While installing the Road Attack tires I just purchased, we came across a question of which way is the correct rotation. The front tire has the arrow on the sidewall with "front" inside the arrow. Does "front" refer to the rotation or the actual front of the bike? Because of the inverted writing, if the tire is mounted with the text readable, the arrow would be pointed either against the rotation or towards the rear of the bike. I mounted it as the rotation, but noticed that it causes the tread pattern of the front to be opposite of the rear. Which is correct?
