custom seats or seat mods.
Discussion in 'Motorbike Technical Discussion' started by Rob Kleinschmidt, Dec 20, 2007.
  1. I'm running a BMW R100GS with a slightly modified solo seat
    and am considering possible seat improvements.
    What I have now is a stock seat with a gel pad added and
    some foam rubber cushioning between the seat pan and frame.
    I'd modified the seat mount to allow a little bit of extra travel
    as the pan moves up and down.
    Right now, I'm good for 300-400 mile days but would like to
    increase my comfort level and distance abilities. It's also
    very important to me to be able to get a foot down occasionally
    for off-road riding, (29" inseam) so the seat has to remain
    fairly narrow and low.
    I think if I had my druthers, I'd start with a bare pan then build
    it up and tear it down a few times using different materials
    until I really got it right. Don't think I really have the time or
    money for a project of this scope however, so it needs to
    come out pretty good on the first try.
    Anybody done any mods themselves, used any aftermarket
    accessories such as Airhawk or had a custom seat made that
    they're expecially happy with ?
    Thanks for any thoughts on mods, shops or construction.
  2. Rob Kleinschmidt
    Mark Olson Guest
    I have a Russell Day-Long seat on my Concours. It's pretty comfy
    because it spreads the load out over a wider area. The shape is what
    makes it work, not the softness of the foam.
    How much do you weigh? Russell has a standard and a heavy-duty saddle,
    the heavy-duty one is for folks over 225 lb IIRC, and has a built in
    metal spring, whereas the standard saddle uses a plastic thingy to
    maintain the shape. I could be misremembering all this.
    I do remember what I paid, it was roughly $600 all in, including
    shipping. Not cheap but when you're on a multi-thousand mile 10 day
    trip you'd easily pay double that to make your butt-burn go away.
    Anyway, what you need for ultimate comfort is something like an shaped
    like an old-style tractor seat.
    http://www.keynamics.com/images/Contoured-Tractor-Seat.jpg
    Unfortunately that shape will work against you, with your short inside
    leg measurement.
    Lots of folks claim success having a local upholstery shop recover
    their saddles for cheap, using better foam, presumably also carved to
    shape. According to one person on the SV mailing list an electric
    carving knife is perfect for cutting seat foam. I still have a couple
    of large squares of very expensive Tempur-Foam that I bought for
    re-doing my SV's saddle which I haven't yet gotten around to doing just
    yet. If you do want to do you own seat building, 3M spray adhesive was
    recommended to bond the foam to the cover.
    Mark Olson, Dec 20, 2007
  3. What can you do to lower the whole bike? A Dakar certainly would have
    no exhaust pipe dragging problems.
    I had Hang2 cut down my GS1100 seat, they got rid of the annoying
    crotch pad and lowered the seat 2 inches, but that changed the
    relationship between the seat and foot pegs, making my hip joints
    ache.
    Otherwise the flat seat was good for 300~400 mile days, even though
    half the padding was gone.
    Buteo lineatus, Dec 20, 2007
  4. $600 for a Russel is about the most I could imagine paying,
    though I like the spring idea. Not so sure about the Russell
    butt wings though. Again, looks like it'd be hard to get a
    foot down to stop a slide. I go about 200 lbs. I thought all
    Russells used a spring seat.
    I'd toyed with the idea of a tractor type seat as still found
    (I think) on Urals, but shoehorning the spring mechanism
    into my frame without raising the seat heigh would be a
    littlle tricky. I could probably do it if I relocated the toolkit
    and/or battery.
    I'd already had a local shop add a gel pad to the stock
    seat a few years ago. This was before memory foam
    was popular. One think I could do, I guess, would be to
    bring it back and have them throw another layer of stuff in.
    I'd really wish I had a spare seat pan and the sewing skills to
    be able to bang out a cover myself. I ready made seat covers
    on eBay for ~ $45, but would need to have the seat shape
    figured out to know if they'd be a match. A new cover made
    locally sounds like the way to go.
