Concept
Discussion in 'UK Motorcycles' started by platypus, Oct 15, 2004.
  1. platypus
    Timo Geusch says...
    Doesn't it piss you off that the Schuberth wouldn't look out of place
    parked up on the grass at Menwith Hill base? For a helmet they are
    certainly big enough.
    Lozzo, Oct 16, 2004
  2. platypus
    Lozzo was seen penning the following ode to ... whatever:
    Yeah, you're right, small it isn't. For me the deciding factor was
    that I'm rather sensitive to noise (prolonged exposure to noise tends
    to trigger a migraine) so the considerably lower noise level to choice
    # 2 (Arai Corsair, the only other helmet that fits me properly) is
    good enough for me to ignore that I'm kinda looking like I've got a
    big head...
    Timo Geusch, Oct 16, 2004
  3. platypus
    tallbloke Guest
    Well unless you are the kind of biker who admires his reflection in shop
    windows when he should be keeping an eye on the road it don't matter too
    much really.
    tallbloke, Oct 16, 2004
  4. platypus
    Sean Guest
    I had a Schuberth Speed. It's just come to the end of its useable life (
    polystyrene now compressed so the lid is a bit loose ) after 3 years of
    daily wear.
    Best helmet I ever had in terms of comfort, wind noise, fit etc. The
    visors had an anti-mist coating that -shock horror- actually worked!
    The vents worked too!. Madness!
    If I didn't need a flip front, I'd go for another Schuberth without
    hesitation.
    As it is, I do need a flip front, and the Schuberth Concept didn't fit
    as well as the Shoei, so the Shoei won out.
    If the Schuberth fits you, buy it.
    Sean, Oct 16, 2004
  5. platypus
    See that biker, admiring his reflection ... that's auvache, that is.
    Pip, Oct 16, 2004
  6. platypus
    Christofire Guest
    No, but with a sharp knife you could fashion your own from those visor
    inserts that cover the whole visor[1]. Just cut a strip off the top
    and you're away. I reckon you could get 2-3 out of each one, making it
    either 1.67 or 2.50 each, which is a fair bit less for the same thing.
    As they're curved, even if you can only make one per insert, it's still
    1/3 the price.
    [1]http://www.rivetts.co.uk/CatalogueList.asp?CatID=32
    Visionary visors, about halfway down, two for a tenner.
    Christofire, Oct 16, 2004
  7. platypus
    Slider Guest
    Game over man, game over.
    Slider, Oct 16, 2004
  8. platypus
    One source of comment:
    http://www.webbikeworld.com/r2/motorcycle-helmet/schuberth-helmet/
    ....which is why I want to have a close look at the thing before I make my
    mind up.
    platypus, Oct 16, 2004
  9. Pip wrote
    True, so very, very true.
    Me and the Pacemaker look the absolute dogs bollox in the Co-op window
    we do.
    steve auvache, Oct 16, 2004
  10. platypus
    tallbloke Guest
    What, on an MZ 150?
    I wonder if he noticed the reflections of all the bystanders laughing.
  11. tallbloke wrote
    ****. At least I don't look like fucking Twizzle. I make *any* fucking
    bike look good I do. An asset to fucking motorcycle aesthetics me and
    don't any of you fucking forget it.
  12. platypus
    tallbloke Guest
    Quite the motorcycle dandy
    in his derri's and his mitts
    paint in apple candy
    With shiny chromy bits.
    Takes off down the street
    in a cloud of sweet 2t
    Smiles at those he meets
    What a happy lad is he.
    Sees himself in co-op window
    cutting quite a dash
    but watch that VOLVO up ahead
    Too late, screech, tinkle, smash.
    You all pose safely now.
  13. tallbloke wrote
    LOL.
    Cracking that is, all your own work?
  14. platypus
    tallbloke Guest
    Totally off the cuff. Honest.
  15. platypus
    platypus was seen penning the following ode to ... whatever:
    They were looking at the DOT-approved version of the helmet...
    I've just checked - my 'L' S1 has an ECE weight sticker in it that
    says '1525g'. Compared to the flip lid which supposedly weighs 1740g,
    this seems to be mostly correct.
    Can't quite follow their comment about the noise - the helmet is
    considerably more quiet than my XR800; the only problem you can run
    into is when you airflow from the top of the windscreen onto the
    underside of the helmet, that does increase the noise level. And the
    owners manual actually points this out for those amongst us who can
    read. The only 'vent noise' I noticed on this helmet is when I've got
    the chin vent open, which is only to be expected. The other source of
    noise clearly can be attributed to the screen height of the Pan as it
    goes away if I crouch slightly behind the screen.
    Their comment about the non-tabbed visor rings pretty much true. I
    found I quickly got used to it, but it's not that great to close the
    visor. That said, AFAIK you can get a visor with a tab on but it
    increases the noise level slightly.
  16. platypus
    dwb Guest
    As I've possibly mentioned before, IMO the Concept is crap.
    It's heavy.
    It's noisy.
    The 'seatbelt' type clip is an arse to do up.
    And.. it's just bloody ugly.
    If I were going to any kind of distance, I'd leave the Concept on the shelf
    and take the Shoei Z1 every time.
    Someone will be along shortly to tell me I know nothing.
    dwb, Oct 17, 2004
  17. platypus
    dwb says...
    Sounds about right.
    Dan, on this subject you know everything. Mainly because you are one of
    only 5 people who bought one.
    Lozzo, Oct 17, 2004
  18. platypus
    MattG Guest
    dwb says...
    That particular seatbelt clip? Or that type in general?
    I like them, but I know that many don't. I find them more convenient
    than the D rings, quicker and easier. Although it can be a pain on a
    spare lid, having to adjust the strap to the right length for different
    pillions.
    MattG, Oct 17, 2004
  19. platypus
    The Shoobs are in the same ballpark, pricewise, as a decent Arai. I've had
    my well-battered Quantum/f for about 5 years, and I love it as a helmet. If
    it had a sun-visor, it would be perfect. Otherwise I wouldn't be
    considering anything other than another Arai to replace it.
    platypus, Oct 17, 2004
  20. platypus
    PeterT Guest
    platypus
    Doesn't help with the glare off the street and cars though.
    Gimmicky, but rubbish, in my opinion.
    PeterT, Oct 18, 2004
