Covering the brake
Discussion in 'UK Motorcycles' started by Pip, Jul 8, 2004.
  1. Pip
    Verdigris Guest
    You and Bear.
    Verdigris, Jul 10, 2004
  2. Pip
    Verdigris Guest
    On Fri, 09 Jul 2004 11:56:20 +0100, steve auvache wrote:
    Just the thought of it does it for you, eh?
  3. It was somewhere around Barstow, on the edge of the desert, when the
    Ah yes, the 'oh shit' factor which is a vital component of all good
    maintenance scheduling.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jul 10, 2004
  4. Pip
    Ben Blaney Guest
    In this instance, I'll not take offence at that. I have no problem
    with holding up humbug as humbug.
    Ben Blaney, Jul 10, 2004
  5. Pip
    There you go, then.
    I can foresee problems here - all that constant curling and covering:
    you'll have arthritis in yer digits before you're 50.
    Pip, Jul 10, 2004
  6. Pip
    Pip says...
    Not long to go then?
    Lozzo, Jul 10, 2004
  7. Pip
    Thanks, Mr. Murray.
    Pip, Jul 10, 2004
  8. Pip
    Verdigris Guest
    Get some heated grips. And maybe some handle-bar muffs.
  9. Pip
    Pip says...
    It's my speciality :)
    Lozzo, Jul 10, 2004
  10. Pip
    Verdigris Guest
    Spoilsport.
  11. Pip
    Sorry, but I can't accept that. I'd refer you to darsy's reference to
    'muscle memory', earlier in the thread. I only ever use two fingers
    to brake with. My brakes may not be maintained to the highest
    standards, but they have always been effective when used with two
    fingers ... they may have needed a couple of squeezes from time to
    time in order to wake the pistons from their slumbers, but I can
    always exert enough force with index and second finger to make the
    rear wheel light.
    Pip, Jul 11, 2004
