Deauville Headlights
Discussion in 'UK Motorcycles' started by Brian, Jan 8, 2004.
  1. Brian
    Brian Guest
    I must be an amazing rider as I seem to dazzle everyone as I ride on
    dipped beam. Asked the dealers to check the headlight adjustments.
    They said it's fine just the nature of the beast,apparently very
    bright and they've had similar comments from others in the past.
    Has anyone else had this problem, if so how did you resolve it?
    Brian
    Brian, Jan 8, 2004
  2. Brian
    Steve Parry Guest
    don't ride at night ... ? ;o)
    Steve Parry
    http://www.gwynfryn.co.uk
    http://wrexhamseals.tripod.com
    Steve Parry, Jan 8, 2004
  3. Brian
    Linger Guest
    Looks like Honda are trying to dispel the 'dullville' name.
    Linger, Jan 8, 2004
  4. Brian
    SteveH Guest
    Ignore the fuckers - happens all the time on my VFR, and I'm sure it
    happens to Elly on her CBR, too.
    It's just one of those things with the super-bright headlamps on modern
    Honda kit.
    SteveH, Jan 8, 2004
  5. Brian
    JB Guest
    You mispelled piss-poor-optical-design.
    Most modern headlight designs on bikes, or cars for that matter, are pretty
    shite in terms of output, glare, and beam control. To prove a point, have a
    look at any older (70-80s) bike or car with Cibie 'Z-beam' inserts.
    *Superb* beam pattern with typically 150-400% improvement in output compared
    with some modern optics using the same lightsource.
    So-called 'bullet' or 'projector' types with aspheric lenses are only apprx
    25-30% efficient. The older rectangular units on the 80s GPz for example
    achieve >80% optical efficiency.
    More information you never needed to know brought to you by...
    JB
    JB, Jan 8, 2004
  6. Brian
    AndyH Guest
    The MOT garage always set my headlight too high. When the bike is
    just stood there it was spot on, but once I sat on the bike, up they
    go. The 80 watt bulbs don't help.
    AndyH, Jan 8, 2004
  7. Brian
    SteveH Guest
    That's absolutely bollocks.
    Have you ever ridden a new-ish Honda - VFR800, CBR600F-S(?) etc?
    The headlamps are _superb_ - by far the best conventional headlamps I've
    ever used.
    Refer to Pip's postings regarding 'riding in the shadow of Elly's
    headlamp as it overpowers the pathetic light on my RF900.
    They are an _excellent_ optical design - they're just so bright that
    other drivers seem to think they're on main beam.
    SteveH, Jan 8, 2004
  8. Brian
    Which to me, makes them sound like piss poor optical design for a
    vehicles headlight.
    A good design, IMO, would be bright, clear, good spread and reach but
    *without* blinding every other poor fucker in oncoming vehicles.
    sweller, Jan 8, 2004
  9. Brian
    Catman Guest
    ding
    Best headlight on any car I've driven are 21 years oldd, and
    apparently they dazzle no-one
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    www.cuore-sportivo.co.uk
    Catman, Jan 8, 2004
  10. Brian
    JB Guest
    They are not excellent examples of optical design. Yes the lights on a
    recent VFR800 are very bright! They bloody ought to be with 2x 60/55W H4s
    *and* 2x55W H7s! If they apper to be on high beam to other drivers, when
    actually on low beam, then the light is not going where intended; ie on the
    road surface. I agree that the high beam performance is excellent however,
    but high beam reflector/refractor design is comparatively straightforward
    compared with the restrictive design criteria for low beam units, especially
    when you throw so much raw power at the problem. Generally the smaller the
    reflector the less efficient it will be for a given light source.
    I have been designing high performance lighting optics and the lamps for
    them, for over 25 years now, and also designing/building the photometric
    testing systems which are used *by* the manufacturers.
    I'm not saying *all* modern headlamps are crap. Just most are now governed
    by body-sylists, and th eoptical engineers get told "this is the total space
    you've got to put the lightsource/reflector/lens etc in".
    JB
    JB, Jan 8, 2004
  11. Brian
    Catman Guest
    On Thu, 8 Jan 2004 23:07:34 -0000, "JB"
    That matches nicely with the lights I was talking about. Bloody great
    square things they are, but the cast a very sharply defined beam
    Catman, Jan 8, 2004
  12. Brian
    JB Guest
    Yup. But the styling gurus these days don't like big-square or big-round
    boring old headlight designs. They like minimal frontal area on cars, sexy
    swooping curves on bike fairings and the result is tiny and misshapen
    headlights which as a rule are shite!
    You want it really bad, move to the US. With their truly appalling lighting
    standards, they are lucky to be out at night at all.
    JB
    JB, Jan 8, 2004
  13. Brian
    Catman Guest
    On Thu, 8 Jan 2004 23:33:05 -0000, "JB"
    I'm glad I have a boring car and bike then
    Well, frankly they should never be let out without a responsible
    adult.
    Catman, Jan 8, 2004
  14. Pretty much confirms what I've seen for years. The old Z1100 headlight
    unit on my GS is far, far superior to many others (but not all, it must
    be said) of the day or since. Big reflector area, fairly good cutoff on
    dip with all the light spreading nicely like a white carpet in front of
    you and a bloody good main beam.
    Nice to get things from the 'orses gob. Ta.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Jan 9, 2004
  15. Brian
    Unfortunately their definition of responsible adult is a bit shaky as
    well.
    sweller, Jan 9, 2004
  16. Brian
    Catman Guest
    Responsible *non* American adult?
    Catman, Jan 9, 2004
