DAB radios
Discussion in 'UK Motorcycles' started by Fr Jack, Jan 29, 2010.
  1. Fr Jack
    Fr Jack Guest
  2. Fr Jack
    Pure is a good start, IMO.
    I have one of these (as well as a Bug) and it is well under your budget:
    http://www.johnlewis.com/230503769/Product.aspx
    And I'm not sure it's as retro as you want.
    CT, Jan 29, 2010
  3. Fr Jack
    Andy Hewitt Guest
    I paid about £40 for a Pure Siesta clock radio last year. I'm pretty
    happy with that, although it ain't portable or retro. Sounds good
    though, and is USB updatable. The display is rather too dim though.
    However, doing the research, I think I'd stick with Pure or Roberts.
    Bush are cheap stuff, although the DAB they do seems quite popular.
    Personally, I think DAB isn't good enough to warrant spending too much
    on anyway. Sound quality is clean, but dire on dynamic range, and
    apparently the BBC do pinch some bit-rate from channels if there's a big
    event on another. I only got it because FM around here is even worse.
    Andy Hewitt, Jan 29, 2010
  4. Fr Jack
    Good points.
    And check that you can get a good DAB signal everywhere you want it
    first. I have to switch to using FM in the kitchen, as I can't get DAB
    in there.
    CT, Jan 29, 2010
  5. Fr Jack
    Fr Jack Guest
    Thought so...
    Looks like some PoS that sat in my kitchen, about 1988, replacing a
    rather nice Roberts R600, which was nicked.
  6. Fr Jack
    Fr Jack Guest
    How does a chap do that, without a DAB radio?
    Nobody I'm aware of has one I could borrow to check.
  7. Fr Jack
    Andy Hewitt Guest
    <Rock> - Fr Jack - <Hard place>
  8. Fr Jack
    crn Guest
    Just about any DAB radio is OK if you keep it plugged into the mains.
    Battery life is lamentably short on all of the damn things, typically
    around 4 hours for a set of 6 C size Duracells.
    crn, Jan 29, 2010
  9. Fr Jack
    Fr Jack Guest
    (Andy Hewitt) spewed forth:
    #A rock and a hard place await for me
    #Between the devil and the deep blue sea
  10. Fr Jack
    Fr Jack Guest
    spewed forth:
    I'm not likely to wander down the street with it on my shoulder...
    just move it from room to room, is all.
    I think your figures for battery life are out by a factor of 5,
    minimum. Reviewers are quoting 20 to 120 hours, depending on the
    model. Signal strength would be a factor, too.
  11. #Everything I ever did right or wrong
    #Hid out of sight where I belong, belong
    You're an (ex?) goth and ICMFP.
    Chris Bartram, Jan 29, 2010
  12. Fr Jack
    Fr Jack Guest
    Heh! Not an actual Goth, I just like the choonz...
    #Twenty-five whores in the room next door
  13. I name that tune in 1 (line).
  14. Fr Jack
    A.Lee Guest
    I would agree with him about battery life. I took my DAB radio to work
    with me, it lasted less than a day on 6 Duracell batteries (the next
    size up from AA - D?).
    I thought it was a duff set of batteries, so bought some more from a
    different shop, and it again drained them in less than a days work.
    It lives in the van now, with its mains lead, and only gets used if
    there is a power supply I can use.
    Alan.
    A.Lee, Jan 29, 2010
  15. Fr Jack
    crn Guest
    It seems that the latest models are getting a bit better but their
    battery life is still abysmal compared to an ordinary FM radio.
    crn, Jan 29, 2010
  16. Fr Jack
    Catman Guest
    FWIW 'C' actually.
    www.cuore-sportivo.co.uk
    Catman, Jan 29, 2010
  17. Fr Jack
    Beav Guest
    He's read those figures somewhere and they're now etched in his stone.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 29, 2010
  18. Fr Jack
    Colin Irvine Guest
    For that you could get a nice FM radio, which will probably sound
    better.
    Colin Irvine, Jan 29, 2010
  19. Fr Jack
    Fr Jack Guest
    But I'd still have to buy a DAB radio, eventually, no?
    If I was looking for a FM set, I'd most likely tour the boot sales and
    junk shops, to find a vintage job, TBH.
  20. Fr Jack
    Lady Nina Guest
    I'm getting the urge to go to WGW now. It will pass very quickly
    though.
    Lady Nina, Jan 29, 2010
