Decent Wrecker wanted
Discussion in 'Australian Motorcycles' started by Yeebers, Jan 21, 2008.
  1. Yeebers
    Yeebers Guest
    I can't find a bloody wrecker that either has a left fork leg for a
    Hyosung GT250, and / or returns calls or messages.. besides spending
    about 300 less than I've been quoted and risking buying what I need off
    the net from Korea .. after this length of time progress on even FINDING
    the bits I need is roughly zero.
    Today after about 7 weeks I finally got told my fork leg cracked when it
    was attempted to be straightened and have a "nice" figure of $1200 to
    order a new one. Considering that at most the bike's worth 3K it's not
    cost effective to order a new leg,
    After being off the road this long expecting it would "probably" work
    and then being told it didn't is kinda frustrating, I just want to be on
    the road. Does anyone have contact details for a wrecker that at least
    returns calls or emails ?
    At least the bike still starts first go I guess but that does no damned
    good when it's on bricks.
    I suspect I may be able to get a 'matching' part from a different bike
    but I have stuff all idea about what would fit or be suitable etc.
    ID Name Mfg Part # Alpha Part #
    10 DAMPER ASS`Y, front fork L 51220HM8102 HS21937
    It's the whole thing, from the axle up to the triple clamps or whatever
    they're called.
    Any genuine assistance appreciated.
  2. Yeebers
    Yeebers Guest
    Thanks Smiley !
    I presume if I go that way, replace both legs obviously ? :)
    Are the mounting brackets for brake assemblies the same on various
    brands or are they all proprietary ? From what I can tell (limited
    knowledge admittedly) the bottom that has the axle bit and brake mount
  3. Yeebers
    Yeebers Guest
    I've received not a byte for any of the 3 times I've entered what I am
    after into find a part.. Thanks tho, big.
  4. In aus.motorcycles on Mon, 21 Jan 2008 06:38:23 GMT
    Which bit is broken? The tube, or the slider?
    The tube is the shiny tube bit, the slider is the bit the axle goes
    through. (not upside-downers are they?)
    If it's the slider then take a cardboard template of your slider's
    brake mounts with you to check them against the possible sliders.
    Else take the brake itself.
    If the brake mountings are different, then it is often possible to
    make a bracket to fit the old brake, usually hand carved out of thick
    ally sheet.
    NOt that many Hyosungs about so I second findapart.com.au
    replacing a whole front end is not cheap. You also need to match fork
    tube diameters so they fit in the triple clamp properly, and fork tube
    lengths. Sometimes it's easier to take the whole damn front end, and
    get a fabricator to match the stem on the triple clamp to your bike's
    steering head.
    If it is the fork tubes that are done in then that's a little easier,
    although getting an unbent one that a wrecker will sell without the
    rest of the bits could be hard. You'll need to measure diameter and
    length.
    Zebee
    Zebee Johnstone, Jan 21, 2008
  5. Yeebers
    Yeebers Guest
    Hey Zebee thanks for all that, logical stuff but not things a repairing
    n00b would think of :)
    Far as I understand the tube's the part that cracked, but all up it had
    a 'banana' bend (ie all curved rather than a 'bent here only' bend) so
    it could've been either, or both. I didn't think to ask once I'd spoken
    to the mechanic :(
    Basically they're upside down - the gold / tube / thickest part is at
    the top, with a bolt holding a disc over the top, a rubber seal at the
    bottom then the thinner stainless steel-like bit that goes in and out
    (ooer!). The other end of it vanishes into the wheel / brake mount by
    some nefarious means (I see no bolts or anything) which is an alloy
    looking bit with the brake mounts, pinch bolts and axle hole (teehee). I
    can understand how to get the top and bottom apart but I see no way I
    could get the wheel mount off.
    It's not just the front end .. somehow I also managed to kill the rear
    brake light lens and the plastic body under the pillion seat.. dent the
    tank .. obliterate the speedo.. you know .. :)
    My damned knees click every time I get up now, so I know who came off
    best in the accident !
  6. Yeebers
    Yeebers Guest
    Yeah I did that, but all up even with the septic $ being as low as I'd
    seen it, the total came over as $1021au (incl $200us shipping).
    Apparently since it's coming in from OS I get to pay 23% import duty
    then 10% gst on top .. which works out roughly 300 less than the quote I
    got from my local dealer which doesn't come with the 'will I see my
    parts' worry. I have the site bookmarked it was richardhyosung or
    similar in Korea.
    That said I can pick up a single leg for $350septics from there.. I
    asked at the time but someone said the site played music so it was
    evil.. or similar :)
  7. Yeebers
    CrazyCam Guest
    Well...if the value of the item being mailed to you is under a grand,
    you have a good chance of not having to pay any extra tax or duty.
    There are no guarantees, but.... I'd try to keep an order down to under
    $600 Ozzie, total.
    Dunno about Korean postage, but I'd be surprised if it's as expensive as
    the yanks.
    Your local dealer may remove the "will I see the parts" worry, but may
    give a "when will I see my parts" worry instead.
    regards,
    CrazyCam
    CrazyCam, Jan 21, 2008
  8. In aus.motorcycles on Mon, 21 Jan 2008 09:33:41 GMT
    OK so it's an upside downer.
    However... there is still a chance you can replace the tube - I'm not
    familiar with upside downers, but tubes is tubes as far as I know.
    You'll need diameter and length. Then you visit every wrecker you can
    physically reach looking for other upside down forks.
    It's a rare bike alas... so not many bits.
    Start hunting the classifieds for another whole bike.
    Zebee
  9. Yeebers
    Yeebers Guest
    Thanks - I tried the number I have for Hyosung in NSW and it rang 3
    times then said it wasn't connected .. :(
    Not sure what you mean by wrecking the bike then .. oh, ha ! Probably
    right they are a tad on the pricey side but then again all parts
    purchases are the same, cars or bikes.. !
    Yeebers, Jan 22, 2008
  10. Yeebers
    Nev.. Guest
    Nah, the only Hyosung parts in demand on the 2nd hand market are forks.
    Nev..
    '07 XB12X
    Nev.., Jan 22, 2008
  11. Yeebers
    Knobdoodle, Jan 24, 2008
  12. Yeebers
    Yeebers Guest
    no .. thanks :)
    Yeebers, Jan 24, 2008
  13. Yeebers
    Yeebers Guest
    I got one but not that one anyway :)
  14. Yeebers
    Knobdoodle, Jan 25, 2008
