Cornering...
Discussion in 'UK Motorcycles' started by Cab, Jun 10, 2004.
  1. Cab
    Cab Guest
    Right then, what the **** am I doing wrong?
    Last year, whilst with Ace and Ginge, I knew that I had work to do.
    Today, I was practising some more on the way back from a customer and I
    could get shallow bends okay at speed (like most people), but the
    deeper ones are still harder to get into.
    I take the corners fairly wide and lean into them, but I still keep on
    thinking that if I lean to far, I'll go over, so bottle it.
    Any clues?
    Cab :^) - Ormiga Atomica
    GSX 1400 - 'Tarts Handbag' (tm) Bike, dead 550/4 Rat
    UKRMMA#10 (KoTL), IbW#015, Bob#4, POTM#3
    P.S. Remove your_head from the cab. ICQ: 83023471
    Cab, Jun 10, 2004
  2. Cab
    HooDooWitch Guest
    Firstly, you've got to establish where the limit is. ...
    HooDooWitch, Jun 10, 2004
  3. Cab
    Ginge Guest
    Words I never thought I'd read.
    Try going slower, and build up the speed gradually.
    So, lean further, and don't bottle it. You'll get the peg down on your
    bike before it runs out of tyre.
    Ginge, Jun 10, 2004
  4. Cab
    David Thomas Guest
    Is that always the case?
    D
    Bandit N600 (unmarked pegs)
    David Thomas, Jun 10, 2004
  5. I take the corners fairly wide and lean into them, but I still keep on
    Yes, 'too' takes two 'o's.
    HTH. ;-)
    On a more serious note, you've been riding longer than I, so I shall not
    presume to give you advice, other than to repeat what a far more
    experienced rider told me: the tyres will not run out of grip, full stop
    (unless there's oil or whatever on the road). Modern tyres, blah blah,
    have to get elbow down before they run out of grip, etc.
    genuine_froggie, Jun 10, 2004
  6. Cab
    Ginge Guest
    No. but the GSX1400 has low pegs.
    Ginge, Jun 10, 2004
  7. Cab
    dwb Guest
    On their own probably not - it's when you throw in rider input, plus as you
    mentioned, road conditions, I don't see how that can always be true.
    dwb, Jun 10, 2004
  8. Cab
    David Thomas Guest
    What about my bandit 600 for instance?
    Would the pegs only scrape the ground if the rest of the bike was also doing
    so?
    D
  9. Cab
    dwb Guest
    Slowing down seems to be something you're struggling with though ;-)
    dwb, Jun 10, 2004
  10. Cab
    Ginge Guest
    No idea, I've never ridden a bandit 6.
    Try it. ;-)
    Ginge, Jun 10, 2004
  11. Cab
    David Thomas Guest
    People have only just stared letting me have a sit on thier bikes.... but
    they stand real close and get ready to catch it :-(
    Some even call a mate over so they have someone on each side.
    D
  12. Cab wrote:
    Yes, look towards the end of the bend and aim, not 10 feet in front of the
    bike
    eric the brave, Jun 10, 2004
  13. In uk.rec.motorcycles, David Thomas said:
    No, you can lean a bandit 6 for miles: No problem whatsoever.
    The pegs will touch down and you'll feel it but you can go *miles*
    further and grind your boots away with impunity.
    Have you ever wondered why they cut that slice out of the exhaust?
    Whinging Courier, Jun 10, 2004
  14. Cab
    David Thomas Guest
    *rushes out in dayglo vest (safety first) and shorts to have a go*
    D
  15. In uk.rec.motorcycles, Doesnotcompute said:
    Fucking kneedown! That's almost as bad as the biker issue, isn't it?
    I mean, if you ever actually looked at the photos that wear taken of
    anyone who wasn't a grade A racer, then frankly, it looks a bit fucking
    stupid. IMO, it only looks good when you're /right/ over and doing it as
    part of your job and not trying to cover up the fact you could be
    better.
    FFS!
  16. Cab
    David Thomas Guest
    Coz I'm crap, and have big ears and a walking stick and a pink bike and
    you'll take the piss, apart from that I'm perfect in every way... my mum
    says.
    D
  17. In uk.rec.motorcycles, Whinging Courier said:
    Sorry, *should* be better!
  18. Cab
    HooDooWitch Guest
    Dayglo & Shorts? On your bike? I'll wager you'll look like a slice of
    Battenburg with dog hairs dangling from it.
  19. Cab
    David Thomas Guest
    *runs out to garage to have a squint at exhaust*
    oh yeah so they do.
    D
  20. In uk.rec.motorcycles, David Thomas said:
    Oh, piss off!
