Copper gasket/washer question
Discussion in 'Motorbike Technical Discussion' started by yzfoot, Feb 7, 2006.
  1. yzfoot
    yzfoot Guest
    I'm having trouble finding copper washer gaskets for a fuel pump
    installation. All I find are copper gaskets for either electrical or
    brake applications. Are they all the same ?
    yzfoot, Feb 7, 2006
  2. yzfoot
    OH- Guest
    Copper washers for brake systems are used as gaskets
    and will be the correct softness (only new, unused ones).
    Thickness might be critical depending on how they fit in
    the assembly you're working on.
    I don't know about copper washers for electrical use
    but if they are not meant to be used as gaskets they
    might be to hard.
    OH-, Feb 7, 2006
  3. yzfoot
    Leon Guest
    They could be annealed by heating them.
    Leon
    Leon, Feb 7, 2006
  4. yzfoot
    John Johnson Guest
    That really depends a lot on the copper alloy used, and getting it wrong
    might very well result in high-pressure fuel being sprayed all over the
    engine compartment.
    I'm with Mr. Olson here: any reasonable automotive parts store will have
    suitable washers. Both Mark Olson and Ole Holmblad have stated
    (correctly, AFAIK) that brake-system crush-washers will be fine.
    So, to the OP, where have you looked for crush-washers?
    Later,
    John
    John Johnson, Feb 7, 2006
  5. yzfoot
    Ron Seiden Guest
    Curiously enough, some hi-tech brake lines I just installed came with
    *aluminum* crush washers -- surprised me, but I guess the manufacturers
    know.
    Ron Seiden, Feb 8, 2006
  6. yzfoot
    G C Guest
    The electrical washers are usually hard as the hubs of hell and won't
    make good crush washers. If you anneal them you are looking for trouble
    as a lot of electrical copper is beryllium alloy and TOXIC when heated.
    Use the brake washers or aluminum washers. Try McMaster-Carr or Small
    Parts Inc. if your parts house doesn't have 'em.
    Gopher Greg
    '77 CB750K Stock '78 CB750K AHRMA
    '00 ZG1000 Stock '96 Ducati 900SS Former track bike
    '01 GSXR750 Current race bike
    **********pull 'mychain' to reply***********
    ("I've abandoned the idea of trying to appear a normal, pleasant person.
    I had to accept myself as I was, even if no one else could accept me.
    For the rest of my life I would continue to say precisely the wrong
    thing, touch people in the raw and be generally unpopular. I had a
    natural gift for it" W. F. Temple)
    G C, Feb 8, 2006
  7. yzfoot
    yzfoot Guest
    I appreciate all the input, especially the one about the toxic fumes
    when home annealing. The copper gaskets are for a Volvo fuel pump but
    I know the gearheads here have the mechanical acumen to answers the
    generic question. Here is a long winded speil on todays frustration.
    After declining the local shops offer to replace the pump for $515 I
    ordered one from Murray's, I've had good luck with them on replacement
    parts in the past. Over the phone I ordered $172 Bosch that turned out
    to be an undersized Carter that came with a variety if fuel and
    electrical fitting that I could use to adapt it to my application. It
    had some real nice, fat, soft copper crush washers.I told the parts guy
    I'd take it with me but it was likely coming back. After a long web
    search I settled on a real Bosch OEM part for $220. It came without
    adapters or copper gaskets. I took the Carter adapto pump back to
    Murray's, all the time thinking about those nice, hard to find crush
    washers. Would the parts guy know if I replaced them with a lesser
    part? In a brief moment of morality/fear of bad Karma I left them in
    the box. Next I went to what used to be one of the better performance
    parts stores in town. As I looked around the newly expanded showroom I
    noticed lots of semi-cheezy tools displayed, none had any prices on
    them. Every time I turned a corner a sales geek would come ask if I
    needed help. When I got done browsing I asked about copper washers, I
    had an old one for comparison. The guy disapeared 'out back' for a
    while then returned with a small box marked 'brake' something In the
    box where a total of about a dozen copper washers of different sizes,
    all thin. I told him my application was a fuel pump, he said he didn't
    know if they'd work but for $1.70 each (discounted from $5.99) I could
    try them. Foolishly I bought the 2 I needed. Later, thinking about
    where else to look for the right part I remembered a new NAPA store has
    just opened. Turns out they had a much bigger box to consult when I
    showed them my sample washer. The kid pulled out a nice, fat, copper
    crush washer just like the ones I let slip away, 70 cent each. I took 2
    and bookmarked the new store on my preffered list. I put the 2 new
    crush washers on the Bosch pump banjo fittings and turn to the included
    instructions in hope of a torque spec to properly crush my gaskets.
    The instruction sheet folds up like an accordian. Eight sections
    printed front & back each in a different language, sixteen languages
    covered. I could read the one marked GB (Great Britan ??). It told that
    I should take the pump to a qualified person to have it installed and
    that gasoline was flamable and that I shouldn't have any gas leaks and
    that fire was dangerous. Yes, yes and so how should I tighten the
    banjo fitting cap so that I don't have any leaks ? Nothing to say
    about that. Anyway that's where this project is at thanks again for
    all the info on copper crush gaskets.
    yzfoot, Feb 8, 2006
  8. yzfoot
    yzfoot Guest
    out to be an undersized Carter that came with a variety if fuel and
    had some real nice, fat, soft copper crush washers. I told the parts
    guy I'd take it with me but it was likely coming back. After a long web
    while then returned with a small box marked 'brake' something. In the
    know if they'd work but for $1.70 each (discounted to preffered
    customers from $5.99) I could try them. Foolishly I bought the 2 I
    needed. Later, thinking about where else to look for the right part I
    remembered a new NAPA store has just opened. Turns out they had a much
    bigger box to consult when I showed them my sample washer. The kid
    pulled out a nice, fat, copper crush washer just like the ones I let
    slip away, 70 cent each. I took 2 and bookmarked the new store on my
    preffered list. I put the 2 new crush washers on the Bosch pump banjo
    fittings and turn to the included instructions in hope of a torque spec
    to properly crush my gaskets. The instruction sheet folds up like an
    accordian. Eight sections printed front & back each in a different
    language, sixteen languages covered. I could read the one marked GB
    (Great Britan ??). It told that I should take the pump to a qualified
    person to have it installed and that gasoline was flamable and that I
    souldn't have any gas leaks and that fire was dangerous. Yes, yes and
    so how should I tighten the banjo fitting cap so that I don't have any
    leaks? Nothing to say about that. Anyway, thats where the project
    stands. Thanks again for the info on copper crush gaskets.
    yzfoot, Feb 8, 2006
  9. yzfoot
    yzfoot Guest
    I noticed lots of semi-cheezy tools displayed, none had any prices on
    yzfoot, Feb 8, 2006
