going whereas, with the analogue speedos I can tell at a
    quick glance where the needle is (straight up, or slightly to the left
    of up, or at ninety degrees) to give me a fair idea of how fast I'm
    going - albeit not precisely (eg 120 kph +/- 5 kph).
    The downside of the analogue is that I've ridden the GS for far longer
    than the K, and the needle sticking straight up on the GS is 100 kph,
    while on the K it's 120 kph. I still instinctively look for that needle
    sticking straight up at the 12 o'clock position. (which is why I've got
    a better chance of getting a speeding ticket on the K than I do on the
    GS (aside from horsepower etc)
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Jan 18, 2004
  12. SJM
    Bobby Guest
    I love mine. Easy to read and great for chucking the vid cam on my bike and
    breaking land speed records. My lovers got a vtr with a non-digital speedo
    and ya cant even see the bloody thing nless ya really look at it.
    Bobby, Jan 18, 2004
  13. Zebee said....
    ZJ> If, on the other hand, you can keep the bike pretty steady and just need
    ZJ> it to check now and then, it's fine.
    I find it easier to quickly glance at a digital speedo, such as my cycle
    computer, is easier than a longer glance at the analog speedo to check
    the speed.
    Martin Taylor, Jan 18, 2004
  14. NickZX6R said....
    Ni> Besides, I've found that after getting used to a bike you can
    Ni> pretty much tell what speed you're at without a speedo.
    Until you get that speed camera fine in the mail that alleges your speed
    to be 10 km/h more than what you thought you were doing.
    Or in my case, 4 km/h, which resulted in a $200 versus an expected $165
    fine when I spotted the camera.....
  15. GB said....
    GB> Anyway, that's how the research reads. Digital instruments
    GB> take longer for heads to interpret therefore they suck.
    I can't say authoritatively one way or the other which is better. I work
    in a control room environment where we have a mixture of analog and
    digital instrumentation.
    Mostly it's a combination of LED displays and meters, with a mixture of
    trend/chart recorders, both paper based and LCD types.
    I'd have to say, from my perspective, that a digital display conveys
    info more quickly than an analog one, particularly one that isn't finely
    calibrated.
    On one of the LCD chart recorders, you can select the digital values on
    or off in conjunction with the analog bar that the "pens" line up with.
    I usually have them set to on, as I can quickly glance at the display to
    see instantly what the reading is.
    With gauges, often I have to work out how far past the major increment
    the needle is to get a figure. Say, halfway between 530 and 540 degs C
    on a temp gauge there is the 5 deg increment but the needle is to one
    side of it. A digital readout tells me exactly what it is, without the
    mental process of locating the needle's position, then lining it up with
    the figures on the dial.
    But that's me.
    But as far as bike dashes go, I reckon that the combination of analog
    tacho and digital speedo looks pox. But that's purely a style thing.
    Then there's the Kawasaki thing with one singl round instro cluster with
    an LCD "bar" type tacho surrounding a digital speedo readout...
  16. SJM
    GB Guest
    Nah, I think it's the environment. You speak of an environment
    where you have to read and interpret many many different
    instruments regularly. I'm speaking of one where you have to
    read and interpret *one* over and over again, day in, day
    out. You become more familiar with the single instrument, so
    you can read it quicker.
    I'm guessing the analog speedo or tacho is right, and in your
    control environment, a lot of the digital stuff is better.
    G
    GB, Jan 18, 2004
  17. SJM
    Biggus Guest
    My lovers got a vtr with a non-digital speedo and ya cant even see the bloody thing nless ya really look at it.
    Cause you cant see your boyfriends speedo means you probably dont see
    half the things on the road, or VTR speedos really suck, cause for ~50
    years bikes had analog speedos that people could read..
    Biggus, Jan 18, 2004
  18. I borrowed a mate's VTR for a week early last year and trust me, the
    speedo sucks ...
    Cheers
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Jan 19, 2004
  19. SJM
    Steve Strik Guest
    I have the '03 ZX-6R with the digital speedo and the digital tacho.
    Looking at the speedo it is amazing how you can be holding a constant
    throttle setting and you speed changes with the road gradient, even on
    the flat roads around home (NE VIC) the speed constantly changes 1-2
    km/h around the desired speed, probably hidden in the damping of an
    analogue speedo. The tacho can be hard to read with the ambient light
    conditions, but I don't us it that mush anyway in normal riding, only
    when I'm pushing hard, but that's what the flashing light is for :)
    Steve
    Steve Strik, Jan 19, 2004
  20. In aus.motorcycles on Mon, 19 Jan 2004 09:51:23 +1100
    Or he's spending most of his time out of the Speedo.
    Or the beer belly is *that* bad?
    Zebee
    Zebee Johnstone, Jan 19, 2004
