Dead Battery.
Discussion in 'Australian Motorcycles' started by Aaron & Kylie, Dec 14, 2003.
  1. Aaron & Kylie
    Johnnie5 Guest
    looking at the specs of 2 bike manuals i have on the shelf here
    ZXR750
    14.5volts @4K RPM
    RGV250
    13-15.5v @ 5K RPM
    i think you will find at higher revs the current output will be higher
    almost all of them
    idle speeds are generally 1500 or less
    alternators are built small and generally dont have such a huge supply
    in excess of what is required in a bike environment due to space and weight
    restrictions
    the probs a lot of people face which is coming into cars now is that between
    EFI, Fuel pumps,
    lights etc that is a huge current drain
    as an example think the duke was using 20+ amps just running all the above
    crap
    FYI cars are going to go to think IIRC 48V as this way less current is
    required with the higher voltage
    and in turn smaller cables are required through the car also then a weight
    and space saving
    first car i heard of this was the late 7 series BMW's they run water cooled
    twin? alternators
    to cope with all the electric crap in the car
    it takes a while after starting a bike to recharge the battery back to the
    capacity of what was used to start it
    Johnnie5, Dec 17, 2003
    #41
  2. Aaron & Kylie
    Theo Bekkers Guest
    "Johnnie5" wrote
    higher
    I think Charlie may be looking at car specs where 1500 engine rpm will
    have the alternator turning at 3000 rpm or more. On most motorcycles
    the alt turns at engine rpm so your figures of 4 or 5K are about
    right, though I think the Guzzi reaches it's max output at less than
    3000. However that equates to over 90 km/h in top gear. Hardly what
    you would expect to do in traffic. At idle, most bikes will be
    discharging the battery if the lights are on.
    Theo
    Theo Bekkers, Dec 17, 2003
    #42
  3. Aaron & Kylie
    Conehead Guest
    Surely it depend's on you'r jetting?
    Conehead
    Conehead, Dec 17, 2003
    #43
  4. Aaron & Kylie
    Theo Bekkers Guest
    "Conehead" wrote
    Oh dear, I've misplaced an apostrophe. Please accept my humblest
    apologies.
    **** off Coney!
    Theo
    #44
  5. Theo Bekkers said....
    TB> I think Charlie may be looking at car specs where 1500 engine rpm will
    TB> have the alternator turning at 3000 rpm or more. On most motorcycles
    Actually, I was looking at my own bike. The lights would dim and then be
    at their brightest below and above around 1,600 rpm, when I was having
    the battery problem.
    But yeah, just looked up the specs for my bike's charging system.
    Regulated voltage 12.5 - 15v as measured at 5,000 rpm.
    Charlie Haughs, Dec 18, 2003
    #45
  6. Aaron & Kylie
    Mike.S Guest
    I have found recently on my bike that the indicators which i previously thought weren't
    working correctly after i changed my rear indicator stalks. Were just not getting quite
    enough voltage to go from continually-on to blinking when waiting at the lights and idling
    (1400rpm idle). I found a tiny twist of the throttle and about 300rpm more and the alternator
    was making enough power for them to work correctly. so now when at the lights i just once
    in a bit touch the throttle lightly while waiting.
    I havent bothered measuring the charge as it seems to be behaving itself for the most part.
    Mike.S
    Mike.S, Dec 19, 2003
    #46
  7. Aaron & Kylie
    Theo Bekkers Guest
    "Charlie Haughs" wrote
    Charging systems are about amps not volts.
    Theo
    Theo Bekkers, Dec 19, 2003
    #47
  8. Aaron & Kylie
    I wouldn't've believed that except my Trump used to do the same thing.
    It would pushstart on the first step but just would not electric start!
    Clem
    Knobdoodle, Dec 27, 2003
    #48
  9. Aaron & Kylie
    conehead Guest
    Same thing happened with a loaner Yamaha 650 I used. Engine turned over
    easily on the starter motor, but it wouldn't fire unless the kick-starter
    was used.
    conehead, Dec 27, 2003
    #49
