Cornering...
Discussion in 'UK Motorcycles' started by Cab, Jun 10, 2004.
  1. Cab
    "Summer"
    hth
    Champ, Jun 15, 2004
  2. Cab
    from memory, or little black PDA?
    darsy, Jun 15, 2004
  3. Cab
    heh. Memory.
    Champ, Jun 15, 2004
  4. Cab
    Monkey Guest
    Ah - my hobby-horse. As I've said many times before, from everything
    I've read and experienced on countersteering, gyroscopic effects have
    very little or nothing to do with it. If anything, gyroscopes make it
    _harder_ to turn (seeing as a gyroscope wants to maintain its
    direction of travel).
    The most conclusive proof of this to me, is that vehicles without
    wheels (e.g. jetskis) can be countersteered. There can't possibly be
    any gyroscopes involved there.
    In addition, if gyroscopes were the main enabler of countersteering,
    then a bike with lightweight racing wheels would be harder to turn
    than bikes with heavy steel wheels, which obviously isn't the case.
    Gyroscopes might add stability, but they don't aid cornering.
    Countersteering simply makes the bike 'fall' into the turn due to
    'centrifugal' forces e.g. turning the bars left will 'throw' the bike
    and rider to the right, setting up for a right-hand turn.
    Countersteering simply enables you to get the bike leant over quicker
    - it doesn't actually make you turn the corner.
    Monkey, Jun 15, 2004
  5. Cab
    Monkey Guest
    Once you've got the turn set-up, you _don't_ countersteer. If you did,
    the bike would keep leaning further and further until it hit the deck.
    A cranked-over bike, at a constant lean angle, will have its bars
    turned _into_ the turn slightly.
  6. Cab
    What do you do if you want to tighten the turn?
    Ace, Jun 15, 2004
  7. Cab
    porl Guest
    Why would it? The bike wants to stay upright, it's being pushed out by the
    centrifugal force like a conker on a string being swung round the head. It's
    harder to turn a bike into a corner than to go straight, etc.
    Countersteering surely just makes the bike drop down to compensate for this
    and make the turn possible at all.
    porl, Jun 15, 2004
  8. Cab
    No it doesn't.
    WHich is countered by the camber thrust generated from the tyres. At
    a steady speed, and a constant radius, the forces are in equilibrium
    Champ, Jun 15, 2004
  9. Cab
    You countersteer some more.
    Champ, Jun 15, 2004
  10. Cab
    porl Guest
    This way madeness lies.
    porl, Jun 15, 2004
  11. Cab
    Exactly. And I'd ask you to imagine being cranked over, knee-down, at
    high speed on a racetrack, and ask yourself what you might feel if,
    when countersteering like this, the wheel first moved _away_ from you
    before dropping into the turn. I find it impossible to believe that
    you wouldn't notice this, whereas in fact all you feel is that you
    push the bar and the bike drops further into the turn.
    What I'd ask all the gyro-doubters to do is this: Take a bicycle
    wheel, held in both hands on the axle, and spin it. Then imagine the
    axle is a handlebar and push one side away from you gently. Instead of
    moving in that direction it will move up (or down, depending on spin
    direction) with exactly the same amount of force you're applying.
    Ace, Jun 15, 2004
  12. Cab
    I've no idea what you're trying to say here. If you countersteer, the
    wheel "moves away" from the direction of travel. We already agree
    that countersteering is what makes bikes steer, so what's the
    argument?
    So what? If you read the pages of John Robinson's stuff I typed in,
    the maths shows that there's no need to resort to gyros to explain it,
    so why do you feel the need?
    Champ, Jun 15, 2004
  13. Cab
    eh? why? In a corner the bike is *not* upright, so how can it "want
    to stay upright"?
    Champ, Jun 15, 2004
  14. Cab
    porl Guest
    No, I mean for me :)
    porl, Jun 15, 2004
  15. Cab
    A number of people have said that the gyroscopic effect is
    insignificant and that what happens is that there's a movement of the
    wheel in the opposite direction before the bike's geometry settles it
    into the corner. I'm saying I don't believe that, as you'd notice it
    in the circumstances described..
    Because he doesn't tackle the issue I'm trying to deal with. All his
    explanations about camber thrust are trying to show how, when the
    bike's C of G is shifted to one side, it will 'follow' that and lean
    that way/turn in that direction.
    He still seems to be suggesting that there is first a movement in the
    direction you push, followed by a reaction to that movement as the
    bike drops into the corner. I'd like to know if you think this is the
    case, and whether you can feel it happening in high-speed, knee-down
    corners.
    Ace, Jun 15, 2004
  16. Ace wrote
    Pile on the throttle until the back comes round.
    steve auvache, Jun 15, 2004
  17. Champ wrote
    So why do all you track heroes spend so much of your time making sure
    the bike does stay as upright as possible by getting off and running
    beside it then?
  18. Cab
    Hmm. I need to ask you some questions here:
    1. Do you believe that all steering above walking pace is done by
    counter steering? (Either from upright to leant over, or from leant
    over at one angle to some other angle).
    2. When you countersteer, does the contact patch move?
    3. Immediately after counter-steering, do you 'correct' the steering
    to maintain a steady attitude at the new lean angle?
    I don't know that I can feel it happening, but this is what I think
    happens.
    Champ, Jun 15, 2004
  19. Cab
    Ace says...
    Alot harder to manage on something as light as the CB250RS. The throttle
    sticks at about 35 in top gear, so I can play with hands off the bars.
    It takes quite a bit of leaning over to make the bike go round the very
    slight bends down our road at that speed. FWIW I now weight about 11
    stone and I am leaning right over to make it move off course, but it
    will go. Once the turn has started, it is easily centralised again.
    The Thunderace won't budge, it just ploughs straight ahead unless I hold
    the fuel tank with my hands and shift weight. Donb't ask me why, but
    this is the only way it will budge off centre with hands off the bars.
    Lozzo, Jun 15, 2004
  20. Cab
    No. Body weight shift also plays a part.
    Afterwards, yes, but only as a result of the changing angle of the
    bike.
    [1] It auto-corrects, for reasons as explained by JR in your earlier
    quote.
    Ah. Doesn't it seem strange that you don't notice it though?
    [1] Of course, one possible explanation that occurs to me, and
    possibly what JR's getting at, is that the steering angle actually
    remains where you put it with your contersteering input, and the
    camber thrust etc. turns you ruond the corner _even though the wheel's
    pointing slightly the other way_.
    This is something I'll have to think about...
    Ace, Jun 15, 2004
