Crashed my bike :(
Discussion in 'UK Motorcycles' started by BGN, Apr 15, 2005.
  1. BGN
    Dan White Guest
    I could be wrong here, but you may be able to weasle out of paying this.
    When my mate had his car nicked last year, the coppers told him where it
    was. He asked them to leave it there, and he would pick it up at the end of
    the day. Got there to find that it had been removed to a recovery yard
    against his request. Refused to pay bill, got car back anyway.[1]
    You could argue that you asked the police to leave it by the side of the
    road so that you could arrange your own recovery. Spend the money you save
    on a better jacket for next time :)
    [1] There's more to it, but it really requires telling over beers. Suffice
    to say, if you ever see a "Hinton Rescue" van coming to pick up your
    vehicle, just set it on fire and claim the insurance. It'll be a lot less
    hassle...
    Dan White, Apr 16, 2005
  2. BGN
    Dan White Guest
    Sawing the Elton John CDs in half?
  3. BGN
    frag Guest
    BGN scribbled:
    Sorry to hear about your off Nick, but bones and things are OK which is
    what counts :)
    Looking at your pics what I'd do is check no pipes are damaged coming
    from petrol tank (i.e. see if you can work out where it came out) and
    if thats safe then drill couple of holes to let you put two long bolts
    in where right footpeg was (maybe just unbolt whats left of existing
    one if brackets not snapped) and rear brake (if you CBA about the
    brake), plug the plug back into the rev counter, wash off the worst of
    the mud and ride it home.
    Check the headstock carefully first though, the forks don't look bent
    to me but I'm wondering if the headstock is smashed? Check brake levers
    and things beforehand obviously, and with engine running turn bars from
    lock to lock to ensure throttle cable isn't fecked, and have a little
    pootle round the yard to see if the bike feels normal or odd.
    With any luck you'll need right peg, rear brake pedal, right brake
    lever & mirror, the bracket for the clocks/light unbending, surround
    for the headlight maybe, rear cover for speedo & rev counter, right
    front indicator. And might need new master cylinder for front brake.
    It'll look 10 times better once you've washed the mud off, trust me.
    frag, Apr 16, 2005
  4. The Older Gentleman, Apr 16, 2005
  5. BGN
    MattG Guest
    BGN said...
    You're still in one piece and walking, so that's a good thing.
    Bit of gaffa tape round the clocks and it'll be fine. My old lid was
    worse than that, it was fine - you just had to turn your head a bit
    further to see what was coming from the right.
    MattG, Apr 16, 2005
  6. BGN
    Catman Guest
    ROTFL
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS
    www.cuore-sportivo.co.uk
    Catman, Apr 16, 2005
  7. BGN
    The Older Gentleman emerged from their own little world to say
    Read the OP again. Saw mud, stared at mud, finished up in mud.
    wessie, Apr 16, 2005
  8. BGN
    SP Guest
    Inexperience?
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Apr 16, 2005
  9. BGN
    BGN says...
    I reckon 2-300 quid will see that bike back on the road again. Another
    couple of hundred will have it back to sparkly. If the forks are bent
    then you can have them straightened. It cost me 35 quid to have my
    GPZ500 ones done and they were obviously bent. Even if they are bent
    and no-one locally will straighten, forks come up on eBay quite
    regularly and new stanchions from Kawasaki aren't as expensive as folk
    think. From what I can see there, yours may just be twisted in the
    yokes. The rest looks pretty good, new brake lever/pedal, possible set
    of handlebars, headlamp shell/rim/bracket and an indicator should see
    you back on the road with the rest left a bit scruffy.
    Get the bike home, and then give it a bloody good and sympathetic clean
    down, making sure you don't grind mud and grit into the paintwork. A
    powerhose will help there. From then on you can get further advice from
    Cheritons or Alfords about what bits need replacing/repairing and what
    you can live with as scuffed up. Radiator looks fine, which is a bonus,
    as is the waterpump. The major damage is to the clocks, but they are a
    little fragile on ER-5s. Buy a used set from a breakers or eBay and
    save a fortune.
    You got off lightly and those engine protectors did their job well,
    keep them.
    If that's all the damage to the helmet then I'd just buy a new visor,
    or a new Nitro :). Considering the battering your jacket took, I
    wouldn't rule out buying the same again. A 60mph slide down the road
    will shred any cordura material and lets face it, you aren't the
    smallest of people so it will have been a fairly heavy impact with the
    deck. If you want more in the way of protection from this sort of
    thing, buy leathers. Corduara will keep you dry and warm, but don't
    expect too much when it comes to crashing.
    Email me if you need any advice or need to source parts.
    Lozzo, Apr 16, 2005
  10. BGN
    jsp Guest
    Lady Nina wrote:
    Self harm has never been an attractor for me.
    John
    SV650
    Black it is
    and naked
    jsp, Apr 16, 2005
  11. BGN
    jsp Guest
    BGN wrote:
    It's a bit ditrty, mate.
    Muck off and water and it'll be as good as new.
    John
    SV650
    Black it is
    and naked
    jsp, Apr 16, 2005
  12. BGN
    They look a little bent to me. I bent the forms on my Bandit, and got
    them straightened again. The old biddy who pulled out on me payed
    though,
    Maybe. Being mindfull of the forks not being quite right.
    Muck, Apr 16, 2005
  13. BGN
    JackH Guest
    Lucky him... a couple of years ago, I had one nicked on the Sunday
    evening... spent the Sunday, Monday and Tuesday nights flying about in my
    other car (1) looking for it in places in the local area famed for being the
    favourite strip out and / or 'rag the tits off it' locations of the local
    toerag community, only to receive a phone call on the Wednesday lunchtime to
    say that it had been recovered on the Monday afternoon, and was in storage
    at a local recovery place.
    I refused to pay anything other than the actual recovery charge, which they
    accepted without too much of a squabble... hardly surprising, since they
    were getting over £100 for plucking said car out of a field within 3 miles
    of their premises.
    I laboured this point with Kent Police, who stated their policy was to get
    the car recovered, then inform you of where it had been recovered to, to
    ensure it didn't go walkies in the time it took between them informing you
    of where it was, and you getting there.
    In other words 'we don't give a ****, we just want to wash our hands of it
    asap, regardless of whether or not you could actually get here relatively
    quickly if we just rang you...'
    (1) Car pinched, was a Nova GTE... my other car at the time, was a Senator
    24v... and I had every intention of ramming the little cunts into a tree, if
    I'd seen them driving it - a fitting end, to two of Vauxhalls finest, I'm
    sure you'll agree.
    JackH, Apr 16, 2005
  14. BGN
    Christofire Guest
    That's gone and done it. Best of luck.
    Christofire, Apr 16, 2005
  15. BGN
    Christofire Guest
    Also, when I got knocked off at ~45mph in a belstaff padded
    "pro-biker"[1] it didn't hole, and resisted abrasion quite well.
    Melted in parts, but generally held together.
    [1] obviously not
  16. BGN
    Christofire Guest
    Me neither, but it's best not to rely on it as a method of keeping your
    bike upright.
  17. BGN
    Dan L Guest
    Heh, I'm now too worried to take the bike out.
    Think I'll just stick to polishing it :)
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    Dan L, Apr 16, 2005
  18. BGN
    Christofire Guest
  19. BGN
    Monz Guest
    Monz, Apr 16, 2005
  20. BGN
    Christofire Guest
    Kinnel. Are the Lib Dems in already? Free motorbike with every degree?
