Dangling Alternator Question
Discussion in 'Motorbike Technical Discussion' started by loa13mbb, Nov 4, 2008.
  1. loa13mbb
    loa13mbb Guest
    So I'm having problems with my voltage rectifier. In the meantime I'm
    leaving it unconnected, and charging my battery at night. My question
    is this: because the voltage rectifier is unconnected, the alternator
    is now dangling (not outputting into anything). Is this harmful to
    the alternator or just plain dangerous?
  2. loa13mbb
    lneukom Guest
    It's a '97 BMW F650. And yes, I made sure that alternator wires were
    cared for. Thanks for your response.
    lneukom, Nov 5, 2008
  3. I think you've got a permanent magnet alternator with
    a regulator/rectifier combo. In that setup, the regulator/
    rectifier has to dissipate unused current as heat rather
    than de-energizing an electromagnetic rotor.
    For a permanent magnet setup, I'm not sure about leaving
    the R/R completely disconnected. electrexusa.com is a
    good resource. I'd also recomend the beemershop in
    Scott's Valley, Ca as a pretty good source of advice and
    online parts.
    Rob Kleinschmidt, Nov 5, 2008
  4. loa13mbb
    . Guest
    Do NOT run your engine with a permanent magnet alternator disconnected
    from the rectifier regulator, except to test the open circuit voltage.
    The insulation on the alternator stator coils is just a thin layer of
    plastic meant to withstand 20 or 30 volts and it can be punctured by
    open circuit voltage of 90~100+ volts.
    ., Nov 5, 2008
  5. loa13mbb
    . Guest
    It may take a while for the voltage to puncture the insulation, but,
    given time, temperature and immersion in oil, the windings can short
    to the metal core, taking one phase out of use and reducing output
    power by half.
    Look at all those Suzuki GS stators that went bad.
    The plastic connectors that hook the stator and the rectifier
    regulator to the main wiring harness would get hot and melt, and
    that's almost the same as running the alternator open circuit.
    ., Nov 5, 2008
  6. loa13mbb
    Loa Guest
    So I just spoke to the tech support at electrosport.com, and he stated
    that there would be no harm done leaving stator unconnected. Now, I
    hear and believe what you are saying, so would a viable solution
    (besides actually replacing the bad VR :) ) be connecting the stator
    to the VR, but leave the VR output dangling?
    Loa, Nov 5, 2008
  7. loa13mbb
    . Guest
    Oh, what do the tech support kids know, anyway?
    I am assuming that your motorcycle has the typical permanent magnet
    alternator, NOT a car type excited field alternator.
    If you run an excited field alternator disconnected from a battery, or
    from the regulator, nothing bad happens.
    A permanent magnet alternator really needs to have a battery in good
    condition connected to the regulator DC output.
    The battery forces the system to operate somewhere near battery
    voltage.
    An almost dead battery forces the alternator to run at about 12.0
    volts or less.
    A fully charged battery in good condition lets the alternator run up
    to around
    18 volts before gassing and boiling the electrolyte, if the regulator
    fails.
    The regulating circuit tries to keep the voltage between about 14.5
    and 15.5~16.0 volts, depending on whether it's a flooded-cell battery
    or a maintenance free AGM battery.
    The permanent magnet alternator system uses a three phase full wave
    rectifier bridge to change the AC into DC. You will find a .pdf file
    that shows a typical rectifier bridge at
    http://www.electrosport.com/electrosport_electrical_home.htm when you
    click on the technical links.
    If you have an ohmmeter, you can easily do the diode check, but you
    would need a variable voltage power supply to test the voltage
    regulating circuitry in the regulator.
    If one of the diodes is blown out, this reduces the power output of
    the alternator by half, for half a cycle. Blow out two diodes and the
    output could be anywhere from half power to almost nothing, depending
    on which of the six diodes is blown.
    In order to regulate voltage, this type of shunt regulator has a
    silicon control rectifier (SCR) hooked up between one pair of power
    diodes and there is a zener diode that senses when voltage rises above
    about 14.5 ~ 15 volts *with the regulator conected to the battery*.
    If you try to operate this system with the regulator output
    disconnected from the battery, the zener diode will continously tell
    the SCR to shunt excess current to ground and the regulator will get
    very hot when the engine is running.
    It's normal for an SCR or a diode to get *somewhat* hot when you run
    power through it, though. That's why the regulator is housed in a
    finned aluminum heat sink.
    But the charging system of a modern motorcycle is really designed to
    burn up excess power that isn't charging the battery by lighting the
    headlight and taillights, not by continuously shunting ALL the power
    to ground via the SCR.
    The best solution would be to avoid riding the motorcycle until the
    rectifier regulator is replaced.
    ., Nov 5, 2008
  8. loa13mbb
    . Guest
    I suppose you're speaking of some sort of electrical "imbalance", not
    mechanical imbalance. The magnetic fields inside a permanent magnet
    alternator just wouldn't be strong enough to move the windings.
