CT90 top-end rebuild - completed!
Discussion in 'Australian Motorcycles' started by BT Humble, Nov 20, 2006.
  1. BT Humble
    Here's the bike as it looked back in July (just unloaded off the
    truck):
    http://www.otherpower.com/images/scimages/236/ct90_2.jpg
    I decided that it would make a good paddock bike for my 10-year-old
    niece (she's a bit too tall for the "family minibike"). About $250
    later it has:
    * A functioning front brake;
    * A functioning ignition system[1];
    * A cleaned-out carburettor;
    * A new piston, rings, and 0.5mm overbored cylinder;
    * A sidestand.
    I had a bit of e-bay luck on some CT90 parts in Wagga which my uncle
    collected for me, $18 bought the correct seat[2], exhaust heat shield,
    front mudguard, spare forks[3], spare fuel tank, and centrestand. I've
    got a CT90 wreck at Tarago that still has a brake pedal and rod
    attached.
    It was interesting to learn that the fork oil seals can be bought from
    a bearing shop for $1.50 each, if you know the numbers for them.
    Amazingly it started on the first kick after reassembly. It runs in a
    very smoke-free manner until the exhaust pipe gets hot, which is full
    of oily muck due to being run with a broken compression ring and
    worn-out oil scraper ring[4] for Quite Some Time. The exhaust port was
    about 25% smaller than it should have been, due to a thick layer of
    oily, sooty goo.
    And yes Pat, as a matter of fact I *DID* check the bolts on the
    camshaft *VERY* carefully!
    [1] I recycled the old ignition coil & condenser from my truck, and a
    suitable 6V battery for $14 from Jaycar.
    [2] It has the narrow seat of the first k0 model, where it should have
    the current CT110 wide one.
    [3] In case the fork sliders on it are too rusty to fit new seals to.
    [4] The "wear limit" for the piston ring end gaps is 0.5mm, the
    unbroken ones were about 5mm.
  2. Bastard!!
    Pisshead Pete, Nov 21, 2006
  3. BT Humble
    When I see her tomorrow, I'll tell my mum that you said that.
    Boy oh boy, are YOU gonna be in trouble! >:-D
    BT Humble, Nov 21, 2006
  4. Heheh. You may very well be surprised, BT!
    Pisshead Pete, Nov 22, 2006
