Covering the brake
Discussion in 'UK Motorcycles' started by Pip, Jul 8, 2004.
  1. Pip
    dwb Guest
    I took a decision the other day when a stupid bird ran into the road of
    '**** it' and just carried it.
    It moved, but I wouldn't have cared if it hadn't - cue cries of my lack of
    compassion towards animals.
    Is this actually true though? There are times when I've rolled off mid-bend,
    thinking "oh shit" (usually for other reasons) , and the bike has opened
    it's line slightly, but it doesn't actually react that violently. I guess
    this is possibly down to it being a modern bike (which makes me not want an
    old/non-sports bike ;-) ) or me riding slowly or something.
    That sounds very familiar...
    dwb, Jul 9, 2004
  2. Pip
    dwb Guest
    There is a theory though that using the throttle only possibly does slow
    down your riding or at least isn't that helpful. It's in my local IAM rag
    this month - basically saying that if you ride around all the time using
    only the throttle the day you really need the brakes will be the one you end
    up on your arse - (this is all to do with a long(ish) standing argument for
    and against track days). That and slowing down _miles_ earlier then
    necessary - very smooth, but very slow.
    dwb, Jul 9, 2004
  3. Pip
    I don't "not" use the brakes.
    darsy, Jul 9, 2004
  4. Pip
    On some of the older 70s Jap machines I've owned it certainly wasn't a
    good idea as it would seriously unsettle an already pretty fidgety
    suspension.
    I can more or less do it with impunity on the Guzzi and MZs
    sweller, Jul 9, 2004
  5. Pip
    dwb Guest
    Neither do I, but I do know I occasionally slow down miles too early :)
    dwb, Jul 9, 2004
  6. Pip
    It certainly varies a lot with the bike, as does the use of front
    brakes in corners. This latter would seriously unsettle the Sprint ST
    ( and most other bikes I've owned) causing them to sit up big stylee
    and often tending to start a weave in high-speed bends as the front &
    rear suspenders tried to catch up with each other.
    The same amount of front braking on the gixxer goes almost unnoticed.
    Reasons why everyone should have a gixxer thou, #25 in a series of
    infinity.
    Ace, Jul 9, 2004
  7. Pip
    And your point is?
    They probably don't recommend stoppying into bends on mountain roads,
    consistently overtaking on solid[1] white lines, doing 160+mph and all
    sorts of other things I deem to be part of my uncivic duty, either.
    [1] Double, for you UK types.
    Ace, Jul 9, 2004
  8. Pip
    Owen Guest
    I seem to remember the IAM reccomending filtering at no more than
    15mph faster than the traffic...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jul 9, 2004
  9. Pip
    Owen Guest
    As long as you're not ridding like a complete twat I don't suppose
    they're too bothered...
    O
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jul 9, 2004
  10. Pip
    that's when you first get on the bike, isn't it?
    darsy, Jul 9, 2004
  11. Pip
    My commute involes a lengthy section of double broken white lines with
    diagonal stripes - I am working on the assumption that this is the
    "motorcycle lane".
    darsy, Jul 9, 2004
  12. Pip
    Just check it works for the MOT / Scrutineering.
    Champ, Jul 9, 2004
  13. Pip
    You are indeed correct in that assumption :)
    Ace, Jul 9, 2004
  14. Pip
    dwb Guest
    Er, is that a dig, or a serious question?
    dwb, Jul 9, 2004
  15. Pip
    The *theory* is, if you are near the limit of the amount of grip you
    have on the front tyre, then shutting the throttle will transfer
    weight to the front and may overwhelm it. In practise, this is
    unlikely on the road.
    However, shutting the throttle hard will unsetlle the suspension,
    which may make a bad situation worse.
    Champ, Jul 9, 2004
  16. Pip
    Used to, pre-gixxer. Now trying to brake the habit.
    Ace, Jul 9, 2004
  17. Pip
    I should have clarified that by "except on the CD, where the back
    brake is better than the front".
    I do use it *very* occasionally - I'm thinking of when riding down
    steep hills covered in wet leaves or some other non-grippy situation.
    darsy, Jul 9, 2004
  18. Pip
    I will, this weekend.
    I feel dirty now.
    Champ, Jul 9, 2004
  19. Pip
    "What would Jesus do?"
    darsy, Jul 9, 2004
  20. Pip
    Ben Blaney Guest
    That's right, I bet he could shave at least 10% off his commute time
    by sliding the back at will, and hoiking a wheelie with his knee down.
    Ben Blaney, Jul 9, 2004
