Covering the brake
Discussion in 'UK Motorcycles' started by Pip, Jul 8, 2004.
  1. only you would pick up on this sort of distinction. ;-)
    Paul Corfield, Jul 9, 2004
  2. Well I recognise all of that but I have found myself covering the levers
    when there is no practical reason so to do.
    Probably the thing I'm most scared of and have practiced least. I really
    have no idea how hard I can safely brake on any of my bikes.
    my brain still dissolves when trying to understand countersteering. I
    simply rely on the fact that I manage to get round corners OK. Oh and Mr
    Cordon did a little evaluatory exercise on this subject and I passed
    with no problems whatsoever - therefore I must do it and do it OK. Just
    don't ask me to explain.
    I am worried - you've agreed with just about everything I wrote. I think
    that is definitely a first.
  3. Pip
    Ben Blaney Guest
    It's one of my strengths.
    Ben Blaney, Jul 9, 2004
  4. Pip
    Salad Dodger Guest
    Two answers:
    1) indeed, I really *need* that kind of pressure. :)
    2) heh. :)
    3) quite: having commuted, without major mishap[a], to Central London
    for fecking ages, I need some out-of-town, up-themselves, know-it-all
    to tell me how to do it. Monday's run, feet-up, took 12-13 minutes to
    cover 6 miles, all in the 30mph limits, without stopping. That said, I
    have no doubt whatsoever that some IAM observers would take great
    delight in telling me where I was going wrong.
    [a] Z750/GPO van interface in '83 notwithstanding. In mitigation, I
    was 21, and in a hurry. Not a good combination at 8:15 on Blackfriars
    Bridge Rd.
    | ___ Salad Dodger
    |_\_____/_| ..66073../..15556.../.Going./.Going
    \|^|/ ANORAK#17
    '^' RBR-Visited:35 Pts: 705 Miles:2429
    Salad Dodger, Jul 9, 2004
  5. Pip
    That's either an upper middle class euphemism, or a frighteningly
    accurate description of Simes.
    Or both, perhaps.
    Pip, Jul 9, 2004
  6. Pip
    I exist only to serve.
    platypus, Jul 9, 2004
  7. Pip
    Owen Guest
    The IAM view on filterring speeds backs up Porl or whoever it was that
    said they don't do more than 15mph faster than the traffic...
    Erm, I seem to have oversnipped...
    Most certainly not...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jul 9, 2004
  8. Pip
    ... and the time before that, chin-nuts.
    Pip, Jul 9, 2004
  9. Pip
    Stonge Guest
    I travel great distances (ish) in 3 vehicles, cage, bike and push-bike...
    It's amazing how your brain does the right thing in an emergency on each
    without any concious thought.
    Stonge, Jul 9, 2004
  10. Pip
    Certainly. Is Sir pre-cannulated, and has Sir any preferences as regards
    mean drip transient time?
    platypus, Jul 10, 2004
  11. Pip
    It isn't the force that I use as an indicator - it's the number of
    pumps required before something apparently happens ...
    Pip, Jul 10, 2004
  12. Pip
    Pushbike for you soon, then.
    Why dangerous?
    This is a serious question, and a point I expected to come out
    earlier.
    Because I habitually ride with two fingers resting flat on the brake
    lever, do I have less control over the direction of the handlebars,
    which I move about with pressure from the heel of my hands when on the
    move?
    Is your concern regarding safety due to the increased chance of
    involuntarily grabbing a handful in an inappropriate moment?
    I have an open mind on the subject; I'm looking to learn, and in the
    process, due to asking the question in an open forum, encourage others
    to ask themselves similar questions about their riding habits. I'm
    quite comfortable riding with extended fingers, although when the
    Suzuki vibes get to me and my little and third fingers go numb I do
    move my hand about until the familiar pins and needles recur.
    I don't use the brakes (IMHO) overmuch, or particularly hard unless
    pushing on, when late hard braking in a straight line is the order of
    the day. Thinking about it now, I consider that when I am "pushing
    on" (this is a relative term, applicable to my comfort zone and not as
    quick as some, but quick enough to generally hold my own (f'naar))
    that the bike is happier and that I have more consistent control by
    leaving my fingers on the brake lever.
