Data Dots
Discussion in 'Australian Motorcycles' started by Boxer, Nov 26, 2003.
  1. Boxer
    Boxer Guest
    My car came standard with data dots to protect it against theft, sounds like
    a great idea for bikes too, particularly those prone to be stolen such as
    Harley, Ducati, and sport bikes.
    Any one had it done on their bike?
    Boxer
    http://www.mdatatech.com/
    Boxer, Nov 26, 2003
  2. Boxer
    Dave Ello Guest
    Yup - mine came with it. I believe new Yammies come with them standard too.
    Still have mine... touch wood.
    Cheers,
    Dave ZZR600 => ST2 (stolen - *no* data dots) => '03 XX (data dots all over
    the bastard)
    Dave Ello, Nov 26, 2003
  3. Boxer
    Chris R Guest
    Applied them myself to my bike at the request of the (at the time)
    insurer. Dots were purchased as a kit (a little over $100 from memory)
    containing the dots in a clear adhesive and a small brush to apply.
    Have applied them all over the bike, especially major components. Then
    registered the ID Number with a mob called Identify Australia who hold
    a register of identified items. If the cops come across recovered
    items they get the number of the dot and contact them to identify the
    original owner.
    Were easy to apply, but took an hour or two (removing fairing, lifting
    tank to get to engine airbox, cam cover, head etc). Then applied a
    couple of stickers that state the bike is fitted with datadots.
    A number of cars now have them sprayed on ex-factory. Subaru, HSV and
    BMW among them from memory.
    Neat idea which if you believe the manufacturers blurb have reduced
    theft rate on vehicles so identified dramatically in the UK.
    Chris
    Chris R, Nov 27, 2003
  4. Boxer
    Bernie Dwyer Guest
    In Qld, the RACQ now offer a datadot service - about $400 from memory -
    maybe less for bikes, but I doubt it.
    Now, a technical question - a datadot is a tiny,
    visible-only-in-UV-light, dot of material sprayed or brushed in their
    thousands onto as many vehicle surfaces as possible - panels, parts, etc
    - but probably not the glass. Each dot is engraved/printed with a number
    that will identify your stolen vehicle/part to plod if and when it's
    found. OK so far?
    How do they make sure that the dots land number side up? I mean, what if
    they were all applied face-down? ;-)
    Bernie Dwyer
    Dump two z to reply to me
    Bernie Dwyer, Nov 27, 2003
  5. Each dot also has a _very small_ piece of buttered toast attached to
    it...
    big
    Iain Chalmers, Nov 27, 2003
  6. Boxer
    Nev.. Guest
    Simple... just double the number of dots applied. Then if the original
    quantity all land upside down there's a possibility some of the remainder will
    land right way up. ;)
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 27, 2003
  7. Boxer
    Greg Byrnes Guest
    Datadots are no longer painted on - they are sprayed on - around 5,000 of
    them. They also now contain the VIN number so the "serial number" does not
    have to be registered. Cost is about $290 for a bike.
    Greg
    Greg Byrnes, Nov 27, 2003
  8. Boxer
    Skipper Guest
    Yep, all of the Yamaha roadbikes come standard with them, they have since last year I
    think.(I understand the road-registerable trailies don't yet but they are thinking of
    doing all of their range soon)
    Doug.
    Skipper, Nov 28, 2003
  9. Boxer
    Chris R Guest
    Yep. Aware of this. Mine were applied about 3 years ago before the
    spray on service was available. Application at that time involved
    applying them manually with a small brush (getting the damn things out
    of the container and on the end of the brush was a prick of a task).
    As they were bought in a kit they came with a pre-allocated serial
    number which subsequrntly needed registering.
    I'm guessing I managed to apply quite a few hundred across all major
    components before giving in, but certainly not 5000. Better than
    nothing though.....
    Chris
    Chris R, Nov 28, 2003
  10. Boxer
    Dr.Shifty Guest
    They only use numbers that look the same from the other side of the
    see-through dot.
    That means that they're all 0, 1, 3, 8, or 6 and 9 (interchangeable).
    Kim
    Dr.Shifty, Nov 28, 2003
  11. Boxer
    sharkey Guest
    10 points to Dr. Shifty!
    -----sharks
    sharkey, Nov 29, 2003
  12. Boxer
    Dr.Shifty Guest
    Fangs, Sharks.
    I've never been much good at fishing, but if you hide the bait well enough
    something take a nibble.
    Kim
    Dr.Shifty, Nov 30, 2003
