Cornering...
Discussion in 'UK Motorcycles' started by Cab, Jun 10, 2004.
  1. Cab
    My view on this is that, at any sort of speed, the mechanism that you
    describe is not present, or is insignificant when compared to the
    gyroscopic effect.
    This is the tendency for a spinning mass to remain in the same axis
    and, if pressure is applied to change that axis, for the body to move
    in a plane at 90 deg to that in which the force is applied. Put
    simply, if your front wheel's spinning then pushing the handlebar
    forward results _directly_ in a tendency for the wheel to lean over to
    that side.
    So there's no initial opposite movement required here, although I
    accept that at low speeds this will be a factor. The explanation
    you've been given, which is what many instructors spout, works as an
    example to persuade people that countersteering exists, but in
    practice is not the predominant effcet.
    Ace, Jun 14, 2004
  2. Cab
    Salad Dodger Guest
    Ride the Wing, shift weight left, bars turn right, bike goes left.
    and vice versa.
    Controllable enough to negotiate country lanes, or change lanes on
    motorways, with the cruise on.
    | ___ Salad Dodger
    |_\_____/_| ..66073../..15556.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:35 Pts: 705 Miles:2429
    Salad Dodger, Jun 14, 2004
  3. Cab
    Porl Guest
    Do you mean that the lean angle is taken out of the riders hands, aside from
    changing the throttle position, after tipping in?
    Porl, Jun 14, 2004
  4. Cab
    Porl Guest
    Can you lot sort it out once and for all and then decribe it at Ladybird
    3a/b level.
    Porl, Jun 14, 2004
  5. Cab
    Porl Guest
    I get that. But what about all that "can't change the angle of lean once
    into it, it being dictated by tyres" or whatever whatisface was going on
    about?
    Porl, Jun 14, 2004
  6. Cab
    You steer the wheels out from under the bike, and it falls to one side.
    This works on racing bicycles with wheels that weigh less than one of
    Blaney's farts, so there's the gyroscopic effect right out the window.
    Geometry innit.
    platypus, Jun 14, 2004
  7. Cab
    Porl Guest
    I feel like I'm being a TC here but I don't know why.
    Isn't "the set of the bars once in a turn is dictated by the lean angle and
    the geometry of the bike" the opposite of "If you change the direction the
    front wheel is pointing while you're leant over, you'll change the amount of
    lean and radius of turn".
    IOW, how can you change the direction of the front wheel (to change the
    amount of lean and radius of turn) if the set of the bars is already
    dictated by the lean angle and geometry of the bike?
    Porl, Jun 14, 2004
  8. Cab
    Porl Guest
    Yeah I get that. But that wasn't exactly my question.
    Porl, Jun 14, 2004
  9. Cab
    Monkey Guest
    Well duh. Of course they bloody do.
    Monkey, Jun 14, 2004
  10. Cab
    Porl Guest
    Sorry, am I keeping you from some other fascinating ukrm conversation
    somewhere?
    Porl, Jun 14, 2004
  11. Cab
    Porl Guest
    I think that was confusing me. Cheers.
    Porl, Jun 14, 2004
  12. Cab
    petrolcan Guest
    the cont known as Porl says...
    More like keeping him from worrying where Ross is.
    petrolcan, Jun 15, 2004
  13. Cab
    OH- Guest
    Other bikes as well. Leaning the riders body while going
    straight will lead to the bike leaning the opposite way.
    The lean of the bike (while still going straight) will lead to
    forces from the front wheel that turns it into the lean. The
    contact patch of the front wheel is behind the head bearing
    centerline so the upwards force from the ground and the
    wheight of the bike coming down from the head bearings
    will turn the wheel.
    A bike that turns away from the lean by itself would be
    somewhat unstable.
    Us poor people without cruise control get to experiment mainly
    on long down hills.
    OH-, Jun 15, 2004
  14. Cab
    Oh piss off Simon - we've done this before and all you ever do is try
    to baffle with science'.
    What you don't ever do is explain what _does_ go on - it's clear from
    the K. Code experiments mentioned earlier that the main component
    involved in leaning a bike is _not_ weight transfer, and I've
    demonstrated (and you failed to counter) how 'weighting the pegs' is a
    complete nonsense.
    The idea that a cranked-over bike at 130mph countersteers by the wheel
    first moving away from the turn is patent nonsense - if that were the
    case it would keep moving away if you kept pushing, which it doesn't.
    So there are other forces involved. What do you think they are?
    <snip half-baked mathematics>
    Ace, Jun 15, 2004
  15. Cab
    Yeah, as I said, a slow turn can be induced by body weight shift,
    causing the bike to lean over and the bars to follow as described.
    Ace, Jun 15, 2004
  16. Cab
    Porl Guest
    Eh?
    Porl, Jun 15, 2004
  17. Cab
    I'm afraid I think you are wrong too. John Robinson's book make's
    very little reference to gyro effect.
    Anyway, countersteering *initiates* change in cornering, it is not
    present at a steady speed.
    Champ, Jun 15, 2004
  18. Cab
    LadyNina Guest
    < fx shakes head, newbies>
    As far as I can gather from the soap opera that is UKRM, Ross is
    Rope's previously troublesome teenage son - do pay attention at the
    back.
    LadyNina, Jun 15, 2004
  19. Cab
    And, of course, the larger the body weight is...
    Ace, Jun 15, 2004
  20. Cab
    porl Guest
    I can't remember Anne's granddaughter's name let alone any of the less
    female progeny associated with ukrm.
    porl, Jun 15, 2004
