[QUOTE] That could be a few tight spots here and there, or just plain crud sticking the links in various places..[/QUOTE] There's loads of crud on it. If I had a bath full of acid I'd quite happily throw it on. The amount of gritty crap I got off of my hands earlier on was astounding, and I didn't even touch the chain much. [QUOTE] Try using some chain lube, ride for a while, check the situation again and tighten a little more.[/QUOTE] I 'wash at it' and then lube it up ever 500 miles or so, that's about once a week. [QUOTE] If you imagine the chain as a straight line between the bottom of each sprocket then about half to three quarters of an inch movement from that centreline when you push the chain in the middle up or down would be about right.[/QUOTE] After I took the video on my phone I turned off the engine and moved the chain up and down - it looks like its within the specified range. Earlier on I did the "20 <something> measure" and it wasn't outside the maximum - had about 15mm before it moved out of what the manual describes at the servicable zone. [QUOTE] Others may disagree so check the HBoL. If in doubt have a "Man" look at it.[/QUOTE] The last chain was replaced by the previous owner at 10,000 miles. I'm ever so slightly heavier than he, and it's done 8,300 miles. Should I just get it replaced now? (next payday) Is it likely to be an expensive job to have a man replace it (How much is a chain, and does it take an age to fit and tension) and I suppose I could get said Man to buy/fit Scottoiler too.
