Cylinder Pinging
Discussion in 'Motorbike Technical Discussion' started by hE, Apr 11, 2004.
  1. hE
    hE Guest
    I've got an '03 PW50, about 6 months old, and about 50 hours riding time on
    it. About 3-4 weeks ago, I noticed a "pinging" or rattling noise coming
    from the cylinder. Thought maybe it was running too lean but it checked out
    OK. Then I thought it was the fuel so I switched to a 93 octane...still
    pinging. Compression checks at around 115-120 psi. I removed the head and
    jug and decarburized the piston crown and head and checked for signs of
    scoring....didn't find any. I'm out of ideas. Any suggestions greatly
    appreciated.
    hE, Apr 11, 2004
  2. I think what you've got is probably normal two-stroke
    ring-dinga-dinga-ding cylinder resonance.
    Many air cooled two-strokes had rubber bungs rammed between the fins to
    counteract it.
    The Older Gentleman, Apr 11, 2004
  3. .....don't look back.
  4. hE
    hE Guest
    No baffle, and the spark arrestor has been thoroughly cleaned.
    That's interesting. I've suspected the stroke on the oil injector pump
    needed to be adjusted down for some time now. I haven't done it because I'm
    afraid I'll get it too lean and seize. These &*^!@ oil injectors are a bear
    to adjust properly and even worse to try and measure. I didn't know about
    the dieseling though...sounds like I might need to bite the bullet and do
    it...or disconnect the pump and go premix...thanks for the suggestion.
    Another good suggestion. I'll check that out too.
    hE, Apr 12, 2004
