damn rivetts
Discussion in 'UK Motorcycles' started by RJAG, Feb 26, 2005.
  1. RJAG
    RJAG Guest
    anyone got a suggestion of how to remove those plastic rivets that hold the
    seat unit onto an R1 for I need mine off.
    I cant see an easy way of doing it but if they make replacement underseat
    units then there must be an easy way.
    Robin
    RJAG, Feb 26, 2005
  2. RJAG
    RJAG says...
    You'll find the rivet is in two parts, an outer and a slim long plug
    that expands the outer when it is inserted. Push the centre of the rivet
    (plug) inwards from the outside and the outer will be easily removeable.
    Lozzo, Feb 26, 2005
  3. RJAG
    RJAG Guest
    damned fine of you sir. well that's the crawling bit out of the way and
    thanks a lot for I'd have written the bloody thing off if you hadn't helped.
    cheers again.
    Robin
    RJAG, Feb 27, 2005
  4. RJAG
    RJAG says...
    Who the **** are you replying to, and in what context?
    Lozzo, Feb 27, 2005
