Dealing with clutchslip
Discussion in 'UK Motorcycles' started by Nev Arthur, Sep 21, 2004.
  1. Nev Arthur
    Nev Arthur Guest
    'Hog said...
    And if I can't get hold of any new clutch bits, believe me, I'll
    try it!
    Nev
  2. Nev Arthur
    Nev Arthur Guest
    Nev Arthur wrote
    Found some other stuff on the net about relative merits of dear
    and expensive oils, car versus bike oils, etc. Fascinating stuff,
    I'm definitely going to change the oil in the bike, it's an easy
    job right?
    Good advice.
    Been there, read a load of good stuff in there in the last couple
    of hours, hoping I'm not doing the stuff that could piss you off,
    and apologies for any going over old ground that's boring for the
    regulars.
    Cheers, Nev
  3. I believe this is the real s.t.
    Same style, same spelling mistakes (check the OP) and our revered friend
    didn't use punctuation, either.
    Whinging Courier, Sep 21, 2004
  4. Nev Arthur
    That's much better Chris. Thanks for the advice.
    Pip, Sep 21, 2004
  5. Nev Arthur
    Nev Arthur Guest
    I'm beginning to think that's what's in the gearbox.
    A trip down Halfords tomorrow I suspect!
    Is replacing clutch springs a job for a beginner at this bike
    maintenance malarkey?
    I think I will inspect everything I can see to the best of my
    ability, change the oil, and see how we go. Anything to watch out
    for with changing the oil, like the old X7 trick of buggering up
    the gear change if you left out the washer?
    No, it's a silver one, used to belong to the 125cc champion of UK
    apparently, then I bought it off of his nephew. It's not a
    terribly well cleaned or maintained example, but it is nearly
    original. S reg though.
    Thanks for the help, Nev
  6. I have loads of pattern piston rings for the RD400, in several
    oversizes.
    You'll need 'em.
    The Older Gentleman, Sep 21, 2004
  7. Nev Arthur
    Loz H Guest
    Whinging Courier <> spewed forth the
    following...
    <fx: Dons deerstalker hat>
    The Dogmeister always posts from a Blueyonder IP in Enfield, London, whereas
    this particular specimen is posting from a BY IP in the Aztech West area
    near Bristol.
    Loz H, Sep 21, 2004
  8. Nev Arthur wrote
    One of the easiest you can do.
    Where do you live? A surprising number of ukrm regulars will be more
    than happy to come and take the piss out of you, your bike and all sorts
    of other things whilst pretending to give you a hand.
    steve auvache, Sep 21, 2004
  9. The Older Gentleman wrote
    No gaskets or indicator lens? You are slipping in your old age.
  10. Nev Arthur
    Nev Arthur said...
    PGM YAMAHA SPARES
    TEL/FAX# 01289 386720
    They should have or be able to get all you'll ever need.
    Lozzo, Sep 21, 2004
  11. Nev Arthur
    Steve Parry Guest
    www.pgmyamaha.com
    Steve Parry
    K100RS SE
    F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Sep 21, 2004
  12. For a confident beginner it should pose little problem.
    This bit is very important:
    When the Haynes book of lies says: Use a torque wrench set to the
    correct setting when doing the spring retaining bolts up.
    It means it. Really.
    DAMHIKIJKOK?
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Sep 21, 2004
  13. Nev Arthur
    Nev Arthur Guest
    Nev Arthur wrote
    Well, that's the kiss of death innit? Gonna be oil everywhere
    now! :)
    I'm in Kent. Anyone wants to come round on an RD, they're gonna
    be more than welcome. Especially if that clutch *does* need
    changing!
    Nev
  14. Nev Arthur
    Nev Arthur Guest
    How did you end up with loads of those to get rid of? Stocking up
    waiting for the worldwide shortage and the consequent increase in
    demand making you rich? ;-)
    Nev
  15. Nev Arthur
    Nev Arthur Guest
    Superb, thanks for that.
    Nev
  16. Nev Arthur
    Nev Arthur Guest
    Useful looking site, cheers.
    Nev
  17. Nev Arthur
    mups Guest
    Nev Arthur says...
    Dead easy. Just one bit of advice if you haven't done it before. Don't
    just fill to the mark on the dipstick. Fill it to the mark and then run
    it for 30 secs, stop and then check the level again, top up if required.
    Repeat until the level stabilises.
    mups, Sep 21, 2004
  18. Nev Arthur wrote
    Well yes. This is why you buy cement dust.
  19. Nev Arthur
    Telewest's offices are in Aztec West. He could be anywhere.
    platypus, Sep 21, 2004
  20. Nev Arthur wrote
    If that is TOG you are asking the question of, then yes.