    In a three-phase wye-wound stator, the phase rotation is A > B > C,
    with
    power returning from C > A, etc., via the power diodes.
    A blown diode just interrupts the orderly return of power to the
    following phase.
    The biggest 3-phase generator I ever worked on was one of the 250
    megawatt units at Boulder Dam, on the Colorado River.
    We secured the generator by isolating it from the circuit so it
    couldn't run as a motor, and closed the butterfly valve in the
    penstock and chained the wicket gates shut so water couldn't move the
    turbine.
    Then we crawled around inside the generator, looking for burned
    windings and windings that had been dislocated by the powerful
    magnetic fields inside the generator while operating.
    ., Nov 5, 2008
  9. Once again, you use your 'experience' of a particularly crappy design,
    that's now 30 years old, and think it applies to modern kit.
    You're full of shit.
    The Older Gentleman, Nov 5, 2008
  10. loa13mbb
    . Guest
    Eat it.
    ., Nov 5, 2008
  11. loa13mbb
    . Guest
    Curiousity led me to google up information on the BMW F650.
    It seems that it has a remote sensing lead coming from the ignition
    switch similar to a Honda.
    The extra voltage drop across this long lead causes the voltage
    regulator to
    think that battery voltage is higher than it actually is.
    So some technically minded owners figured a way to shorten the lead by
    adding a relay...
    http://faq.f650.com/FAQs/Photos/ElecPhotos/wiring1-1.gif
    http://faq.f650.com/FAQs/FlayingtheVRFAQ.htm#VR Flay I
    ., Nov 5, 2008
  12. loa13mbb
    . Guest
    Right. I was trying to post and cook pasta at the same time and got
    distracted. (1)
    The battery gets overcharged because the extra connectors and the
    ignition switch contacts and about six feet of small gauge wire keep
    the zener diode from triggering and the SCR doesn't shunt excess power
    to ground.
    The diodes also have to put up with excess voltage from continual
    charging and they tend to blow out.
    The F650 has a $250 OEM regulator...
    (1) Write that down, Older Gasbag, so you don't forget all the things
    I've said that displesed you.
    ., Nov 6, 2008
  13. All BMW parts come with those very special
    BMW prices.
    I took a quick look at my BMW parts CD and
    besides the regulator, they show a separate
    diode (part #s 61 312 346 432 and 61 312 346 465)
    Not sure what's up with that. Nice if you could
    really replace them separately. I guess the diode
    may not be for the main charging current though.
    Rob Kleinschmidt, Nov 6, 2008
  14. loa13mbb
    . Guest
    The protective diode is a logic diode that keeps current flowing in
    the correct
    direction. It's associated with a starter solenoid *enabling* relay,
    the neutral
    switch and the clutch lever switch.
    In this wiring diagram, green is hot when the ignition switch in in
    the ON position
    and orange is ground.
    The voltage regulator gets its voltage information round-aboutly,
    through the
    ignition switch, like a Honda VFR...
    ., Nov 6, 2008
  15. Nice find.
  16. loa13mbb
    . Guest
    Pssssst! Don't tell The Old Gasbag that I found the answer by googling
    the web. He thinks that's a sign of weakness...
    ., Nov 6, 2008
  17. Nice save - a decent design these days should be using a fully electronic
    regulator not a simple SCR jobbie, that would have full over and
    undervoltage
    protection. A DSP that does this is an off-the-shelf part that sells for
    maybe
    $1 OEM.
    I'm amazed the aftermarket hasn't come up with a replacement for that
    30-year-old discrete parts design from the Dinosaur age that you described
    in your earlier post.
    Ted
    Ted Mittelstaedt, Nov 7, 2008
  18. loa13mbb
    . Guest
    Can you give us part numbers for an American made 3 phase full wave
    rectifier bridge with a DSP chip in it? Most motorcycles would
    probably be OK with a bridge that can handle about 400 watts. Only a
    Gold Wingish land yacht garbage wagon would need more power.
    The motorcycle aftermarket thrives on the ignorance of the owner, and
    there are often international tariffs on foreign electrical/electronic
    parts driving the prices up to about three times what a domestic
    manufacturer would charge.
    ., Nov 7, 2008
  19. Not sure if you were talking about the $250 regulator for
    the PM alternator or the complete energized rotor systems
    from the earlier BMW boxers.
    This place offers a well regarded PM alternator replacement
    for the old energized boxer systems. This includes a thyristor
    based regulator which I believe costs maybe $125 sold separately.
    The whole system is based on one used in Ducs. I've heard
    of problems on Ducs, but on elderly boxers it's well thought of.
    http://www.euromotoelectrics.com/EDLBMW.html
    Rob Kleinschmidt, Nov 7, 2008
