Reading the specifications in the Honda Shop Manual for my CJ360T, I find that there are four versions of the bike, apparently for export to different countries. The spark plug spec seems to be the main difference among the versions. Type Spark Plug Spec ================================================ A NGK D8ES ND W24EX D.U. (NGK) B8ES (DENSO) W24ES G (NGK) BR8ES (DENSO) W24ESR F.E.ED. (NGK) BR8ES (DENSO) W24ESR In addition, there are Wiring Diagrams for: "A Type", "General and Australian Types", and "U.K., French, Germany, European Types". I don't see much difference in the other specs, except that the A Type and D.U. Type are 70mm shorter in overall length. All the versions have the same wheel base, bore and stroke, compression ratio, and valve timing. I checked the VIN label on my bike, and it doesn't say what Type the bike is. If anybody has any knowledge of these Types, I'd like to hear what Type was imported into the U.S. I'm guessing that the plugs were specified differently to satisfy emissions requirements. Naturally I would like to use the plug that will give the best performance and be the most mechanically healthful. Any enlightenment would be appreciated.
