Daytime Headlights
Discussion in 'UK Motorcycles' started by gazzafield, Jul 13, 2005.
  1. gazzafield
    Ben Blaney Guest
    Should you be using the brakes to correct a line?
    Ben Blaney, Jul 14, 2005
    #81
  2. gazzafield
    Ben Blaney Guest
    This is the man who rides with full beam on all the time, remember.
    Don't expect any sense.
    #82
  3. gazzafield
    Ben Blaney Guest
    The "you're as slow as Ginge" crew will weigh in imminently - but ****
    them: I did 9000 miles in 9 months on my VFR800 and I never noticed
    that it had linked brakes. I knew it had them, of course, but I was
    never aware of any untoward effects.
    I noticed when I did a tight U-turn on a loaner about three years
    previously, when I dabbed the rear in mid-turn and it reacted
    strangely but not severely.
    #83
  4. I'm amazed you're still in one piece, to be honest.
    The Older Gentleman, Jul 14, 2005
    #84
  5. Like I think I said up there somewhere, I didn't notice Zymurgy's
    Blackbird had them until he told me.
    #85
  6. gazzafield
    Ben Blaney Guest
    They worked to my satisfaction. Does that count?
    In so many ways.
    #86
  7. gazzafield
    AFAIR its more about the intensity of the light, because they are close
    together it's difficult to judge the speed of the approaching bike rather
    than any "utter and profound fool of a European health and safety person".
    You can see this effect on a bike approaching you with lights on main
    beam.
    sweller, Jul 14, 2005
    #87
  8. gazzafield
    Then you're a fool.
    #88
  9. gazzafield
    It's not about being dazzled.
    #89
  10. gazzafield
    I've had a bike with linked brakes for the last 10 or so years and never
    had a problem [1].
    I'm of the opinion you don't have the confidence, or ability, to judge
    what the machine is doing or about to do.
    [1] I did, however, find coming down a slope covered in sheet ice a
    bit tricky but TBH riding any bike down it was going to be foolhardy.
    #90
  11. gazzafield
    My experience is the same, except it's 20 years in my case.
    #91
  12. gazzafield
    The Guzzi linked brakes are a bit different but I find it a lot more
    stable into corners as it has the effect of making it 'squat' down and
    tighten up the whole suspension package, IYSWIM.
    #92
  13. gazzafield
    What do you do on an unlit road at night?
    #93
  14. gazzafield
    I put them on when it's dark or foggy otherwise they stay off, exactly as
    I do in a car.
    This maybe a product of having had bikes and cars with quite marginal
    charging systems.
    It's worth mentioning I very rarely have SMIDSY panic braking moments [1]
    and I ride a fair few miles a year in both rural and urban environments.
    [1] I do have a penchant for bowling over pedestrians but that's on
    the MZ and its brakes are shit.
    #94
  15. gazzafield
    "A gentleman does not motor about after dark."
    platypus, Jul 14, 2005
    #95
  16. gazzafield
    The same effect could be had by using the front and rear brakes together,
    and your back end probably squats when you close the throttle. You don't
    have the option of using the rear on its own, or both fronts without the
    rear. I accept that you don't have a problem with it, but that's more
    likely down to skill and experience, and adapting to that particular system
    without really needing to think about it. Did you find the unlinked brakes
    on the Turbo a bit weird?
    Also, how do you know whether or not it would be better just using both
    fronts? Champ recently remarked that he used the front-end dive under
    braking to sharpen his turn-in.
    #96
  17. gazzafield
    Not especially. They're a bit rubbish though - wooden is probably a
    better description.
    I did find the Turbo's front end twisting and becoming unsettled when
    pushing on a bit. The Guzzi doesn't seem to be quite so 'tied up' under
    heavy braking and both have similar pipe cleaner forks.
    I think my style is a bit less technical and a little more 'wrestle' than
    Champ's.
    As you say, it maybe something I ride round but I find going in with
    front only (obviously I have less brake force) seems less on rails than
    using the linked side.
    The linked side also allows for some pretty heavy mid-corner braking if
    the need arises (this is nice way of saying 'fucked up'); the Turbo won't.
    #97
  18. gazzafield
    Jap brakes from an era when Italian brakes were the best in the world.
    You've been spoilt, you know.
    You've never braked the Guzzi hard without using the rear, though. I
    wouldn't be surprised to find that the Guzzi's frame is a lot more rigid
    too.
    He's a sportsbike guy...
    Front and rear together will unsettle the bike less than fronts only. I use
    both sets going into corners myself. I don't think that's the argument
    here.
    You are Ginge AICMFF mid-corner speed corrections. Didn't you use the back
    brake on the Turbo?
    #98
  19. Dunno. I always have done though and it works for me (or at least it
    does on non-linked brakes bikes).
    It's only a light dab. Sort of a teddy-bear sort of thing. I can give
    it up any time I like. Honest
    Phil.
    Phil Launchbury, Jul 14, 2005
    #99
  20. So all those morons who drive around with their front fog lights on are
    breaking the law?
    Cool. Now I can hate them with a good reason other than the starburst
    halo effect that their pointless little "I want to look like a rally
    driver even if I haven't got either the talent or the car" lights give.
    Phil.
