Coo look at that. Maxton 916/996 shock FS
Discussion in 'UK Motorcycles' started by Hog., May 16, 2011.
  1. Hog.
    Back-filling from the nipple with a syringe is much easier, & doesn't
    run the risk of sucking air in via the M/C or caliper seals.
    Krusty, May 17, 2011
  2. Hog.
    Hog. Guest
    Any good workshop like what I've worked in 'ad a vacuum bleeder.
    Hog., May 17, 2011
  3. Hog.
    I've got a Mityvac, I just find a syringe easier & quicker to fill an
    empty system. I still use the Mityvac for final bleeding, or changing
    the fluid if I'm not draining it first.
  4. Hog.
    TOG@Toil Guest
    Sort of. A bit like you and I, really ;-)
    Oh, back to bleeding. I've got new tyres on the GPz750 (Contis: cheap
    and quite good enough) and thought I'd bleed the brakes. What's the
    form with the anti-dive system, because there's a bleed nipple on each
    caliper and on top of each anti-dive unit and a third (per side) on
    the junction box where the pipe to the anti-dive meets the brake
    pipes.
    I'm assuming that the pipe on the junction box is the last to be done
    because it's the highest, so is the sequence caliper, anti-dive,
    junction box, or what?
    Tia.
    TOG@Toil, May 17, 2011
  5. Not as nice as antifreeze.
    Grimly Curmudgeon, May 17, 2011
  6. Hog.
    I put it to the Hon. Gent. that if the caliper seals are in such a
    condition as to admit air due to the slight vacuum generated by a
    Mityvac, that brake fluid would indeed piss out as soon as the brakes
    are applied.
    Pip, May 17, 2011
  7. Hog.
    Logically that's the only order that would make sense. You'd need to do
    the calipers first to fill the system, then the other bits to do their
    respective air-traps. Bleeding a higher bit before a lower bit could
    just result in air from the lower bit moving up to the higher bit
    before you've had a chance to get it out.
  8. Hog.
    Mark Olson Guest
    Not necessarily. The seals aren't required to resist vacuum to do their
    normal job. I'm not saying good seals will leak, just that it's possible
    for them to seal perfectly in one direction but not the other.
    I've got a Mityvac and I'm not afraid to use it.
    Mark Olson, May 17, 2011
  9. Hog.
    I knew someone would.
    I'm sure you're right, but I'm equally sure that somewhere out there
    will be a dished seal that works like a piston ring. I suspect the MV
    has something weird as the Mityvac point blank refuses to work on the
    back brake. It'll get most of the air out, but not the last bit.
  10. Hog.
    Nige Guest
    Just beern into Leeds to buy one, £49 is better than £70, also should make
    the front easier to do....
    Nige, May 17, 2011
  11. 'Swot I fort.
    Btw, that racing car book is ace. Haven't dipped into Irving yet.
    The Older Gentleman, May 17, 2011
  12. Hog.
    Good attitude. Chin up!
    Pip, May 17, 2011
  13. Hog.
    Hog. Guest
    and I just found mine ;o)
    Hog., May 17, 2011
  14. Hog.
    Nige Guest
    Tockico calipers are the devils spawn, but we have a rear pedal now.
    And as a bonus, i'm still alive.
    Nige, May 17, 2011
  15. Hog.
    Nige Guest
    I'll drill a hole in it & take it back for a refund :)
    Nige, May 17, 2011
  16. Hog.
    Rather nicer than sodium hydroxide solution, I suspect. One of the
    most unpleasant experiences I've ever had.
    Pip Luscher, May 17, 2011
  17. Hog.
    On my Guzzi Quotas rear brake, a Mityvac is pretty useless: as far as
    I can tell, it just sucks fluid past an air pocket. The only way to
    bleed the thing is to unmount the caliper and hold it tilted up at an
    angle while bleeding it.
  18. Hog.
    Salad Dodger Guest
    Like GL1500s with the front left caliper, and rear caliper (Also on
    left) operated by the pedal.
    Very tricky to depress pedal while applying spanner to bleed nipple in
    such a set-up.
    Salad Dodger, May 17, 2011
  19. That's what I have. It plugs into my air compressor and makes brake
    bleeding an easy, one man, five minute job. Well worth the Aus$150 it cost.
    Fraser
    Fraser Johnston, May 18, 2011
  20. Hog.
    It is?!?
    Ewwww!
    Krusty, May 18, 2011
