Crashed my bike :(
Discussion in 'UK Motorcycles' started by BGN, Apr 15, 2005.
  1. BGN
    For BMW, 1969. Up until then, the boxer engine had a built-up crank and
    roller bearing big ends, and a camshaft above the crank. On older BMWs, and
    any Russian, Ukrainian or Chinese boxer (heh), you'll see that the pushrod
    tubes are on top of the cylinders. On /5 and later airhead BMWs, they're
    underneath. BMW had turned the engine upside-down and put the camshaft
    under the crank, changed the crank to a one-piece effort with shell bearing
    big ends, and employed the conrods from their car engines. This gave them a
    much stronger engine, capable of handling the big increases in capacity and
    horsepower that were to come, and that would remain essentially unchanged
    for a quarter of a century.
    As far as I can discover, the shell bearing big ends and solid crank
    appeared on Dneprs in 1971 with the MT9 (which is what sweller's got).
    Apart from this, the engine was pretty much the same as before.
    Roller bearings are simply wrong for a big end. Even if the crank rotation
    was constant, the relative angle of the conrod changes through every
    revolution, so the rollers are never at a constant speed and tend to scuff
    if the lubrication is at all suspect.
    platypus, Apr 21, 2005
  2. BGN
    sweller, Apr 21, 2005
  3. ROFLMAO
    The Older Gentleman, Apr 21, 2005
  4. BGN
    Champ, Apr 21, 2005
  5. BGN
    PeterT@Home Guest
    Bear proposed
    I'd say it truly deserves the Carmicheal award for photography.
    PeterT@Home, Apr 21, 2005
  6. BGN
    petrolcan Guest
    the cont known as PeterT@Home says...
    petrolcan, Apr 21, 2005
  7. BGN
    It's like being there but without the pain.
    sweller, Apr 22, 2005
  8. BGN
    rb Guest
    rb, Apr 22, 2005
  9. BGN
    BGN Guest
    I can't stop looking at it. I must have been there 30 times so far.
    BGN, Apr 22, 2005
  10. I am impressed by the lack of damage to the rider's clothing, which
    appears to be constructed by some form of multi-layer fibre
    construction encompassing the rider's entire body. Furthermore, I have
    not seen quite such a pink set of motorcycle clothing since the days of
    the Fieldsheer "acid worm" suits in the late 1980s/early 1990s.
    The decelleration experienced in the accident does appear to have
    caused some peculiar
    and potentially disabling eye injuries, however.
    Paul Varnsverry, Apr 25, 2005
  11. BGN
    BGN Guest
    Sorry to resurrect this old dead thread, but as the ER-5 is in for
    it's 15,000 mile service tomorrow will they look at the headstock
    (steering pin?) as part of the service, and if not:
    (Yes Bear, this *is* a clueless question)
    If the headstock/steering pin was damaged when I crashed it in April,
    would I have noticed it in the last 1,500 miles? Would there be any
    obvious signs, like the bike splitting in two that I would have seen?
    If it's look at as part of the service, then that's just fine, but if
    it's not then I'll put it on my "Please also look at" list that I'm
    giving them tomorrow.
    BGN, Jun 2, 2005
  12. They will probably check the steering head bearings.
    It takes a *huge* impact to destroy a steering head. It's one of the
    strongest bits of the bike.
    Just ask them to check the head bearings.
    The Older Gentleman, Jun 2, 2005
  13. BGN
    BGN Guest
    On Thu, 2 Jun 2005 21:34:49 +0100,
    Thanks for your help.
    BGN, Jun 3, 2005
  14. BGN
    zymurgy Guest
    When fio lobbed her CX, I had the dubious pleasure [1] of seeing not
    only a fucked steering head, but also a seriously split lid.
    Cheers
    Paul.
    [1] Also the time where fio got the dubious pleasure of meeting Donald
    in her tent :)
    zymurgy, Jun 3, 2005
  15. BGN
    Ben Guest
    I ripped most of the lock stop of my FZR when I crashed it. Amazingly
    there was no damage to the forks or headstock. Just had a new one
    alloy welded on and part-ex'd it for the SV.
    Ben, Jun 3, 2005