    Scenario: charging up to a corner, apply a good handful of front
    brake, drop a cog most likely, release brake and tip in. Push the
    inside bar, pull the outside bar, roll the throttle on all the way
    round the corner, WFO as the bike comes upright. Index and second
    fingers still on the brake lever all the way. Actually, this is not
    true. The fingers over the lever may wave around in the breeze a bit,
    mid-corner. I wouldn't/couldn't brake when committed in this way in
    any case. Hah!
    All I need to do is squeeze, hold, release and relax the fingers. You
    and others apparently have to retract your fingers and curl them down
    inside the lever and round the grip. I appreciate that you do this
    without thinking about it hundreds if not thousands of times, each
    time you go out and so are well practiced. I don't think that my
    directional control or stability are adversely affected by my method -
    in fact, quite the reverse. This applies in spades in Winter, when
    wearing bulky gloves - this is one reason that I habitually rest on
    the brake lever, after a couple of fumbling incidents when wearing
    Pathan Lobsters.
    In the case of an unexpected hazard popping up, I am firmly of the
    belief that the fraction of a second saved by not having to get
    fingers on the lever could be vital in at least reducing the
    seriousness of the situation, if not avoiding it completely. I would
    further suggest that in such a case, a non-brake-coverer would
    instinctively go for the brake with all four fingers, "grabbing a
    handful".
    IME "grabbing a handful" badly affects the stability of the bike.
    Sudden removal of the four fingers from the twistgrip and transferring
    them to the brake lever is likely to cause a wobble. Heaving the
    lever towards the bar causes massive fork dive - which to an
    unbalanced bike is pretty serious. I'm no Riding God and I think my
    way is safer for me - and safer for the majority of others, too.
    I'm still a newbie at this, see - despite my grey hairs, I don't have
    the decades in the saddle that a lot of people here have. I came to
    bikes comparatively late in life, despite a promising start which was
    abruptly curtailed by the death of a friend on a bike I'd sold him and
    the consequent parental pressure to move to four wheels. I still
    managed to do a few things on and with bikes and bikers that my
    parents would not have approved of (an inverted wheelie largely off
    the pillion of a bike going up Westgate Hill springs readily to mind)
    but cars were my bag for many years.
    I have, in my defence, done _lots_ with cars: rallying on tarmac and
    loose surfaces, racing on tarmac circuits; banger racing on shale.
    I've done vehicle repair and recovery and driven thousands of miles
    towing overloaded trailers. I've done race schools, rally schools,
    advanced training and all sorts of naughtier stuff. I wish I'd had a
    bike earlier, because it had made me a better driver - certainly WRT
    respect for other road users (and lack of it), planning manoeuvres and
    anticipation.
    Now, the bike is my main transport. Frequently for convenience in
    getting through traffic, often for the sake of higher average speed; I
    take the bike by choice. Quite often, there is no choice - the car is
    required elsewhere, so I must take the bike. I do a considerable (by
    my standards) mileage bike-borne every year, much more frequently for
    purpose rather than pleasure. And I fucking love it ;-)
    I'm quick enough for me. I don't anticipate getting much quicker, I
    can at least hold my own with 90% of people I ride with or meet on the
    road. I have yet to acquire the depth of experience which allows a
    lot of you to do the things you do and get away with it. By the time
    I acquire that experience, I'll be too old to use it. Life's a bitch.
    I can't afford to do advanced training or track days. uk.r.m. taught
    me how to ride, how to filter safeishly, how to countersteer and how
    to get through traffic. Now I want more. I want to know how to
    improve, become smoother - and perhaps even a little quicker: but
    really I just want to be better.
    Ever since I was a little kid, I've (wanted) to take things apart to
    find out how they work. Sometimes, I have been less than successful
    at putting them back together again. Now, I'm a half-decent
    mechanic-cum-bodger and reassembly is frequently the reverse of
    dismantling. So I'm not that concerned about taking my riding apart
    and having a look at it, IYSWIM. I do like to analyse things - it's
    part of my anal makeup ...
