Crap fuel :-/
Discussion in 'Australian Motorcycles' started by Bob Milutinovic, Oct 21, 2005.
  1. Filled up a few days ago at a newly opened petrol station; they had a
    variety of "Ethanol-ised" fuel available, but I opted for the more
    traditional (and more expensive) regular unleaded.
    Sadly, it must've contained something other than just normal fuel; from a
    few kilometres down the road 'til now, the bike's been behaving rather
    strangely. Reduced power, then loud rattling (backfire with every
    revolution?) from the air filter.
    Refilled a couple of times since then with known-good fuel, and the problem
    appears to be abating, but at this rate it looks like it'll take another 4-5
    tankfuls to clear the problem up (assuming the engine doesn't destroy itself
    in the meantime).
    Lesson learnt, never be tempted to save a few cents by buying petrol from a
    dodgy servo.
    - Bob.
  2. Hi Bob,
    Dunno where you hail from, but could you give us the name & address of
    the servo as I'll be on the road in the van for 3 days and I don't
    want to buy dodgy fuel.
    Kind regards
    Dave Milligan
    Dave Milligan, Oct 21, 2005
  3. Bob Milutinovic
    Nev.. Guest
    If you've already diluted the fuel with several tanksful of different
    fuel, and the problem only 'appears to be abating' then you either need
    to clean your fuel system - check the fuel filter and put in a tankful
    of Optimax - or look for the cause elsewhere - maybe something
    electrical?
    Nev..
    '03 ZX12R
    Nev.., Oct 21, 2005
  4. Bob Milutinovic
    yub Guest
    I'd pull out your spark plugs and give them a good clean
    If that doesn't work and its an 03 R6 it could be the coils. Had to replace
    all 4 of mine :-(
    yub, Oct 21, 2005
  5. Sloptimax!!!!!
    Never will I put that in mine.....
    Go Caltex ---- Vortex or higher octane... Put in some 98% octane ... and
    hopefully that will fix.. your problem sooner...
    Mark Donoghoe, Oct 21, 2005
  6. Bob Milutinovic
    Jason Woods Guest
    I've heard the tanks in stalled underground at service stations come shipped
    with a coating of oil to protect them from the elements during
    transport..... this oil mixes with the fuel and its best to avoid new
    service stations for that reason.
    Have no idea about how much truth is in that, but I guess your helping me
    realise there might be a lot of truth there :)
    All the best with getting your bike back the way it was.
    JasonBW
    Jason Woods, Oct 21, 2005
  7. Bob Milutinovic
    justAL Guest
    First things first.
    You need to clean out your fuel system and not try to dilute it with 4-5
    other tankfulls hoping that will make it go away. Sure the fuel might have
    been "dodgy" but what was making it dodgy in the first place? They usually
    don't come shipped like that.
    And seeing I don't work for the tech department of a large petrochemical
    company anymore...."You're a fuckwit" thinking it will just 'go away'.
    justAL
    ----- Original Message -----
    Newsgroups: aus.motorcycles
    Sent: Friday, October 21, 2005 4:38 PM
    Subject: Crap fuel :-/
    justAL, Oct 21, 2005
  8. ....not if it's n-octane.
    98%? Wow, I hope you didn't pay much for that!
    Hammo
    Hamish Alker-Jones, Oct 21, 2005
  9. Bob Milutinovic
    Nev.. Guest
    Optimax allegedly has the highest %age of detergents of any of the fuels
    (we want to clean out the fuel system right?), and works just fine in
    motorbikes as long as you don't leave them sitting in the shed for weeks
    on end unused, and the OP has refuelled several times since the bike
    started playing up, so may be either the worlds worst procrastinator
    when it comes to posting questions for help on usenet, or more probably,
    uses the bike regularly. If you think that the problem can be fixed
    merely by increasing octane wouldn't it be a better solution to buy a
    drum of avgas rather than pissing about with sub-100 RON fuels?
    Nev..
    '03 ZX12R
    Nev.., Oct 21, 2005
  10. Penrith region, outer West of Sydney. The servo is the new "Prime" Westbound
    on the Great Western Highway, about 2Km West of Mamre Road (adjacent to the
    new industrial complex).
    - Bob.
    Bob Milutinovic, Oct 23, 2005
  11. Ok, I'll accept that, considering you're one of the few who actually
    wrote "you're" rather than the "your" I see too often in newsgroups! :p
    I was actually specifically warned _against_ higher octane fuels by the
    mechanic, as being a "traditional" carburettor-fed bike, there're no
    electronics to adjust the firing to accommodate the different fuel
    properties. So given that I'm looking at cleaning the fuel system, what
    would you recommend? Obviously replacing the filter would be a good start,
    but what else? Drain the tank 'n flush it with something? With what?
    - Bob.
  12. Get another mechanic.....
    Regards, Andrew.
    Andrew Puddifer, Oct 23, 2005
  13. Bob Milutinovic
    Nev.. Guest
    There's a reason why he's working as a mechanic and not as a
    petrochemical engineer...
    Nev..
    '03 ZX12R
    Nev.., Oct 23, 2005
