Cornering
Discussion in 'UK Motorcycles' started by Jeremy, May 21, 2004.
  1. If you're doing it right the front wheel is in the air
    and the back is sliding. It doesn't cause a front end washout.
    I managed it once at Quarry Bends.
    Or this could just be the ramblings of an old git in his dotage.
    Old Fart at Play, May 21, 2004
  2. Jeremy
    OH- Guest
    Apart from everything else, this is an opportunity to let the gyroscope
    into the motorcycle turning debate again.
    At greater speed the wheels gyroscopic effect gets greater, resisting
    change to where their axle of rotation is pointing.
    In the responses in this thread I miss some consideration of how
    braking rear or front and acceleration affects steering geometry by
    compressing or unloading the suspension. This can totally change how
    the bike feels.
    OH-, May 21, 2004
  3. OH- wrote
    I think you will find that this is because it so much a part of the
    shaftie not countersteering thing that folks tend to forget that it does
    have an effect on chain driven bikes as well, albeit a small one, and
    they tend not to mention it in case there are any more unfortunate
    incidents like there was the last time.
    steve auvache, May 22, 2004
  4. It was somewhere around Barstow, on the edge of the desert, when the
    Pixies little feet.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 22, 2004
  5. Jeremy
    I will make it this weekend's mission to prove him wrong.
    sweller, May 22, 2004
  6. Bike physics is always hard to analyse - well I think so. From my
    experience...
    When the bike is decelerating, especially braking, it requires more steering
    input (countersteering that is) to get it to lean over. I dunno why cos when
    the forks are compressed the rake angle of the forks is steeper so it should
    turn faster but it doesnt.
    Racers turn into corners hard on the brakes which I'd say is why most want
    the bikes to turn so quickly. I tend to turn into most corners on the road
    with the brakes on, out of habit. I'm just used to pushing hard on the
    inside bar so therefore dont ever feel like its going to run wide.
    Steve Bullimore, May 22, 2004
  7. Jeremy
    Porl Guest
    I was just saying that turning/leaning into a corner is how we compensate
    for the centrifugal effect pushing us out.
    Porl, May 22, 2004
  8. Jeremy
    Porl Guest
    porl: I lost the back and it still fucking hurt.
    Porl, May 22, 2004
  9. Jeremy
    Porl Guest
    Let's all make a pact never to talk about it again.
    Porl, May 22, 2004
  10. Jeremy
    Slider Guest
    Until they ran out of revs :-o
    Slider, May 22, 2004
  11. Jeremy
    John Guest
    You don't need to whack the throttle open, just give it a little bit
    to maintain your speed as you'll actually slow a bit as you corner. It
    will also set the suspension and transfer some weight to the rear
    tire.
    If you've overcooked it, well then you better have some ground
    clearance and traction to lean it in more or your going to make nice
    bike-shaped holes in the hedges.
    John
    Apple Valley, MN
    '02 FZ1
    '73 RD350
    John, May 22, 2004
  12. Jeremy
    Jeremy Guest
    Is that in rideable condition?
    jeremy
    ['75 RD250A ] | ['02 Fazer 600 in blue]
    ____________________________________________
    jeremy dot ovenden at hazelweb dot co dot uk
    Jeremy, May 22, 2004
  13. Jeremy
    John Guest
    Wot, the mosquito fogger? Yessir. And I will get you pictures some
    time this millenium! I've actually procured a genyoowine Yamaha seat
    cover[1] for it so piccies won't be along until at least that gets
    redone.
    [1] It currently has a huge rip in one side that is adorned with what
    looks like cigarette burns. Utterly ratty.
    John
    Apple Valley, MN
    '02 FZ1
    '73 RD350
    John, May 22, 2004
  14. Jeremy
    Abso Guest
    Imagine looking at the front of the bike when it's leant to the left,
    then with it upright, and finally with it leant to the right. What
    happens to the height of the headstock as you transition from leaning
    one way to leaning the other? It rises.
    So when you're braking and there's more weight transferred to the front
    of the bike there is more steering input required as it's actually
    harder to get the headstock (and the rest of the front half of the
    bike) to rise. In effect you're trying to push against more of the
    weight of bike + rider than when you're hard on the gas.
    Abso, May 22, 2004
  15. Jeremy
    Abso Guest
    Are you sure? Surely the centripetal forces act on the bike tyres and
    the forces on the rider are straight down through the seat towards the
    straight line between the contact patches (all the time you're
    cornering at constant speed anyway).
    Abso, May 22, 2004
  16. Jeremy
    Abso Guest
    ... also, if there were a centripetal force pushing the rider outwards
    (which you think you're leaning against), would this not also act on
    the bike and tend to straighten it out (reduce the bike's lean angle)?
    Abso, May 22, 2004
  17. Jeremy
    Porl Guest
    I said centrifugal not centripetal. The centrifugal force is what enables
    wall of death riders to stick to the walls.
    Porl, May 22, 2004
  18. What does it fucking matter?
    Why don't the cunts that don't understand just go and ride and work it
    out? It's not fucking difficult.
    Simon Atkinson, May 22, 2004
  19. ITYM the imaginary force we refer to as centrifugal is what sticks them
    to the walls.
    Actually (as I am sure you well know young Porl) the bike is trying to
    go ever higher and tiny sprinklings of fairy dust cause it to slide
    back down.
  20. Jeremy
    joe parkin Guest
    Almost.
    The centripetal force is proportional to the square of the velocity,
    implying that a doubling of speed will require four times the
    centripetal force to keep the motion in a circle. If the centripetal
    force must be provided by friction alone on a curve, an increase in
    speed could lead to an unexpected skid if friction is insufficient.
    Joe
    Chinese takeaway to reply
    joe parkin, May 22, 2004