    On braking - I'm not a heavy user of brake pads. In fact, the RF is
    the first bike in my ownership on which I have had to change pads.
    The MOT tester warned me last year that the (EBC HH) pads were low and
    needed replacement. This year, he made the same warning and I
    couldn't tell him that it was the same set with another 10k miles on
    them.
    Front tyres - I don't wear them rapidly. Probably 9k miles from a
    front 020, which isn't bad for a heavy bike like the RF. They mark up
    all the way to the edges and wear out on the shoulders rather than in
    the centre, which indicates to me that I'm probably braking into
    corners when banked over. I certainly drag the front a bit when
    pushing on, which brings me back to my initial point ... in that I
    consider re-curling my fingers round the grip by the point at which I
    release the front brake would unsettle the bike to an unacceptable
    degree.
    So, if there's anybody who has got down this far - what do you, the
    jury, reckon?
    Pip, Jul 10, 2004
  13. Pip
    As usual Mr. Sweller, you are the exception to the rule. Do you cover
    the pedal, then?
    <VBG>
    Pip, Jul 10, 2004
  14. Pip
    TBH, not consciously. The rearsets place the pedal under my foot but I
    don't "cover it" in the context being discussed.
    It's no laughing matter they're awful. A good 1/2 - 2/3 of travel is
    slack. I really need to buy <shudder> some new brake shoes.
    sweller, Jul 10, 2004
  15. Pip
    I wear both pads (10K) and tyres (4K-5K) quite quickly. The Guzzi is a
    heavy bike with a lot of unsprung weight (although that has been
    drastically reduced of late) and I do ask a lot of it.
    Brake pad wear is heavy because the bike was underbraked for what it was
    asked to do and the cast discs when rusty (which they do very /very/
    quickly) can't do pad wear any good.
    I'd be interested in seeing how pads last with the new bonkers four pot
    brembos.
    I don't think I can really comment as I've not owned a modern machine and
    the Guzzi gets ridden at the "mercilessly" end of the spectrum.
    Never changed any pads or shoes on an MZ.....
  16. Pip
    Furry muff. I'll mark your card appropriately ;-)
    My idol has feet of clay. Surely you mean "reline the shoes with
    several layers of the Morning Star" - although I understand that
    Socialist weekly does provide superior retardation in wet conditions
    at the expense of ultimate longevity ...
    And anyway, I rode the RF through most of Winter without any rear
    brake at all (due to a maladjustment that I don't want to go into,
    ahem) and with between two and three pumps on the front to gain any
    useful braking. Having said that, I suspect your riding is a) more
    urban and b) more committed than mine.
    On reflection and having seen you ride the Guzzi, I think you should
    be committed on that basis alone. For everyone's safety.
    Pip, Jul 10, 2004
  17. Pip
    new euphemism for "untidy"
    It's got working brakes now...
    Which sort of explains my ideology of not touching the brakes, nothing to
    do with smoother, better thought out riding; they simply didn't have much
    effect.
  18. Pip
    Champ says...
    Thank god it's not just me .
    Lozzo, Jul 10, 2004
  19. Pip
    I'll spend a week riding with the front brake covered, and see how it
    goes. Then I'll have a more valid point of view.
    In theory though, what you say about unwrapping your fingers from the
    grip and curling them round the lever is interesting. It only takes a
    small amount of force on the handlebars to change a bikes direction
    slightly, so if you can be in a ballanced state riding with your fingers
    resting on the lever, then the very small change needed to brake isn't
    going to upset the bike too much.
    My Bandit, being a bike built down to a price and being on skinnier
    tyres than most sports type bikes is (imho) more easily upset by things
    like grabbing a hand full. So it'll be interesting to see if a small
    change in riding style can effect a bigger change in bike response.
    Thanks for the thought provoking stuff Pip.
    Muck, Jul 10, 2004
  20. Pip
    On the CG125, the front brake lever has the function of turning the rear
    brake light on, oh, and lightly rubbing the inside of the front brake
    drum to keep it from going rusty.
    Muck, Jul 10, 2004
