COMPRESSION TESTING
Discussion in 'Motorbike Technical Discussion' started by John Mathias, Oct 10, 2003.
  1. John Mathias
    John Mathias Guest
    I live at an elevation of 5000 feet. I think the compression reading
    to be expected should be corrected from the manual value, for the
    reduced air density at this location. Does anyone know the proper way
    to make this correction?
    John
  2. Ooooh, I like this thread already. Methinks it has great potential.
    So if you have a reading of 160psi at sea level at (say) 70 degrees F,
    what would you expect at 5000 feet?
    The Older Gentleman, Oct 11, 2003
  3. <snip>
    *Impressed*
  4. John Mathias
    John Mathias Guest
    You did not read my message, or at least, it did not sink in. I asked
    whether anyone KNOWS the PROPER way to correct for density.
    John Mathias, Oct 11, 2003
  5. John Mathias
    bowman Guest
    http://dbhs.wvusd.k12.ca.us/GasLaw/KMT-Gas-Laws.html
    It's got something to do with avocados, iirc.
    bowman, Oct 11, 2003
  6. John Mathias
    Pete Guest
    All this gas law stuff looks quite familiar, but I'm not sure it is the
    answer here.
    Could be you don't have to correct for anything (but this needs more tech
    input to analyze correctly.) For one thing the gauge is measuring gauge
    pressure, not absolute pressure.
    I think the important thing is that all the cyl's read close to each other,
    like, within about 5%. And if they are different, it could be something like
    a valve clearance adjustment. It doesn't mean you have fried valves, or
    something worse, if they aren't all the same.
    Dave "not really answering the origonal q but thinking he's contributing
    something worthwhile" W.
    Pete, Oct 12, 2003
  7. John Mathias
    Lemmy Guest
    Ok, so are you "Pete" or "Dave"?
    From the perspective of my feeble experience, I agree with Petey-Dave.
    My manual ('83 Kawa KZ440) actually states that exact cylinder pressure, as long as it's not well below the suggested range is not as important as cylinders having matched pressure AND (here comes my contribution)...
    the pressure of the cylinder should be taken, then add a tablespoon of oil to the cylinder and recheck the pressure. If the pressure WITH oil is considerably higher (subjective terms, I know) then you likely have a piston ring job in your future.
    Careening farther from john's original question but also hoping to add something.
    Your mileage may vary.
    -Paul
    Lemmy, Nov 30, 2003
