Commuter bike?
Discussion in 'UK Motorcycles' started by fishman, Sep 4, 2009.
  1. fishman
    fishman Guest
    Imagine you had to commute from the A1 near Sandy to London for the
    next few months and are a new rider.
    What bike would you use and what kit would you wear given the weather
    we're about to endure for the next few months and why? Budget £3k for
    the bike and £realistic for the kit.
    I'm thinking 650 V-Strom...
  2. fishman
    Simes Guest
    Pan Euro or old BMW. Something with plenty of fairing if you're
    commuting through the winter.
    Simes, Sep 4, 2009
  3. fishman
    TOG@Toil Guest
    Took the words out of my mouth. And shaft drive too. Pan, BMW K100RT/
    LT, K1100LT, old airhead RT, Kawasaki GTR1000 (does much the same job
    and is dirt cheap used).
    TOG@Toil, Sep 4, 2009
  4. fishman
    Jim Guest
    I guess Yamaha XJ900 is worth a look as well on that basis.
    Jim, Sep 4, 2009
  5. fishman
    Simes Guest
    True - but not such good protection from the ellyments.
    Simes, Sep 4, 2009
  6. fishman
    TMack Guest
    Not a bad choice of bike. I do a minumum of 60 miles a day commuting on mine
    and I often do a combination of motorway, A roads, B roads, unclassifed
    roads and urban stuff. The v-strom is only half-faired but the fairing and
    screen do a decent job of protecting against weather. It will sit happily on
    the motorway at an indicated 100mph (really about 90mph) and fuel economy is
    very good. It has a pretty flat torque curve, which means it pulls strongly
    from low revs all the way to max. The upright riding position is
    comfortable. However, it is quite a tall bike and is a little top-heavy so
    it isn't quite as agile as some when filtering. Also, the handlebars are a
    bit wide compared with most sports bikes, which reduces filtering capability
    very slightly. Build quality is pretty crap so be prepared for furry bolts,
    peeling engine lacquer and rust if you ride through winter. Liberal
    applications of ACF50 or similar will help keep corrosion at bay.
    Heated grips are a must-have. For luggage I would recommend a combination
    of top box and a tailpack sitting on the rear seat as panniers tend to make
    bikes quite wide at the rear, which can hamper filtering. Scottoiler is good
    for chain maintenance.
    Be prepared to spend in the region of £750 to get kitted out properly. I
    would recommend Heine Gericke textile clothing as the quality is pretty good
    in most of their ranges. Make sure the jacket is reasonably loose fitting
    so that you have room for extra layers underneath in winter. I use a fleece
    waistcoat under my jacket on the coldest days.
    Spend money on decent boots. They need to be waterproof, warm and
    comfortable whilst offering good protection. Anything else from the Daytona
    winter booot range would be good. Any gloves that are comfortable and
    waterproof are likely to be OK. Where the helmet is concerned, comfort and
    quietness are probably more important than any specific make. Even the
    best helmets suffer from wind noise over 50mph so make sure you use
    earplugs.
    I tend to wear my textile jacket and trousers over my work clothes and carry
    my work shoes in the tailpack. When I arrive at my destination I can take
    off the motorcyle kit and store it in the bike's topbox and tailpack
    (provided the gear isn't too wet) and walk in wearing a suit. This is handy
    because not all of the places I visit have changing and storage facilities.
    TMack, Sep 4, 2009
  7. fishman
    Simes Guest
    It must have been while you were kissing me...[1]
    All good.
    [1] I feel a little soiled.
    Simes, Sep 4, 2009
  8. fishman
    crn Guest
    Hmmmm - the V-Strom is a bit lardy for city commuting.
    Depends on the traffic on your standard route, but in general London
    traffic calls for something skinnier and more flickable to cope with
    dodging through the holdups.
    I normally suggest a lightweight of around 125Kg such as a 125 or 250
    for typical town stuff or the GS500 if you have some faster bits.
    Trailies are nice and manoeverable if you are tall enough but be warned
    that they are skrote magnets, probably a good idea to stick to
    something less likely to get nicked unless you have secure parking.
    crn, Sep 4, 2009
  9. fishman
    Simes Guest
    **** me you're a twat. He's going to be fine toodling down the A1 on a
    fucking 125 isn't he? Well protected from the weather and able to whizz
    away from the roundabouts.
    Honestly Matey - stop offering advice as you are always (without fucking
    exception) wrong to the point of being dangerous. One day some poor
    idiot will listen to you and take your advice, then you'll end up with a
    death on your conscience.
    GS500 is the nearest to useful in the above - and in reality it's too
    small and lacking in weather protection for a 50 mile each way commute on
    the main road in winter.
    You've obviously never ridden a Pan (or other 'big' bike) otherwise you
    wouldn't have this obsession with them being unwieldy.
    Simes, Sep 4, 2009
  10. fishman
    Jim Guest
    I think crn once read "recommend what you own" and misheard it as
    "recommend what you own even if it's completely unsuitable". In his
    world horses wouldn't only be for courses but also for motorways and
    possibly even deep sea diving.
    Jim, Sep 4, 2009
  11. fishman
    Jeremy Guest
    says...>
    I really like that one, may I use it?
    Jeremy, Sep 4, 2009
  12. fishman
    Jim Guest
    Sure, I'd have put "(c) Jim" at the bottom if I cared.
    Jim, Sep 4, 2009
  13. fishman
    Simes Guest
    BWWAAAAAAAAAAAAHAHAHAHAhahahahahahahaha
    Brilliant. I think crn should put that in his .sig file. If he knows
    how.
    Simes, Sep 4, 2009
  14. fishman
    zymurgy Guest
    Well, they can be a bit unwieldy. My FJ1200 is unwieldy at low speed
    (as it's a heavy bike). The Tiger is unwieldy (as it's top-heavy)
    everywhere except when hooning down quiet back roads.
    Non-unwieldy big bikes do exist, but they aren't starter bikes (i'm
    thinking litrebikes here really)
    Cheers,
    Paul.
    zymurgy, Sep 4, 2009
  15. fishman
    Nige Guest
    The K1200S is as big as you get & feels very tidy at low speeds, including
    walking speed.
    It looks like i'm keeping it too :)
    Nige, Sep 4, 2009
  16. fishman
    JackH Guest
    Only if you're limpwristed old giffer... Pan wise, anyway.
    I found the one I had excellent in the manoeuvrability stakes.
    JackH, Sep 4, 2009
  17. fishman
    Nige Guest
    Spend about £1500 on a transalp or similar & about a grand on the kit.
    Nige, Sep 4, 2009
  18. fishman
    Nige Guest
    Incredible actually.
    Nige, Sep 4, 2009
  19. fishman
    zymurgy Guest
    Well, for sure. I'm happy with the bikes I own, unwieldy or not, but
    they can catch you unawares, (especially with luggage) if you're off
    the bike, manouvreing them by hand.
    Being lanky helps, especially with the Tiger.
    Not had the pleasure yet, but I will. I can see the C of G is low on
    them, as was my Blackbird. Tootling it along at walking pace was a
    doddle.
    Cheers,
    Paul.
  20. fishman
    steveloukes Guest
    Pan Euro. This one looks reasonable:
    http://cgi.ebay.co.uk/Honda-ST1100-Pan-European-Only-6800-Miles-from-new_W0QQitemZ280391237397
    Steve
    steveloukes, Sep 4, 2009
