Datatool alarm on Triumph Speed Triple
Discussion in 'UK Motorcycles' started by caz, Nov 29, 2003.
  1. caz
    caz Guest
    Hi!
    I have a '03 speed triple with the datatool series 3 alarm accessory
    fitted on it. It was fitted by my local dealer and after i got the bike
    back i noticed that there was a recommendation in the users guide to set
    a pin code on the alarm. The problem is that to set the initial pin code
    i have to remove the "In-line fuse" and i can't find it. I have followed
    all cabels from the alarm and i can't find any special fuse for the alarm.
    I have a fragment of the fitting instructions and the only thing i can
    find about the fuse is:
    "The alarm is protected by the fuse shown in the motorcycle fuse box."
    The Speed Triple have 10 fuses in the fusebox and noone is labeled
    "alarm" or something like that.
    Does anyone have any idea which fuse in the fuse box to remove when
    setting the pin code?
    /Marcus
    caz, Nov 29, 2003
  2. caz
    Robbo Guest
    Pull out the fecking lot then !
    Robbo
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Nov 29, 2003
  3. caz
    caz Guest
    Alreay tried that. However after your reply i went out and tried one
    more time and this time i managed to find the right one. I must have
    made something wrong the first time.
    caz, Nov 29, 2003
