converting 12 volts to 4 volts
Discussion in 'Australian Motorcycles' started by Locoaudio, May 29, 2008.
  1. Locoaudio
    Locoaudio Guest
    Hi
    I have a classic motorcycle and I have updated the old alternator to
    a
    Permanent Magnet Alternator,
    but the motorcycle has a starter safety relay ( which basically stops
    the starter motor from reengaging once the engine has started)
    which is activated by 4 volts from the old style alternator
    now i need something small rugged and vibration proof to step down
    the voltage from 12 volt to 4 volt
    any ideas
    Jamie
  2. Locoaudio
    G-S Guest
    It's actually an LM317.
    http://www.national.com/mpf/LM/LM317.html
    http://www.google.com/url?sa=t&ct=r...q94IoCmnUPkZ9qd8A&sig2=zDfKQFQ8myiJCG_vU-psCQ
    Sample circuit is in that lot.
    G-S
    G-S, May 29, 2008
  3. Locoaudio
    An LM317 will handle up to about 1.5A of current. If the relay needs
    more than that (which seems unlikely) then an LM350 will probably do
    the job.
    http://www.electronics-lab.com/downloads/datasheets/general_regulators.html
    BT Humble, May 29, 2008
  4. Locoaudio
    atec77 Guest
    I would think a simple resistive divider would do the job ? and how much
    voltage and current will the relay handle , can the relay be upgraded ?
    atec77, May 29, 2008
  5. Locoaudio
    theo Guest
    Figure out the current draw and use a resistor in series. Simple and
    cheap.
    Theo
    theo, May 30, 2008
