Cracked case and roadside repair ?
Discussion in 'Motorbike Technical Discussion' started by Rob Kleinschmidt, Jun 11, 2007.
  1. Funnily enough, chewing gum will plug a hole in a fuel tank, as it's
    petrol-proof. Really.
    (Any flavour will do)
    The Older Gentleman, Jun 12, 2007
  2. Rob Kleinschmidt
    C. Deforrest Guest
    Same here, and I have actually used it for this very purpose after
    some chain - engine case interaction, resulting in a pencil-eraser-
    sized hole. Clean the oil off, cram that stuff on there, let it dry &
    you're good. Actually held for a couple years before the leak became
    really irritating.
    I keep some in my tankbag, just in case.
    Can't remember the name of it, either! Found it at the local autoparts
    store. It's a metallic-y sort of play-dough...definately thicker than
    JB-Weld. Knead it til it gets warm, and squish/smooth it into the
    desired area. Cant recall drying time..
    -Chris
    C. Deforrest, Jun 12, 2007
  3. Rob Kleinschmidt
    sqidbait Guest
    Please surrender your Possum Lodge membership card.
    -- Michael
    sqidbait, Jun 12, 2007
  4. Rob Kleinschmidt
    Thumper Guest
    No, my Brits' don't leak (much).
    Thumper
    Thumper, Jun 12, 2007
  5. what bout silicon
    aint those instant gasket glue-y thingys made out of silicon?,only
    they hold up to the heat, i mean they use it for gaskets
    silicons not hard to get hold of, and with the solvent stuff in it to
    apply it, it probably wouldnt care bout the oil either when you stick
    it, and it dont take that long to dry out
    metal_flowboard, Jun 12, 2007
  6. with the solvent stuff in it to
    Want to bet?
    chateau.murray, Jun 12, 2007
  7. I'm a life member, as such no one will mention exactly how I earned the lifetime
    status. The wife and son have a membership each.
    Lifetime accomplishments and a couple truly spectacularly useful uses earn these
    things.
    Keith Schiffner, Jun 12, 2007
  8. This is a bit worrying, really. I used it only recently to patch a small
    hole in a silencer.
  9. Rob Kleinschmidt
    Mark Olson Guest
    Belzona?
    Mark Olson, Jun 12, 2007
  10. hey i didnt say it wouldnt
    just said it probably wouldnt
    and in anycase i still think the point stands, that even if you have
    to clean it up a bit first, the silicone will plug the hole
  11. You star. Although I've got a clone version.
  12. Oh yes, but it has to be surgically clean.
  13. If I were in your place, I'd post the 'feminie hygiene products' you
    use, once, er, used, back to the manufacturers, and say you have a
    problem and they haven't cleared it up.
    I'd *love* to see their replies.
  14. Rob Kleinschmidt
    ottguit Guest
    Bubble Gum held for a quite a while for a hole in my Jeep's gas tank!
    It was a long time ago and I might have put some silicone seal over it
    when I got some.
    Bg
    ottguit, Jun 13, 2007
  15. Rob Kleinschmidt
    badaztek Guest
    What I find impressive is what some of those guys did back in World War
    2 to keep alot of those vehicles moving is almost border line genius or
    insanity ,sometimes it's tough to tell the difference .
    badaztek, Jun 13, 2007
  16. Rob Kleinschmidt
    noone Guest
    JB Weld.
    noone, Jun 13, 2007
