Concorde Successor
Discussion in 'UK Motorcycles' started by Hog, Nov 23, 2003.
  1. Hog
    http://news.bbc.co.uk/1/hi/business/3231354.stm
    Bullshit, someone needs to read Skunk Works. I can just envisage a large
    passenger jet built of Titanium, which leaks fuel before takeoff and needs
    servicing at the end of each flight.
    Concorde was the optimum performance.
    Hog, Nov 23, 2003
  2. Hog
    Platypus Guest
    Titanium construction isn't a guarantee of fuel leaks. The Space
    Shuttle was originally designed to be made of titanium.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 23, 2003
  3. Hog
    Andy Hewitt Guest
    I was the optimum design in it's era for sure, and the shape is probably
    optimum too. However, the materials and power power units were not
    optimumised. With more powerful engines and new materials used it is
    almost certain it could go faster and higher.
    There is even more to consider now though. Computers! With these you can
    create new shapes that are be better at going faster with less friction,
    but may be less 'flyable'. For example the F117 would be almost
    impossible to fly if it relied on traditional control systems.
    Andy Hewitt, Nov 23, 2003
  4. Hog
    In terms of materials etc. I was referring to the SR-71 Blackbird.
    Going above the Mach 2-3 envelope would generate an excess of aeroframe heat
    almost impossible to dissipate. It would also lead to even more extreme heat
    distortion problems. Flying higher creates other problems with intake volume
    and solutions in turn reduce low altitude efficiency. I expect that Ben
    Rich's variable intake cones as used on the Blackbird are subject to several
    patents!
    Lockheed, after the creation of the Blackbird, killed requests for a
    hypersonic sub-orbital aircraft as they had realised it was impractical. It
    would need to be an orbital rocket system and the fuel load to transit 100
    passengers must be pretty large.
    Lets face it you don't need to go much faster than Concorde. Say a
    replacement was built it in Titanium and pushed to a sustained Mach 2.5?
    more than fast enough for Global commuting.
    Hog, Nov 23, 2003
  5. Hog
    Paul - xxx Guest
    Hog posted ...
    Heh .. **** that, the faster the better ... ;)
    Try to get rid of Jet Lag.
    Paul - xxx, Nov 23, 2003
  6. Hog
    Correct, but I think the Concorde development addressed fuel tank issues to
    some extent. The Blackbird had further problems, at Mach3+ they had to run a
    heat pump to protect the cameras and pilot. They were using the fuel as the
    heatsink, having developed a special fuel which was happy at 450F.
    Hog, Nov 23, 2003
  7. Hog
    Ummm...because it was the only practical metal for an aeroplane flying
    sustained Mach3 never mind 6. This was one of the finding from Lockheed
    detailed in Ben Rich's book.
    I doubt that sacrificial ceramic tiles are going to find there way into
    airline workhorses.
    Hog, Nov 23, 2003
  8. Hog wrote
    Who says it has to be metal?
    Sacrificial you are prolly right about but don't dismiss the efforts of
    Brave British Materials Engineers. We will find something for the
    merkins to steal to make it work don't you worry.
    steve auvache, Nov 24, 2003
  9. Hog
    Andy Hewitt Guest
    I'll bet they are. ISTR though that they have achieved much higher than
    Mach 3 with the old Bell X-x series. Although this was a very small
    plane, and certainly not subject to the same expansion problems in the
    larger planes.
    Although they are experimenting with alternatives now, SCRAM jets and
    even the old RAM jets are being considered. Not forgetting that chap
    experimenting with a light engine.
    The trouble they have is that most of the Concorde clientel were killed
    in the twin towers, and unless they can find other routes, and other
    buyers, it will never become a viable option. I can't see the cost of
    developing a new plane would justify and extra Mach 0.5 though, the time
    saving just wouldn't make it worthwhile.
    Andy Hewitt, Nov 24, 2003
  10. Hog
    Platypus Guest
    50s technology. The X-15 was doing Mach 6 in the early 60s.
    http://www.airartnw.com/firstreentry.htm
    Heat (and drag) is produced when the supersonic airflow is turbulent.
    When it's smooth, there's less heat and drag. So, improved
    aerodynamics. It should be possible to show improvements over the
    efforts of 40 years ago. Skylon, for instance:
    http://www.gbnet.net/orgs/skylon/
    Worthless on grounds of prior application - see Miles M52 and the
    computer-controlled intake ramps on Concorde.
    Kick the plane out of the atmosphere and you can go as fast as you like.
    Platypus, Nov 24, 2003
  11. Platypus wrote:
    I'd like to go at 3e8 m/s.
    Does that mean I'm warped?
    Old Fart at Play, Nov 24, 2003
  12. Hog
    Dan White Guest
    I can certainly see how it would have been more convenient for Bilbo and
    Gandalf etc...
    Ah, my coat. Thanks.
    Dan White, Nov 24, 2003
  13. Hog
    Oh, fair enough - you know more about aircraft design than a
    multinational aerospace company, cos you read it in a book.
    You should drop them an email, you'll save them a lot of trouble.
    Champ, Nov 24, 2003
  14. Hog
    Er, the faster you go, the worse jet lag gets.
    Champ, Nov 24, 2003
  15. Hog
    deadmail Guest
    Is that true?
    Actually it's not something I suffer from so I wouldn't know.
    I find sleeping little enough so one's constantly irritable means when
    one should be suffering from jet-lag one seems 'normal'
    deadmail, Nov 24, 2003
  16. Hog
    I think so - it's a factor of having to adjust your body clock. If
    you travelled by sea to New York, the change in Sunrise/sunset time
    each day would be gradual, and you'd suffer no effects.
    If you instantly teleported to New York in a UK evening, , you'd have
    to, start a 2nd daylight day when you got there.
    Flying by jet is somewhere in between the two.
    Champ, Nov 24, 2003
  17. Hog
    Ginge Guest
    Not really, you'd only be an afternoon behind, and you could have a
    decent lie in the next day.
    Ginge, Nov 24, 2003
  18. Hog
    More to the point, instant teleportation would mean the reverse would
    be true, so you'd be able to pop home to bed whenever you felt like
    it.
    Ace, Nov 24, 2003
  19. Hog
    Travelling east-west is easy. You just stay up a bit longer or go to
    bed a bit early.
    Travelling from west-east (eg. US->UK) is trickier. You either have
    a very short day, or you leave the west in the evening and arrive in
    the east in the morning, having had a night lasting a couple of hours.
    By that point your body thinks it's the middle of the night but the
    clock says it's the next morning. If you sleep all day to catch up,
    you're awake just in time for nightfall.
    ogden, Nov 24, 2003
  20. Hog
    The difference was in endurance. The Bell made a fast dash to speed, the
    SR-71 maintained it for hours producing new problems. I liked the passage in
    that book about the end of life airframe analysis. The titanium fuselage had
    been so annealed that it was tougher than when originally constructed. I
    was also greatly amused by the tales of learning to work with this (then)
    new material, brought back memories of Fast Reactor development - titanium,
    inconel and pe-16 come to mind.
    These wouldn't get a passenger jet off the ground from a static start within
    local noise regs though.
    Hog, Nov 24, 2003
