Cooling a Rectifier Regulator.
Discussion in 'UK Motorcycles' started by gazzafield, Jul 25, 2006.
  1. gazzafield
    gazzafield Guest
    My Rectifier/ Regulator died the other week and has now been replaced. It
    has been replaced with the same model that lasted two years. This is much
    bigger than the original model where a replacement lasted a whole two months
    before spilling its guts.
    The only place I have to mount it is in the tailpiece as it is roughly 80mm
    * 80mm. There is no suitable hanging place that I can see anywhere else on
    the bike. Well, nowhere that it wouldn't get covered in shite. So my
    thought was to put a fan on it. I have two.
    I have a small Pentium 3 size fan and I have an 80mm * 80mm case fan. I
    like the idea of the case fan but I don't know if this would be overkill.
    I'm inclined to think the cooler the better though. What does the FOAK
    think.
  2. gazzafield
    gazzafield says...
    Extend the wiring and stick it under the bottom yoke, in the airflow.
    Worked nicely on my GSX750EFE and almost as soon as my mate put it back
    where it should have been it caught fire and melted a sidepanel.
    Lozzo, Jul 25, 2006
  3. gazzafield
    That's the trouble with non-Italian bikes - the electrics are shit.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jul 25, 2006
  4. gazzafield
    Monz Guest
    <Thud>
    Monz, Jul 25, 2006
  5. gazzafield
    Robs Guest
    Bolt it to a lump of 1/4 inch alloy plate, works well on the 400 imports!
    Rob
    Robs, Jul 25, 2006
  6. I have mine mounted on the tailpiece and it's not overheated.
    The smaller fan will do, but they don't last long and if it's already
    seen hundreds of hours use I wouldn't bother. The 80mm fan is yer man if
    you really want to fit one.
    Grimly Curmudgeon, Jul 25, 2006
  7. gazzafield
    gazzafield Guest
    And have it blowing the air into the heatsink (like a processor fan) or
    pulling it away? What do you think?
  8. Blowing in, in general. Too much ineffective air entry from the sides if
    it's sucking.
  9. gazzafield
    Having 'taken the mind' of several people in the know, a good smear of
    heat transfer paste between reg/rec and frame tube is a Good Thing
    too. A big fan blowing is the dog's, though.
    Pip, Jul 25, 2006