    Not really clear how much seat comfort depends on shock
    absorbtion and how much on just getting a good contour to
    your butt and a nice even load distribution.
    Thanks for the ideas. I'll report back on anything I do.
    If you do the Tempur mods, please do the same.
  5. The bike's already lowered as much as I'd ever want it to be.
    Even with a bash plate, the underside takes more bashing than
    I'd like it to. I want to be able to do stuff like creek crossings
    and singletrack with it and still be able to exceed 300-400
    mile days comfortably.
  6. The bike is slightly lowered by a shortened Fox shock
    and tubes slid up in the yokes. This seems to have
    the effect of stiffening the suspension a little, though
    I haven't stopped to work this out on paper.
    Even with a full travel suspension, bumps at speed
    will be noticeable. Also, when you move around
    on the saddle.
    I think you're correct though that contour and contact
    are the major factor. On long trips, I'll try to remember
    to stand up on the begs occasionally. This seems to
    help quite a bit.
  7. Rob Kleinschmidt
    Seth Hammond Guest
    I'm troubled a bit by sciatica in my right hip and soles of both feet, so I
    worried some about comfort on a ride of 4,128 miles last summer, especially
    because there's almost no seating option on my Wing. My butt fills the seat
    with little movement allowed. So far as rider seat space is concerned, it
    could be a much smaller bike. The real comfort room is for pillion.
    Anyway, I was pleasantly surprised to suffer no discomfort whatsoever. I
    didn't even unfold the hi-way pegs.
    Seth Hammond, Dec 21, 2007
  8. I like his deposit/exchange plan for stock seats.
    I hate the idea of having the bike down while the
    seat's being worked on.
    As I understand it, Bill Meyer originally designed a
    spring based seat which was then sold to Russell (??).
    Bill eventually passed and his two sons, Rick and Rocky
    began a feudin' and a fightin', starting two competing seat
    businesses in Ojai and Redding, Ca.
    I've heard various reports about the two brothers and their
    businesses, but have never been able to keep them straight.
    I see Rick's the one near Redding.
    Thanks
    Rob Kleinschmidt, Dec 21, 2007
  9. Rob Kleinschmidt
    Snag Guest
    I see no one has mentioned Mustang ... had a Corbin on my '76 FLH that was
    good for about 500 miles/day . Last Mustang was on an '88 Sportster , and
    it was easily a 600 mile seat . The Mustang on my current bike isn't broken
    in yet , but I expect it to be good for at least 700-800 miles .
    Sheepskin (real only , synthetic sucks) helps , warmer in winter , cooler
    in summer .
    Snag aka OSG #1
    '90 Ultra , "Strider"
    The road goes on forever ...
    none to one to reply
    Snag, Dec 25, 2007
  10. Rob Kleinschmidt
    Wudsracer Guest
    In 1986, I had Corbin customize one of his saddles to the seat pan
    on my '81 XV920RH. I had met him at "The Great American Motorcycle
    Show" (as it was called back then) in Dallas.
    It worked so well that I promptly lost my sheepskin and other aids
    to help me live with the horrible stock Yamaha seat.
    Before the modification, fifty miles in the saddle would have my
    legs and butt numb and lower back screaming for relief.
    After the Corbin modification, I could regularly go past 200 miles
    before stopping for fuel (drink, bathroom break, etc).
    Fantastic seat!
    A couple of years ago, while I was speaking with Mike (owner of
    Mustang Seats) on the phone. I told him my "Corbin story".
    He laughed, and said the he was probably the one who did the
    modification of my seat, because he was working for Corbin at the time
    and was the one who did the modification of that sort.
    I sold a good many aftermarket seats during my ten years as a m/c
    dealer, and never had a complaint about the Mustang seats. (The only
    complaints I had about the Corbin seats were concerning the price.)
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Jan 8, 2008
